Question about Pentax K1000 35mm SLR Camera
Film I own a pentax k1000 and I had finished shooting for the day, and I wound the film back, but accidentally went to far, and now the films gone is isde the film cassette, can I solve this, if so how? cheers
Ya all you really need is a "film retriever." We use the Arista Deluxe one in class and it is extremely user friendly (this one, http://www.freestylephoto.biz/32760-Arista-Deluxe-Film-Retriever?cat_id=1603), however you can probably find it cheaper on ebay or craig's list, but ya that's all you need to pull it out, however, be careful when using it because if you wind it up too tight then you may just have to develop the roll, but um ya that's my solution.
Posted on Nov 21, 2008
Can you usePentax k1000 or me super film caamera lens on a Pentax ditigal camera?
Yes, with limitations. The lenses will fit on any Pentax (now Ricoh) digital SLR. You may lose autofocus and/or auto exposure metering.
Oct 19, 2014 | Pentax Cameras
Asahi pentax sv film advance lever stuck
Without film in the camera it may well read before zero, my K1000, K1000Se, and K2 do that. Press the film rewind button, maybe that will release it for you.
For camera repairs look to:
Eric Hendrickson: http://www.pentaxs.com/index.html
Oct 02, 2012 | Pentax K1000 35mm SLR Camera
The flip up switch to rewind the film has fallen off, I have all the original pieces but cannot fit the bar in. How do I take off the rewind lever to fix it?
Perhaps the following site will help you visualize the fixing. I remind you that these film cameras sell for very little now days and can be purchased for a song. see: http://www.slideshare.net/lokerd/pentax-k1000-35mm-slr
Apr 14, 2011 | Pentax K1000 35mm SLR Camera
I took 4 rolls of film in for development but when I got them back all of them were either very under or overexposed despite taking all the pictures according to the light meter in the viewfinder of my...
Are you looking at the picture as in a print OR are you holding the negative up to the light and looking at it that way. Don't touch the negatives, they should be in a protective sleeve but you can see through it. You should be able to see if the spacing between the frames is messed up and if you have lighter and darker negatives. Looking at a print from an automated one hour service isn't worth the time of day to determine a problem. The Pentax K1000 is the work horse of the century for students learning photography and a lot of them have seen extensive use, also the camera is quite old. What I expect is if the negatives are showing overlapping frames AND the exposure is off sometimes over and other times underexposed then the camera needs service lubrication and adjustment. It's great that the light meter is working but the shutter speed could be off and the advance is skipping giving the overlap. I don't know where you are in this world but in Canada that's a $80.00 to $120.00 fix and have the repair person change the light seals while he/she has it apart.
The Pentax K1000 is still a great camera it's up to you whether or not to spend the money. I can't tell you what to do but I can suggest that if you are going to shoot film you find some place that does it with a little more human touch. Hope this was a help
Jan 24, 2011 | Pentax K1000 35mm SLR Camera
Will no longer recognize 4gb sd cards
F4shsk1
are you sure the camera is a Pentax K1000.
the K1000 is a manual 35mm film camera, the only electronics in it are for the light meter. plus a circuit for the flash connections.
Apr 14, 2009 | Pentax K1000 35mm SLR Camera
The handle that pull the film forward is blocked or jammed.
lovegolf,
Sounds like the film might have been and wound but not exactly straight, almost hard to do but it can happen.
You don't have to disassemble, Most film cameras have a button on the bottom directly below the winder that you hold in to disengage the gear thaat winds the film, like a clutch, so you could unwind or rewind, that's how you could get some double exposures back in the day. The other thing you can do is (if you don't want to save the exposed film is to open it in a light proof bag if you have one - if not take it to a camera repair shop and they can open it without damaging the camera and even salvag the film, just make sure you call them and describe the problem and negotiate the price before they do the work. You will both be happier that way.
randy320sgi
Mar 06, 2009 | Pentax K1000 35mm SLR Camera
Pentax 145M has lost data from LCD panel
Open film door.
There should be small CR2025 battery in the film door.
Mar 04, 2009 | Pentax IQZoom 145M 35mm Point and Shoot...
How do I rewind and take the film out of a pentax k1000?
mhamabrown,
push the rewind button on bottom of camera and turn rewind knob to the right, ( clock wise ) then pull the rewind knob up to open the film door.
Feb 24, 2009 | Pentax K1000 35mm SLR Camera
Scratched Negatives
When you say ''back'' of the film do you mean on the emulsion side or the base side. Base can take light scratches can may desapear in processing..Emulsion side is not forgiving...
Hard to tell..Anything along film path can cause scratches, including the back of the cover, film tension, aperture gate..
Hard to suggest anything precisely other than a good check up by registered Pentax rep.
I once spoted a similar problem by loading a camera with he film wounded backwards. That is emulsion facing the back of the camera and base toward the lens. Emulsion being softer, I found a spot where emusion built up (thus scratching on base side). I did not dare fixing it and sent it for repair for a good clean up.
Under proper lighting, you may also want to remove the lens and carefully look for the scratch in the aperture gate. If you see it, problem is before (feeding side).
Good luck. KX is aging but still a good camera
Mar 22, 2008 | Pentax K1000 35mm SLR Camera
Pentax
i think it means the film hasn't loaded properly. I had this and opened up the back and the film hadn't wound so it wasn't exposed. Anyway i just wound the film around a bit and shut the back and it turned on like normal. hope this helps.
Jun 30, 2007 | Pentax IQ Zoom 60S 35mm Point and Shoot...
Pentax K1000 35mm SLR Camera Logo
99 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
