Need replacement Audio Transmitter for Shift3 Wireless Speaker with Audio Transmitter
I Need to purchase a REPLACEMENT AUDIO TRANSMITTER; for Shift3 Wireless Speaker with Audio Transmitter. I contacted manufacturer on box (MSCUSTOMERCARE.COM) listed for support help, they say product discontinued and they do not sell replacement parts and not of any help at all, I have been trying to find one for past year or two. the transmitter does not do anything when turned on, using brand new batteries. Product DetailsExperience 100% Wireless Music throughout your home or yard with the Shift3 Wireless Indoor/Outdoor Speaker System! Plus enjoy direct line-in connection as well! Instantly transmit all of your favorite music from your home stereo receivers, MP3 Players,CD Players, Personal Computers, Television, Laptops and more! With a 180 degree pivoting speaker head and various other useful features, this Shift3 speaker system has it all!!! Key Features Brand: Shift3Type: Speaker SystemUPC: 694202102848 Miscellaneous Product ID: 111893725 I only want a transmitter not the whole system.
ginko
  • 19396 Answers
SOURCE: Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
Posted on Jul 19, 2008
SOURCE: Mismatch of stereo receiver outlet to connector wire.
There are adapters available at Radio Shack for connecting almost anything to anything.
Not knowing which connectors you have, I can't tell you what to get, but if you take what you can with you and explain the rest, they should be able to give you the correct adapter.
Posted on May 09, 2009
SOURCE: I have a Prolink wireless
I have Prolink 900 MHz wireless loudspeakers, probably the same as yours. The transmitter is labelled on the bottom as "CAN 2579 102 1811, UNI-ART PRECISE PRODUCTS LTD". That transmitter comes with an AC/DC adapter whose output is labelled as 12VDC, 300mA, with polarity positive outside, negative inside. Note this polarity is the OPPOSITE of what is typical for AC adapters.
Posted on Dec 06, 2010
robotek
  • 1512 Answers
SOURCE: I need an AC/DC 19v
Hi Curtis
This a hard to find item... if you are quick, you can get one here or here
Only other place I could find one to do the job for you... was rated at 1 amp, and cost $213.00 !!
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 30, 2008
smarthome2
  • 1114 Answers
SOURCE: place for connecting transmitter ot reciever..cable plug does not fit anywhere on receiver
If you just using them for stereo, use the "main pre-out" on the receiver. if your using them for surround, they need to go the 5.1 pre-out rear. Hope this helps.
Posted on Jun 07, 2009
NEED REPLACEMENT NON OEM REPLACEMENT WILL WORK WITH POLK AUDIO WIRELESS SUBWOOFER PSWi225
sq nearest expert radioinstaller I'm sure he will know the answer and have the replacement part you need
Feb 08, 2015 | Polk Audio Audio Players & Recorders
Changed battery and it doesn't detect transmitter. Everything else works and the transmitter gets detected by our treadmill, so I know it works.?
Transmitter Battery
The estimated average battery life span of the transmitter is 2500 hours of use. If you suspect that the transmitter battery
has run out, contact your authorized Polar Service Center for a replacement transmitter. Polar recycles used transmitters;;;
Dec 28, 2013 | Polar F6 Wrist Watch
Sound cast will not play from my ipod by wireless green light on speaker blue flashing light in the transmitter
Usually this happens when you have a damaged power supply. Once you replace it everything goes back to normal. You can contact tech@soundcastsystems.com for support on this.
Dec 01, 2010 | Digital Media Soundcast ICT-111 iCast...
Where can I by replacement parts for my shure wireless handheld transmitter pg58
If you have a T2 transmitter, there is a place in Chicago that repairs them. Try contact them. Delta Audio, 773-764-3634.
Oct 14, 2010 | Shure T2 / PG58 Professional Microphone
Just purchased SBHS100AE-K rear speakers to connect to my SC-BT100. I want to connect them wired rather than purchase the wireless transmitter, but I can't figure out how to connect the wired rear speakers...
This unit is not as flexible as traditional receivers are as far as speakers are concerned. Speakers are labeled and *must* be connected to the correct speaker terminals.
Upon reading the manual - it is quite apparent that the only provisions for rear surround speaker connections is <i>only</i> via the optional wireless transmitter / receiver hardware. The optional digital transmitter is connected via a proprietary plug on the rear of the SC-BT100. The optional receiver amplifies the received signal and passes it to the connected surround speakers. I would bet that there are no provisions for amplifying a surround L and R speaker channel inside the SC-BT100, and that it only provides a low level (like a "tape out") or un-amplified signal to the transmitter plug. Even if you were to manage to get the surround speaker connections made up there - you would not be able to hear anything from them - as there is no amplifier. The amplifier is contained in the wireless receiver, and is largely why it requires a connection to house current.
Unfortunately, I doubt you'll find a way to listen the surround channel audio from the SC-BT100 without the optional transmitter / receiver and the integrated amplifier.
You can review the manual like I did here:
http://service.us.panasonic.com/OPERMANPDF/SCBT100.PDF
I hope this answered your question.
Jun 11, 2010 | Panasonic SC-BT100 Theater System
How can i make a simple wireless speaker ?
There isn't anything too simple about wireless communications. First you need a transmitter. Your headphone output would be a likely source for your transmitter. Once you have that in place you will need a receiver of the same operating frequency as your transmitter. The receiver will demodulate the signal and you will be left with a low voltage audio signal which would then need to be amplified. Amplifier power gain would be dependent upon a few things. Size of speaker, output power desired etc etc. All in all it would be cheaper to buy one. Good Luck!
Feb 08, 2010 | Arcam AVR-200 Receiver
May 09, 2009 | Audio Players & Recorders
SHIFT-3-WIRELESS-INDOOR-OUTDOOR-SPEAKER
it comes with a transmitter. so put batteries in the transmitter and plug the included (white) audio plug in the back of the transmitter, (the hole that says direct input), turn transmitter on. Plug free end of audio cord into headphones jack on ur computer. put batteries in the speaker or plug it in to wall and push power button. push reset button on front of speaker and it should work. start playing music
Apr 09, 2009 | Audio Players & Recorders
Cylinder Like Sharper Image Indoor/Outdoor Wireless Speakers
ask google or you tube or go to car toys they can help. good luck
May 18, 2017 | Sharper Image SR277 Speaker
Wireless headphones
If you're handy, you could rig up a wireless solution to this. The problem is that you have two screens, each presumably playing a different movie. If you purchased an off-the-shelf wireless transmitter accessory, you could connect it to one of the screens. But then if you purchased a second wireless transmitter accessory, and connected it to another screen, you would need to make sure both wireless transmitters were operating on different frequencies, so that each person could wear a different pair of headphones and listen to their own movie. Hopefully this makes sense. You could use either an FM Modulator to do this, or an Infrared Audio (IR) transmitter... Remember, these units aren't like factory installed headrest systems; they don't have the wireless audio transmitter already built-in, so you can't just buy wireless headphones and listen to them.
Aug 17, 2007 | Venturer PVS62911 Car Video Player
599 people viewed this question
 Grubhead
Grubhead
