Question about Sharp MX-2700N Color Copier
Sharp mx-620 u copier - error code h4-00
I tried p * c * 14 start but it restart after restart it take long time for warming up but after taht it show the same issue again please help my email is : abdul19@email.com
007tech
  • 95 Answers
SOURCE: system error H4-00
H4 indicates a heating problem in the fuser. The roller never reached a specific temp. Make sure the fuser is free of any left over paper pieces (maybe from a paper jam). Check to make sure its clean.
Try reseting the the error in service mode.
To enter the test command mode, press the keys as
follows one after the other :
[#] key [*] key [C] key [*] key then enter 14 and press start/copy key. this clear error counter. make sure to restart copier afterwards.
Posted on May 20, 2009
  • 208 Answers
SOURCE: cant get rid of blinking error message, nothing works
  1. Find the pink Clear button on the Control Panel.
  2. Find the button below the word Auto. Under image quality
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.It may be clear Copy quality, or image quality
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Dec 05, 2007
  • 24 Answers
SOURCE: Sharp MX-2300N Reset
Type in "p" "*" "C" " *" (that is p button, star button, p button, star button.) the machine will go into sim mode enter 14 then press execute which appears on the lcd and the yes to confirm, then press CA and the machine should turn off then back on again
Posted on Sep 12, 2008
  • 148 Answers
SOURCE: Sharp AR C160 - Error H4-00
The thermistor inside of the fuser needs to be reset before you can clear the code. If you remove the top cover of the fuser the thermistor is located on top of the upper fusser roller. It should be reset able by pushing in. Then you put in the reset code. you may want a tech to look into what caused this.
Hope that helps...
Lbcoaster
Posted on Sep 16, 2008
007tech
  • 95 Answers
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Posted on Apr 12, 2009
What causes error code E7-14 on a Sharp MX-M363N?
Haven't come across that one before:
Trouble content
Detail SCU
Cause SCU PWB trouble.
Check & Remedy Check the SCU PWB.
Replace the SCU PWB.
You could try resetting the machine:
START (Copy mode)
Press the Program key.
Press the asterisk (*) key.
Press the clear key.
enter 14, execute
Cheers
Andy
Jan 20, 2017 | Sharp Mx-M363n Copier, Printer & Scanner...
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
What does error code h3-00 indicate?
Sharp ARM 550/620/700 Reset Machine with Error Code ...
? 1:26
www.youtube.com/watch?v=BXs8PmMXFtk
May 5, 2011 - Uploaded by Thomas Trumpler hi thmas please tell me how to clear sharp mx-m620n copiermemory chip to use it ... How do I clear error code h3-00 on mysharp mx--453.
Sep 30, 2015 | Sharp DX-C401 Color Copier, Printer,...
Sharp mx 2300N error code H5-01
http://www.copytechnet.com/forums/sharp/76512-sharp-mx-2300n-error-code-h5-01-a.html
Feb 15, 2015 | Sharp MX-2300N Color Copier
MX-M700U
This is a low fuser temperature error. Normally it can be reset by doing the following...make sure it's in copy mode:
pound, star, C, star
14, start
execute
once machine restarts the code should be gone. if not, and you're in Houston, we can get you fixed up.
Skelton Business Equipment Houston Copiers
Jun 11, 2014 | Sharp Maintenance Kit 1 Mx-m700u Mx-m700n...
How to clear an service error code on a sharp printer?
try turning the machine off then on. if that doesn't work, from copy mode type # * C * to go into service mode (test: enter a simulation). Clear codes 14, 15, 16, 17. type the number then hit the start key. then CA to reboot, you must try the codes on at a time. Please report what your error code was.
May 29, 2014 | Sharp MX-3501N All-In-One Printer
SHARP MX-3100N CODE E7-06
MFP -Image data decoder error
Try to clear code. enter sim with program key- asterisk*-clear key- asterisk*(P-*-C-*) enter sim 14 print key execute yes clear all machine will reset. if code comes back it is not just not a fluke and you may have another issue.
Aug 28, 2011 | SHARP MX-3100N
I got call for service code: h5-01 I already took 3 papers that were jam but still the error code are still there. Please help... Sharp mx-3501n
press these keys
#, *, c, *, or
#, *, c, #
if input correctly copier will ask for simulation code
type in 14 then start
01 then start
if it ask are u sure after inputing 14 then start hit yes or 1 for yes or execute. copier will restart. all will be fine untill the next three jams
Jun 11, 2010 | Sharp MX-3501N All-In-One Printer
H2 00 problem
Try to reset the error code by pressing these buttons :
[#] [interupt] [c] [interupt] [1] [4] [start/copy]
If the error code still exist check the thermistor and it's connection and reset again.
May 21, 2009 | Sharp AR-275 Copier
Sharp mx 2700n how to go SP mode and i get error code h5.01 how i solve this problem
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
You may have to have a tech look into why this is jamming...
Hope that helps
Lbcoaster
Dec 23, 2008 | Sharp MX-2700N Color Copier
Sharp MX-2700N Color Copier Logo
231 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
