Question about Intertherm Heating & Cooling
I just purchased a home built in 1981 - it has intertherm heaters thru-out - 3-in floor models, 2-in wall (little - bathrooms), and 6 baseboard EBH - the little ones in the baths do not work at all - can not find parts for thermastats, and the baseboard ones all have the knob on side of units with OFF - 1-5 - no matter what number you set it on, you are blown away by the heat - can not control the heat - and can not find any replacement parts.
    New Friend:
  • 30 Answers
INTERTHERM parts can be purchased through a local american supply
Posted on Oct 30, 2008
Where can I get a blower motor for old Intertherm UCG-1000-7 baseboard heater?
I also have a UCG-1000-7 heater from 1978 in the bathroom next to the floor. The last two nights have been quite cold for our area and for some reason the unit comes on once about 3:30AM even though it's turned OFF. We then turn it on to full then back off and after cooling down it shuts off ok. We pulled it out and opened it up. All looks OK except for 38 years of dust which was extreme. We dusted good and put it back in the wall to see if that helps. Any ideas why this may be coming on in the middle of the night? Thanks for any help. You can also email me at pismodise@gmail.com. my name is Bill.
Oct 07, 2013 | Heating & Cooling
I need to wire a remote thermostat to my electric wall heater in the bathroom. Not sure if I run the wire from the panel to the heater first or to the remote thermostat then the heater.
Run the wire to the thermostat then to the heater
BASEBOARD WIRING WITH A SINGLE POLE (2 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLY
BASEBOARD WIRING WITH A DOUBLE POLE (4 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLYdennis675_0.gif
Jun 21, 2011 | Heating & Cooling
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
We have a NELCO baseboard electrical heater, circa 1970s. We wish to remove it temporarily from the wall to permit new flooring installation under the heater. How are they attached to the wall?
It is attached with 2-screws or 2-nails. Depending on who installed it. I970's, I'm betting on 2-nails.
If you remove the cover, you will see where the nails are located on the inside back wall of the heater compartment and are attached to the baseboard. Be sure to turn the circuit breaker for the heater to the OFF position, be for attempting to unwire and move the heater. The circuit breaker should remain OFF until the heater is reinstalled.
Feb 28, 2011 | Fahrenheat FBE15002 Baseboard Heater
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Installing hot water baseboard heater
IF THEY COME WITH THE COVERS SET THEM AGAINST THE WALL WHERE TO BE INSTALLED, THERE ARE MOUNTING BRAKETS INSIDE THE WALL PLATE AND THE PIPE SHOULD SIT ON THE BRACKETS,, APROX 3-4 INCHES OFF FLOOR,
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
How far off the floor do i install hot water baseboard heaters
When you install the baseboard heater make sure the bottom part which is the all thing must sit over the floor and touch the tiles or carpet and use 2 or 3 wood screw against the wall. That is it and do not put any kind of paper or cotton or material things above the cover. Beside that you are ok and it is not like an electric wall heater.
Can't find replacement parts
Hi google intertherm furnace parts they sell parts on line you may find what you need on there
Oct 22, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
254 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
