Blower motor hums and gets hot .Motor and fan cage turn freely by hand. Thought it was the motor but after reading some of the questions could it be something else like the compaster(sp?). Help!
  • dyqhorses Feb 08, 2012
    This is a Furnace inside Intertherm Model mgh-075-abwn-05
  • dyqhorses Feb 10, 2012
    yes it does start if you give it a spin, Now my question is where is the capacitor?
    Sergeant:
    Champion:
  • 250 Answers
If the capacitor is bad the motor should start if you give it a twist by hand while it is trying to start.
Posted on Feb 09, 2012
4 Suggested Answers
  • 4 Answers
SOURCE: My squirel cage blower motor fails to start
Sounds like the start winding is shot. If the cap is good as well as the run winding but it will not start on its own, either the start winding or starting switch. In any event the cheaper thing would probably be to replace the motor. You could take the mottor to a motor shop and ask them if a repair would be possible or cheaper.
Posted on Jul 08, 2009
icemelts
  • 246 Answers
SOURCE: Coleman EB23B heat pump: Air Handler Humming Loudly, Blower Runs
If you're mechanically inclined - and you seem to be - with all the stuff you've already done - you should be able to 'fix' this problem - if you decide to after reading what I have to say.
First of all - the humming you hear is most likely your 'fan relay.'
The fan relay is nothing other than an electrical coil that is enerigized by 24 volts from the thermostat. Once it's enerigized - it snaps together a set of points (usually copper) which completes a circuit sending 115 volts to your inside fan motor.
These 'fan relays' are notorious for 'buzzing' especially when they are wore a little. If it was me - I'd change it out to keep from having to deal with it at a bad time, i.e. 4th of July - Labor Day or just a lazy weekend.
If you decide to do this yourself - just be sure you have all voltage off before you mess with it. The relay is easy to find - just trace the line voltage wire - from the relay to the motor or vice versa. It (the line voltage wire) might go to a terminal block (although I doubt it) in which case you just need to determine which wire on the terminal block goes to the fan motor. In any case the relay will probably be black and it will have 4 wires going to it. 2 of the 4 wires will be the low voltage (24V) and the other 2 will be the line voltage (115 volts).
When you remove the relay just be sure you label all your wires so you can replace them on the new one just like they came off the old one. Usually the low voltage wires will go to the terminals marked 'coil' and the line voltage wires will go to terminals marked line but not always. The low voltage wires may go to numbered terminals that has a picture of a coil and the line voltage wires will go to numbered terminals that show an open wire connection.
Try and get an exact replacement but if you can't - have the parts man explain to you (if need be) which are the low voltage terminals and which are the line voltage terminals.
You'll probably have to go to an Air Conditioning Supply House - I doubt if Lowes or Home Depot will have the relay - but hey - it's 2010 - they might have it. Might be worth a try.
Also - if you have a buddy or relative in the AC business you might see if he/she would go by and pick you one up. Some AC Supply houses sell 'wholesale' to everyone but most - sell 'retail' to the general public.
So, if you can get it wholesale it will save you a few bucks.
Last thing... since I'm not there to look/listen to the buzzing - there's a small chance it could be something else - but I doubt it. Also, sometimes if you just 'tap' the relay with a screwdriver or pliers it might stop the buzzing - although I doubt it will stay quiet - it'll probably start buzzing again - but - then again - it might not.
Hope I've helped - and it's something different - get back to me.
good luck!
Posted on Jul 29, 2010
  • 1033 Answers
SOURCE: condenser is working but no cold air noticed
Hello, if you can give the blower wheel a push and it starts then you need to replace the capacitor on the unit since it is weak. If the wheel does not start spinning then the motor is bad and must be replaced.
Posted on Jun 27, 2011
GE duet electric dryer. Airflow is erratic/sputtery.
M Pandora,
The squirrel cage fan would not have any bearings. When you turned the fan and you said it did not turn freely, you may have also been turning the entire drum because you would have been turning the motor shaft which then turns the belt and pulley. Not necessarily a bad thing. When you shut the dryer off, does it make a rattling noise as it comes to a stop? If it does, you may have a stripped hub in the center of your fan, and it will need to be replaced. Another way you can tell if it might be stripped is have someone watch the drum while you turn the fan, and if the drum does not move while you are spinning the fan, the hub is stripped. Those fans have a flat spot in the hub and they can get rounded out and that can cause the symptoms that you are describing. Hope this helps!
Feb 24, 2015 | GE Dryers
Amana heat pump emergency heat comes on but blower will not start. The call for heat comes in and the heating element(s) glow red for a few seconds and then there is a "click" and the heating...
Check the blower motor capicator. It should be mounted close to the motor with 2 wires to it (brown,brown/white).
Turn the blower on the thermostat and spin the squirrel cage by hand and see if it runs after by itself. If it does then definitely the capicator is bad .If it still doesn't run then check to see if there is voltage going to motor.
If thermostat is calling for fan and there is voltage present at the motor terminal then the motor is bad
Jun 01, 2017 | Heating & Cooling
Ruud achiever 10 inside blower motor burning
Check fan cage to make sure it turns freely. Check voltage to IFM make sure it is correct for the application. Make sure the motor turns the fan cage in the correct direction. IFM will have high and low speed make sure when you change from fan on to auto that the motor changes speed. If you have an amp draw meter check to see when running the motor pulls the amp load it is rated for. Recheck all wiring.
Feb 29, 2012 | Ruud Matching Split Air Conditioner
How to get to dryer drum. GE mod#dbvh520ej2ww
Hello there and welcome to fixya
The most common problem with these are the motor or the motor bearings or rollers
and next is clothes getting caught between the drumb and the shell of the unit
Here is some troubleshooting help for you listed below
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor
Dec 15, 2011 | Whirlpool Dryers
WHEN PRESSING START UNIT JUST HUMS
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Nov 26, 2010 | Amana Dryers
My outside unit is working but it doesnt seem that the inside unit is blowing or working. It just hums and shuts off. Model is Gmp100-5. Is the fan/blower motor gone? Where can I find the part?
Hi, if the motor hums that tells you there is power to it already. Take a look at the run capacitor mounted on the side of the blower housing. Look it over for signs of oil leakage, swollen out of shape. Its more then likely a 5 microfarad UFx 370volt run capacitor depending on the size of the H.P. of the motor. Like the other fellow said, you can spin the wheel/cage to make sure the bearings are not froze up. Most blower motors are air-over motors and are oil type bearings. You can remove the run cap and take it to any appliance parts house to have it checked out with a ohm meter before you buy one. That will rule that out. More then likely, you have lost a winding in the motor it self and will need to have it replaced. Its either a 2 or 3 speed motor, medium for heat and high for your a/c. Low is extra. For about a $1.15 you can get a zoom spout oiler at the hardware store and remove the caps/plugs to put a few drops of oil on the bearings. This motor will get very dirty and dusty as it is where the return air comes back through your a/c filter. They do get hot and burn out due to this. Before I would go out and buy a motor if you are lucky enough to find one at a appliance parts house, I would oil the bearings if they are not sealed, look at the back end for a plug or cap first, and have the run capacitor checked for proper UF as it has to be with in 10% of its rated value. If this doesn't take care of it, I would recommend having a tech come out to install this motor. It is one of the most difficult to change if you have never installed one. Call around and get a estimate. I would charge you a flat rate of $175.00 complete with new run capacitor, not by the hour. It takes around 1 & 1/2 hours to do and have them clean the blower vanes while it is out also. The shaft size on the motor is 1/2"x6" long, maybe a 1/3 to 3/4 H.P., 1075 R.P.M.'s. I hope I have been of help and given you some direction. Please keep this in mind when rating me as I know you will be kind. Please keep me posted on the outcome by my user name below.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Jul 25, 2010 | Goodman GMS90703BXA Heater
Old GE Fan Motor
try national energy they are on line as well
Jun 04, 2010 | Goodman GMS90703BXA Heater
LG DLE5977W electric dryer hums when attempting to restart
This is usually the motor but not always. Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers, pulley, rear bearing, then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. You can also enter your model # for diagrams and illustrations at www.appliancehelponline.com
Mar 31, 2010 | LG DLE5977 Electric Dryer
Does the lakewood fan have a fuse that can be replaced?
No, it is either the speed control, capacitor or motor. You can get parts, if it worth your time, try nelsonappliance.com and part # LW007JRMOTOR
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 26, 2009 | Lakewood HV 18-c Floor / Box Fan
Hi there the main problem is the run capacitor on the side of the blower cage has gone bad.
But you have replaced that..
The Next Problem is that one of the magnets inside the motor had demagnetized and is not allowing the cage to freely start But makes since that you can hand start the motion of the motor
Need A New motor Sadly to say
But sometimes you can have them rebuilt for less than a new motor
Any other questions just ask
Bryan
Jul 08, 2009 | Goodman CKL42AR42 Air Conditioner
Heating & Cooling Logo
273 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
