Aspire 5738-6444 overheats
Overheats and shuts down constantly, creating problems when rebooting. The vents in this model are so minisucle as to be a JOKE.
  • 355 Answers
You have to open your laptop and clean all dusts sticked to the heat sink. this will solve your problem temporarily.
Posted on Feb 08, 2012
4 Suggested Answers
romsky79
  • 822 Answers
SOURCE: Acer Aspire 5738 - Speaker Issue
try to uninstall audio drivers and restart system. then you must re-install again the original audio drivers.
Posted on Aug 15, 2009
WinstonMeyn
  • 141 Answers
SOURCE: I'm trying to turn on the number pad on my acer
Press the num Lock button which is above the number 7 and turn on the num Lock to use the Number Keypad on the keypad
Posted on Jul 11, 2010
aldwinweng
  • 103 Answers
SOURCE: My acer aspire 5738 won't start up it says
sounds like your unit did not detect the hard drive/hard disk.. try to enter on BIOS setup and check your hard drive or else you have a corrupted system.
Posted on Oct 12, 2011
Acer aspire 5517 powers up sometimes and not others. Randomly shuts down.
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Nov 27, 2012 | Acer Aspire 5517 Laptop
Aspire Aspire SA10 is shutting off abruptly. I have to remove the power cord for 5sc then plug it back in, but this cant be good, help please
Nov 07, 2012 | Acer Aspire Computers & Internet
Affinity dryer model FAQE7001LW0 OVERHEATS AND SHUTS DOWN
Therm o resistor or air ducts venting needs clean out
if not that change main board
Aug 13, 2012 | Frigidaire Affinity FAQE7001LW Electric...
Computer won't boot
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 26, 2012 | Computers & Internet
Suddenly shut down
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Jan 20, 2012 | Acer Aspire 5630 Notebook
My acer aspire 6920g will shut down automaticly when i want to log in to my system, after the boot menu the cooler is turning off for 1 second.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Apr 26, 2011 | Acer Aspire 6920 Notebook PC
ACER Aspire 5720 overheat problem?
Try to keep as much ventilation under the laptop as possible.
You can pick up a can of power spray and blow out the unit yourself or have a pro. do it for you.
Dust and lint play a deadly part in overheating with laptops.
Walmart has Ventilation trays in which the laptop sits and is cooled by forced air from underneath.
Make sure the direction of air flow is the same as your laptop.
You dont want to push air into a output vent.
Aug 30, 2009 | Acer Aspire 5720 6497 Laptop
My acer aspire 5315 overheats constantly. i do not put it on my bed, i do not put it on my lap, i dont even rest it on the table in case it overheats straight away, i make sure theres plenty of air flow...
Try cleaning the air vents wit ha compressed air can. If no joy check for a BIOS update on with Acer. If all this does not help may be the sensors or the fans are failing and will need replacement.
Aug 19, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 3000 notebook constantly overheating and shutting off
purchase what they call a chill pad... it plugs into a usb port on the laptop and has two fans... you set the laptop on top of it....
Robert
Jan 05, 2009 | Acer Aspire 3000 Notebook
Overheating problem, I think
its unusal for an Acer to overheat unless the vents around the fan and extractor vent are blocked, or the fan is not coming on, it should fire up every so often unless there is processor hungry programmes working, so hoover around the vent areas gently. The problem may also be down to a corrupt driver, so to get a clue as to what may be causing it, go to start>all programmes>control panel>administrative tools>event viewer, then look in the left hand list and click on each category and look for any red crosses that appear in the list on the right, if so right click on it select properties and you can then go to microsoft for a possible answer to the problem
Jul 16, 2007 | Acer Aspire 5004WLMi Notebook
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
