Question about Kitchen Ranges
My admiral stove stopped working, the elements just arent on anymore, but the stove has power because i plug my toaster into the socket on the stove and it still works, and everything else in the kitchen is fine
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
First thing is to check you r circuit breaker,is it an electric range ??? or a gas stove with electronic iginiton???, if its a full electric range then youll have a double breaker powering your unit, and its possible that one of the breakers tripped, allowing only half power to the unit.if its a gas with electronic igniton then slightly different matter and then i would ask of the top elemnts will light with match and perhaps theres an issue with the electronic spark switch
Posted on Oct 23, 2008
Why did it suddenly stop working?
The Auto Head Quartz Control or the quartz heating element failed.
Nov 29, 2015 | Bosch Styline Collection Toaster...
How come the burners on my general electric stove
Whenever I replace a block, it doesn't hurt to file or sand the male contacts on the surface burner. Be safe.
Sep 30, 2014 | Kitchen Ranges
Admiral stove is electric oven came on byitself also start beeping i unplug the elements but still the peeping
You have a short in the wiring. I would not reccomend using the unit til it is sorted out.
Feb 27, 2014 | Kitchen Ranges
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
Kitchen aid 2-slice toaster stopped working. It is plugged in to a good outlet.
The wiring is probably the problem. Check the connections. And then the elements . It may be burned in two.
Jan 27, 2013 | KitchenAid KPTT780ER 2-Slice Toaster
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
Admiral wont heat
Your breaker in the breaker box has a double pole breaker for the stove one breaker is shot so you still have 120volts which runs the lights 240volts for the elements.Turn main power off and replace the breaker. To verify for sure pull the stove out and unplug it check power at the plug you need 240volts at the plug. If i dont have a plug and wired straight in disconnect the wires and check the wires.
Sep 01, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Kitchen Ranges Logo
462 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
