Windows cannot start this hardware device because information [in registry] is incomplete or damaged [Code]
  • 355 Answers
You need to format your computer. Registry entry by manual is possible but is risky . so I personally recommend to go for a clean format.
Posted on Feb 08, 2012
hardkiss69
  • 43 Answers
SOURCE: UNABLE TO DETECT CD/DVD ROM
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Your registry might be corrupted (code 19)."
You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 28, 2008
  • 76 Answers
SOURCE: Pioneer DVDRW DR-KW08HB ATA Device driver issues
To me that sounds like something got corrupted with Windows, if you have a restore CD, or know how to reinstall your OS I would recommend that, AFTER you back up your files though as you will lose anything you had saved on there. But that could fix it, or it could be the drive is bad also.
Posted on Sep 09, 2009
  • 57 Answers
SOURCE: Windows cannot start this hardware device because
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolutions
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Here are some things that you can try to resolve this problem.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Revert to the most recent successful registry configuration
This content is designed for an advanced computer user.
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores all the registry information and driver settings that were in effect the last time that the computer started successfully.
For more information about the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 (http://support.microsoft.com/kb/307852/ ) How to start your computer by using the Last Known Good Configuration feature in Windows XP Edit the registry
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP.
Good Luck .. !!
Posted on Nov 22, 2009
SOURCE: DVD-RW does not work and is not recognized
Method 1 :
you must start regedit ( start -> run [See screenshots at the bottom] Type here: regedit )
search the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class/
search for "4D36E965-E325-11CE-BFC1-08002BE10318"
if you doesn't find anything, search only for a part of the string.
now search the propertys UpperFilter an LowersFilter and kill the value. If only one prop. is there, you must kill only the one value
Method 2 :
Watch this Youtube video,below is the URL
http://www.youtube.com/watch?v=UfPJTHpntYU
Posted on Dec 27, 2009
  • 214 Answers
SOURCE: Microsoft WPD FileSystem Volume Driver message
Hello.
It seems you have a faulty driver.
Method 1. Uninstall and reinstall the driver
Uninstall the driver from Device Manager and scan for new hardware to install the driver again. Here is how: First, please disconnect all USB devices and then perform the following steps:
1. Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
2. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
3. Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor's Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall . Follow the instructions.
  3. Open Device Manager, click Action , and then click Scan for hardware changes . Follow the instructions.
Method 2. Revert to the most recent successful registry configuration This content is designed for an advanced computer user.
With regards FIXYA team **Please post your feedback and Vote if the problem resolved as per your satisfaction**
Posted on Sep 27, 2010
I have Optiarc AD-7530B 8x DVD RW DL Notebook Drive Burner, the device status is Windows cannot start this hardware device because its configuration information (in the registry) is damaged or incomplete....
You need to delete the upper and lower filters on the said registry entry.
{4D36E965-E325-11CE-BFC1-08002BE10318}1 You can read the instructions complete with screenshots from the link I added. Cheers!
Fix Windows 10 DVD CD ROM Error Windows cannot start this hardware device...
Feb 20, 2018 | Computers & Internet
My lenovo 3000c series also have this problem, code:19. please advise.... thank you
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged or corrupted.
Probably data in the registry for the device and its driver have been damaged/corrupted
Try these options,
•Click Uninstall, and then click Scan for hardware changes to load a usable driver.
or
•Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back or restore to the most recent successful registry configuration.
Hope it helps.
Aug 12, 2010 | Computers & Internet
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you should uninstall and then reinstall the hardware device. (Code 19)
Try these options:
•Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back to the most recent successful registry configuration.
Hope it helps.
Jul 10, 2010 | Microsoft Windows Vista Ultimate Edition
Code 19 DVD DX not working
  • Open up your Device Manager where you'll see your DVD DX Hardware Device that no longer works correctly. Click it, and then click uninstall. Once uninstalled you can reboot, or click 'scan for new hardware'. Either way Windows will find your Device again and reinstall the driver and probably fix the registry entries.
  • If that does not work, reboot your computer holding down F8 and select 'Load Last Known Good Configuration' before booting into Windows again. It'll restore your settings back when it didn't detect any problems.
Apr 21, 2010 | Computers & Internet
I have HP Pavilion 9500,Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
hope this helps
please leave feedback
thanks
Robb
DVD-RW does not work and is not recognized. It does show up in device manager but the device status lists the following error: Windows cannot start this hardware device because its configuration...
Download and run a registry scan with ccleaner from here.
http://www.filehippo.com/download_ccleaner/
This will remove the corrupt registry entries. You will need to restart your PC afterwards and may get the "new hardware installed" message.
Dec 23, 2009 | Toshiba Satellite A215-S4747 Notebook
Good Luck .. !!
Nov 22, 2009 | Acer Aspire 5315 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
