Question about Car Audio & Video
I need to reset my cd code on my alfa 156 tspark
  • Car Audio & ... Master
  • 32,281 Answers
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Alfa service centre andget them to enter this code for you.
Posted on Feb 09, 2012
How do you change a fan belt on alfa 156
lossen the belt tensioner and pull the belt off
Mar 27, 2012 | Engines & Components for Alfa Romeo 156
Alpha romaeo 156 tspark will not start when hot
its a possibility that the starter solinoid is heating up and will not start car. try a new relay for the fuel pump which should be inexpensive and is a possibility. the fuel pump relay could be heating up and causing fuel pump not to come on. good-day! it could be just about anything. check out above first! the pump relay.
Oct 30, 2011 | 2000 Alfa Romeo 156
My Alfa 156 tspark has developed an engine fault over the last week. when starting the engine it seemed to only be firing on three cylinders then would correct its self after a couple of minutes. now it...
check the spark plugs and leads if OK.
check for any water in the spark chamber.
if any of these there might be an ECU fault.
My opinion.. download the alfadiag software ,and buy yourself a usb to OBD-II plug (which is located near the steering wheel) to connect to your vehicle.
It will save you a lot of money.
Oct 27, 2010 | 2000 Alfa Romeo 156
How do you reset alfa romeo 156 2.0 t-spark radio codes? Pleeaaase!
I just bought a '99 156 & had the same problem. As long as you have the 4 digit code then all you have to do is drive around for an hour (time the 60 mins!!) & providing you have switched the stereo "on" at the beginning the " - - - - " will appear on the front at 60mins. Then just type in the digits! The Alfa has this "anti theft" device on the stereo which also means every time the battery is disconnected you have to drive around for an hour before you do it again!
Feb 21, 2010 | 2000 Alfa Romeo 156
Orange warning light on Alfa 156 2.0 . Looks like an engine?
that would be the check engine light. if you live in the states autozone will scan the codes for free, if not you will need to go to an auto shop that has the tool to scan the codes. they should be able to tell you what is wrong.
Nov 23, 2009 | 2000 Alfa Romeo 156
Alfa romeo 156
There are 3 I think . The main one is behind the panel between the steering column and the drivers door. There should be a screw knob thing on the the upper side of the cubby hole. Undo that and the panel should fall down. The drivers door needs to be open though.
There are some main fuses in the little box on top of the battery and there are some more relays inside the glove compartment. You have to prize off a panel on the upper part of the glove box first.
Nov 11, 2009 | Alfa Romeo Cars & Trucks
I cant remove my front headrestson my alfa romeo 156 tspark
At the base where the head rest forks go in there's usually a side clip which you just push in. If not they may just need some brut force, some of the Recaro leather seats that Alfa used were like this! Hope this helps.
Rich...
Jun 20, 2009 | 2000 Alfa Romeo 156
Car Audio & Video Logo
75 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
