Question about Charging & Starting Systems for Ford F350 Regular Cab
94 ford ranger
Stop charging and got new alternater and now can;t get the truck to start
    Problem Solver:
  • 8 Answers
Is the engine turning over?
Posted on Feb 22, 2012
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Where is the in line fuseable link located on a 94 ford ranger 2.3 motor
    Alternator fuse link repaired my way. - YouTube
    ? 2:10
    https://www.youtube.com/watch?v=xgJQXKESDcI
    Dec 24, 2013 - Uploaded by Potskie
    I had the exact same situation with my ranger. ... I found thefuse links for the charge or alt output but not the one I ..... In line fuse, battery, or alternator? ... Of Key-Off Battery Drain (Parasitic Draw) - Duration: 18:14. by Motor Age.Missing: 2.3
    Fusible links and inline fuses? - Ford Truck Enthusiasts Forums
    www.ford-trucks.com/forums/885708-fusible-links-and-inline-fuses.html
    Sep 17, 2009 - Location: Kuna ID ... The PO had replaced one of the fusible links with an inline 30amp fuse. .... 81-F-150-Explorer is a splendid one to behold .... to charge the battery goes through that link when needed, and/or the battery to the other components when the engine is off. ... 91 ford ranger 2.3 daily driver 1994 Ford Ranger XLT 2.3L man. trans. - Ford Truck ...
    Jul 6, 2014
    86' Ranger cutting out!!! Fuel ? - Ford Truck Enthusiasts Forums
    May 10, 2012
    90' 302 fusible link for fuel? - Ford Truck Enthusiasts Forums
    Nov 2, 2010
    1988 ranger headlights won't work??? help - Ford Truck ...
    May 17, 2009
    More results from www.ford-trucks.com
    Missing: 94 images for Where is the in line fusible link located on a ...
Dec 30, 2015 | Ford Cars & Trucks
Why is 97 ford ranger not charging, with new alternater
Some units have a fuse within 30 inches of the Alternator. Another common problem is the small wire connector on the Alternator. While the plastic connector may look like it is attached in the seat of the Alternator, actually the metal contacts can push up through the plastic connector.
Check for power to the small Alternator wires. You need power to the small wires to make the Alternator work. The Alternator gets this power when the Ignition switch is ON.
Aug 10, 2014 | 1997 Ford Ranger SuperCab
94 ranger battery new alternator charging but wont crank
10 volts isn't good and if you have a weak connection, it won't turn it over. You should have 12+ from a good battery. Try cleaning the battery connections with a battery brush.
Jun 18, 2014 | 1994 Ford Ranger Supercab
94 ranger 4cyl stopped chuggg dead is it the
check the timing belt It may have broken
May 23, 2010 | 1996 Ford Ranger SuperCab
The ignition bell wont stop ringing
You need to unplug the door harness one at a time to locate which door is causing the problem. Once the door is located, you can replace the switch which is located on the lock mechanism.
Sep 29, 2009 | 1994 Ford Ranger Supercab
How to install Pwr Steering in 94 Mazda B2300 (same as Ford Rngr)
You'll also need to change the steering box. The stock axle should be okay to use. Be careful hooking up the new box and make sure it is centered, the same number of turns to the stop when you turn it left or right. Also make sure the pitman arm is the same length, on the Ranger, so the front end isn't out of whack, and check the clearance at the radiator and fan. Hope this helps.
Aug 09, 2009 | 1990 Ford Ranger SuperCab
2003 ford ranger battery light comes on
i think it is the alternator because the idiot light is connected to your regulator of your alternator. it is an indication that your alternator is not charging anymore.
tnx 4 using fixya,
drcool
Nov 08, 2008 | 2003 Ford Ranger Regular Cab
Charging alternater wire gets hot and archs
yep the regulator is stuck open replace it
Aug 26, 2008 | 1985 Ford Ranger
Charging & Starting Systems for Ford F350 Regular Cab Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
