Question about PSC VS1200 Hands Free
I have a PSC vs1200 scanner with OCIA interface, can I connect it to rs232 with an adapter?
I want use it with a PC, Do I need to configure serial communication in the scanner?
5 Suggested Answers
SOURCE: PSC Duet RS232 and USB
you need to buy a USB to serial converter, you can pick these up of ebay for about $5 or from GPS shops for about $30
Posted on Nov 08, 2007
SOURCE: PSC Duet RS-232 Handheld - help needed :(
I had the cable plugged in all the time. It turns out you need a program like Bill Redirect Pro. That did the job.
Posted on Dec 18, 2008
  • 51 Answers
SOURCE: Magellan SL Scanner/Scale PC Connection
first go to posspecialist.com ok get a usb sr232 converter than it will work but not in vista with xp ok
Posted on Sep 01, 2009
  • 1833 Answers
SOURCE: need driver for psc vs1200
Driver of these two products of IBM are very rare andcan be download from IBM only. To download psc vs1200 scanner, you need to sign in to IBM -http://www-947.ibm.com/support/entry/portal/Downloads?cm_re=other-_-suprcn-_-download. You can download 4610 shure mark printer driver from - http://www-01.ibm.com/support/docview.wss?uid=pos1R4000123. Hope this will help you. Good Luck.
Posted on Jul 20, 2011
How I can transfer my files from a Acterna 5100E OTDR to my laptop? It only has a standard internal flash drive and 9 pin output. I have the original software.
This devices interface is extremely old technology the 9 pin connector is most likely a rs232 serial interface . If your laptop has a 9 pin rs232 interface you may need a DTE to DCE adapter .
if you do not have this old rs232 port on your laptop I think this device a usb to null modem rs232 DB9 Serial DCS Adapter Cable with FTDI.
http://www.startech.com/au/Cards-Adapters/Serial-Cards-Adapters/USB-to-Null-Modem-RS232-DB9-Serial-Adapter-Cable-DCE-FTDI~ICUSB232FTN
https://en.wikipedia.org/wiki/Null_modem
from my reading of the manual a null modem may be needed
Nov 16, 2015 | Cell Phones
Driver for PSC VS1000
Hello, you asked the driver behind the times reader PSC VS1000, succeeded ?, you could send me, you have the pinout diagram of the serial cable rs232 db9?
hug,
john son
Mar 06, 2014 | PSC VS1000 & VS1200 Accessories - P/N...
Pin diagram for psc 8-0065-56 RS232 cable
Hello friend,
Despite seeing his request the RS232 serial cable pinouts 8-0065-56 is old, I wonder if you got the pinout of this cable and could send me, I have a big problem to solve and need this pinout if I could help will be very grateful
Hug john son
Mar 05, 2010 | PSC VS1000 & VS1200 Accessories - P/N...
May 19, 2009 | PSC Magellan SL
Driver for psc quickscan 6000 plus scanner
Hi!
Your PSC QuickScan 6000 should not require any drivers. If this unit plugs into your keyboard port, you should be able to scan a barcode and view the data results in a text editor, such as Notepad. This technology is called "Keyboard Wedge" and consists of a cable with three ends. The first is plugged into your hand-held scanner. The second and third are rather close together and are at the end of the cable. This cable is called a "Y" cable because it resembles the uppercase letter "Y". The bottom part of the "Y" plugs into your scanner, while the first upper part plugs into your computer. The second upper part of the "Y" should be a female plug, allowing you to plug your keyboard into it.
Now if you are using a Keyboard Wedge scanner with a USB keyboard, the female end of the "Y" cable would not have anything plugged into. Unfortunately, the scanner will most likely not operate properly if no keyboard is attached to the keyboard port.
I suspect you may have an RS232 or "serial" scanner. Does your scanner have a power supply that plugs into a standard wall outlet? If so, you may have a serial interface scanner. You could use a program called Com to Keyboard, which would convert RS232 or "serial" data into keyboard data. This is a free program, however, it is a resource hog and may slow your system down.
Feel free to call if you have any additional questions.
Good Luck & I Hope this helps!
-Dave
Dave Krause
Founder, Bluesky America's GetOpen.com
720.771.5194 Direct 888.7.GETOPEN Toll-Free
Mar 31, 2009 | PSC QuickScan 6000 Plus Handheld Barcode...
Problem with an usb-rs232 adapter
There is a good chance the weak spot is your serial to usb adapter. The signals are not compatible so the adapter has a chip and serial driver to convert the signals. If the adapter is not fast enough to convert the signals, you get an error. Here is some more info on adapters.
5 Steps for Selecting the Right USB to Serial adapter
Mar 04, 2017 | Televison & Video
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
Can't even start Metrologic voyager 9520
The MS9520 with RS232 needs the AC adapter plugged in to operate, the adapter plugs into the serial cable at the plastic "bulge". Cable part number is 53000c-3
Hope this helps, Terry @ TAG Technical INC
Mar 13, 2008 | Metrologic Instruments 9520 Voyager
Oct 15, 2007 | PSC Duet RS232 (4310001-1000001021)...
QS6000 Plus barcode scanner
you can not change a qs6000 from ps2 to usb by just changing the cable. the interface inside the unit needs to support usb, to check this look at label with the serial number and if it says "I/F=KBW/RS" your our of luck, and can only use ps2 or rs232. if it says "I/F=UW" then you can just scan 3 barcode from the manual to set the interface to usb
Aug 28, 2007 | PSC QS6000 Plus Handheld
PSC VS1200 Hands Free Logo
76 people viewed this question
Top PSC Computers & Internet Experts
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Sardar Yasir
Sardar Yasir
Level 1 Expert
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
