Question about Lexmark X Office Equipment & Supplies
What should I do with my Lexmark printer x3430? It will not print an entire article. It will print only one page.
I have gone to the "Control Panel" but I couldn't find anything that I thought would work. I am not very good at the computer so I need exact directions.I I sure hope you can help. Many Thanks butterfoss@peoplepc.com
  • Official Brand Answer
  • 3,344 Answers
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/AbnM39. Select your operating system, download and execute the file. After the install process, try to print again.
Posted on Feb 09, 2012
3 Suggested Answers
SOURCE: lexmark X3430
ihave windows 98
Posted on Aug 16, 2008
sgarrand
  • 25 Answers
SOURCE: lexmark x3430 ink cartridge?
According to Lexmark's site, it takes #24 or #24A.
Posted on Mar 13, 2009
How to fix printing problem
Check your default printer. The printer may not be set as default setting.
Dec 11, 2015 | Lexmark X3430 All-In-One Color Inkjet...
Lexmark x3430 will not print
1st of all remove the cartridge & again fix it. then Restart the printer
if problem still occur then you need to check hardware of printer.
How do i fix my LEXMARK X3430?
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
If that doesn't help, try to re-seat the cartridges by removing and re-inserting them into the printer. Make sure they are properly seated and secured.
I hope this helps.
Feb 17, 2012 | Lexmark X Office Equipment & Supplies
The same as everyone else on this site. My Lexmark x1270 All in One will print but will not scan. For three days i have removed, downloaded, removed, and downloaded the drivers from various sites to...
Are you using a USB connection? If you go to the site below at the bottom under Top Articles is an article on "Cannot Print or Scan Using USB".
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_US&locale=en&productCode=LEXMARK_X1270&page=product&frompage=null#2
You can also download updated drivers for yoru printer and operating system from this site.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 2470 only prints 1 page out of 10 pages!!!!
You may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 2400 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
May 09, 2009 | Office Equipment & Supplies
X3430 keeps printing test page every time I power it on
sounds like you need to do a complete clean and calibrate/alignment. that's what usually causes this issue.
Aug 07, 2008 | Lexmark X2500 All-In-One Printer
Lexmark x3430 printer
X3430 lexmark wont let me scan any of my pictures.
it says it's to busy.
Nov 27, 2007 | Computers & Internet
White lines appearing on print
White Lines on the Printed Page ID:193 null.gif null.gif null.gif
Clean the print nozzles as follows:
  1. Go to Start, Programs, Lexmark, Lexmark Solution Center (or Lexmark Control Program) and select the Cartridges tab.
  2. Select Cartridge Nozzles (or Clean Print Nozzles).
  3. Check the diagonal lines above and below the solid horizontal lines. The diagonal lines should be continuously solid from left to right, with no gaps.
  4. If there are gaps at the top that diminish at the bottom, run the Clean Print Nozzle page a few more times. If the gaps are gone, the Clean Print Nozzle page has probably resolved the problem.
  5. If the gaps still exist, you should unblock ("wick") the cartridges. See How to Unblock/Wick the Cartridge Nozzles.
    For additional help, refer to the following article: How to Clean the Maintenance Station .
Nov 10, 2007 | Lexmark X5470 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
