Question about Brother DCP-7020 All-In-One Laser Printer
Scanner locked brother dcp 7020 - Brother DCP-7020 All-In-One Laser Printer
  • 3 Answers
SOURCE: Brother DCP-7020 Drum problems
Open the front of the printer by pulling on both tabs at the finger grips on both sides of the front panel. The front panel will flip down. The drum and toner cartridge comes out as a single unit. It is black plastic within gray plastic and has a handle like grip in the middle. Grasp this grip and pull the unit up and out. It feels kinda funny the first time you do it and you may feel like it will break, but it won't. Pull it up and out in a kinda circular arc. Do not touch the drum. If you ever need to replace the toner cartridge, press on the blue tap and separate the drum from the toner cartridge. You will have to replace the drum after every five toner cartridge replacements so practice doing it now. Note the tabs and slots on the sides before separating the drum and cartridge. Align the cartridge into the drum carriage and slide it in until it clicks. To replace the cartridge assembly into the printer, angle the cartridge at about 45 degrees and rotate in while pushing. It should click into place. If the front door then closes properly, you should have it in properly. Practice a few times and you should be an expert. For paper jams, there are many places to check and they may not all give warnings. First pull out the paper tray and check for and remove misfeeds. Remove the drum cartridge assembly and described here and check for and remove any paper. Open the back cover and check for and remove any paper. Open the automatic feed and check there as well as lifting the cover where the scanning surface is. Look in the rollers for the automatic feed for paper pieces. The last place almost never gives you a warning. Reach into the slot where the paper exits after being printed and grasp the whole top cover. Lift upward and it will open about 4 inches. This is a good place where small pieces of paper or even whole sheets may get stuck. Clean out any dust while you are there.
Posted on Oct 04, 2007
I've just been fighting with the 'close the back cover' problem too. All the turning 'OFF' & 'ON' didn't work or opening & closing of covers didn't work. For all that I could see, all jammed paper was gone.
It wasn't until I took our the toner cartridge that I saw one last piece of shredded paper still stuck in there. When I took it out, everything finally worked.
Posted on Nov 13, 2007
ctf1800
  • 4402 Answers
SOURCE: brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
Posted on Dec 20, 2007
xptareq2000
  • 1447 Answers
SOURCE: Brother DCP 7020 Keeps giving me the "Drum Error" Message
Dear sir you see properly drum unite has a drum image sensor its demage so you change your copier drum unite, thanks.
Posted on Nov 22, 2009
xptareq2000
  • 1447 Answers
SOURCE: The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
How to replace paper feeding kit on DCP 7020
Most likely all you need is to clean the rubber feed rollers. Use alcohol.
Oct 24, 2014 | Brother Industries, Ltd DCP-7020 Laser...
Why won't Brother DCP 7020 Scanner connect to computer?
Try opening the Scan function from the computer and pull it from the MFP printer instead of being at the scanner trying to push it to the computer. Your Brother DCP 7020 would have to be on the same network and installed on the computer you are trying to use. Check your usb cable, Ethernet cable or if wireless - check the Wi-Fi connection settings (network name and correct passphrase).
Aug 30, 2014 | Brother Dcp-7020 All-in-one Laser...
Replacing pick up roller
you can safely replace the pickup roller without stabilising the document scanner and the laser scanner.
replacing the pickup roller is a relatively simple job that is easily done by someone who is good with their hands or with a little common sense.
here is a video showing the procedure
and a link to buy the part
Mar 28, 2014 | Brother DCP-7020 All-In-One Laser Printer
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 Scanner Lock Problem
According to Brother there is no switch for this model, you can just power off and on again. Sounds like it needs to go into the shop.
Jun 25, 2009 | Brother DCP-7020 All-In-One Laser Printer
SCANNING WITH A BROTHER DCP 7020
I cant find the machine DCP-7020 but I think this machine is the same with model MFC-7420 if you have the installer CD follow these steps:
For USB Interface Cable Users
For Mac OS® 9.1 to 9.2
& Software
1 Turn off and unplug the MFC from the AC outlet and disconnect it from your Macintosh, if you already connected an interface cable.
2 Turn on your Macintosh.
3 Insert the supplied CD-ROM for Macintosh into your CD-ROM drive.
4 Double-click the Start Here OS 9.1-9.2 icon to install the printer and scanner drivers. If
the language screen appears, select your language.
5 Click MFL-Pro Suite to install.
6 Follow the on-screen instructions, and restart your Macintosh.
7 Connect the USB interface cable to your Macintosh, and then connect it to the MFC.
DO NOT connect the MFC to a USB
port on a keyboard or a nonpowered
USB hub.
8 Plug in the power cord and turn on the MFC.
9 From the Apple menu, open the Chooser.
10 Click the Brother Laser icon.
On the right side of the Chooser, select the
MFC to which you want to print.
Close the Chooser.
The MFL-Pro Suite, Printer driver and Scanner driver have been installed.
To install Presto! PageManager, click the
11 Presto! PageManager icon and follow the on-screen instructions.
Presto! PageManager has been installed and the installation is now complete.
You can easily scan, share and organize photos and documents using Presto!PageManager.
Dec 11, 2008 | Brother DCP 7010 Multifunction Laser...
DCP-7020 start up confusion!!
Yes, you can get the power cord and the USB cable from any electronics store. For the USB cable, get one that is an "A-B" cable, e.g. the cable with a square head on one end and a rectangular head on the other.
The power cable should be a standard 120v cable with male pins on one end (that go into the outlet) and female on the other (that go int othe printer. A used computer store would have lots of those they'll sell you for pretty cheap.
You will need drivers and software to use the printer. This normally comes on a CD, but you can also download it online.
http://drivers.softpedia.com/progDownload/Brother-DCP-Full-DriverampSoftware-Package-Download-19399.html
Jan 31, 2008 | Brother DCP-7020 All-In-One Laser Printer
DCP 7020
If you are using non brother toner then that's the problem, if not it is the drum unit.
Dec 19, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
272 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
