Question about Vizio E322VL 32 in. LCD TV
My VIZIO E322VL turns off, what needs to be replaced?
When I Turn my TV the picture freezes, -then the sound continues for 1 minute w/the frozen picture -then the TV turns off -then the vizio logo blinks orange for 2-3 minutes -then the TV turns back on and is fine -it does this every time we turn it on. Is the bulb going out or?
  • ryan pahler
    ryan pahler Feb 08, 2012
    unpluging the TV doesn't fix it, if you do it will only speed up the process, bypassing the frozen picture with sound stage, upon plugging the TV back in it will continue through the steps, blinking orange for 2-3 minutes and then turn on and work fine, its like it has to warm up, but it does this every time the TV is turned on, even if it's 30 minutes apart from turning the TV on.
  • 43 Answers
Is the main signal board
Posted on Feb 08, 2012
chesterpendi
  • 195 Answers
SOURCE: Vizio E550VL won't turn on. The vizio logo just flashes orange.
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Dec 07, 2011
  • 4 Answers
SOURCE: Vizio m550nv led lcd tv. Problem began a couple
I had same problem. Unplug set for 10minutes then plug it in and let it go thru it's startup routine.
Posted on Jan 27, 2011
djchillsnyc
  • 151 Answers
SOURCE: Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
Posted on Jun 25, 2009
Sebin
  • 712 Answers
SOURCE: Model VS42LFHDTV10A. The TV is
This may be the problem of relay switches. It can be replaced to eliminate such errors.
Posted on Sep 11, 2010
SOURCE: Upon powering on my xvt47sv
The main board of this Vizio is known to fail after some use.
Its number is CBPF9D1KZ4 and as you will see it is hard to find, unless you want to pay $250 or so, which doesn't make any sense, at least to me.
Another common failure in those is the T-CON board, but from the sound of it the problem you have is in the main board.
Here's what I'd do if I were you: post a local ad on Craigslist, sell it to the highest bidder and use the money towards puchasing a new TV.
Not sure it's what you want to hear, but it's what I tell some customers and thus losing business that I couldn't have had anyway because it's insanely expensive and prone to more failures anyway.
If it helps you please vote for me - it helps me in turn :-)
www.coppelltvrepair.com
Posted on Jun 05, 2011
E322VL has power but will not turn on
its usually a capacitor on the power in circuit board..Little black canasters..you will notice the top of the bad one will be arched or swollen..sometime gell will be oozing from it also. its usually very noticeable when its swollen when compared to the others around it..
Dec 27, 2013 | Vizio E322vl 32-inch Lcd Hdtv With...
I have a Vizio SV470XVT1a. When I turn the tv on I may get a normal picture for a minute or two then the screen goes black or I will have a greenish or pinkish screen. I continue to have sound. Afte
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 10, 2017 | Vizio SV470XVT 47 in. LCD TV
Vizio e321vl screen
hi it sounds that you have a problem with the t-con board. but before you come up with replacement with new board tried to re seat the cable wire which may have loose connection.
Oct 11, 2012 | Vizio E322VL 32 in. LCD TV
I need the vizio manual for our new tv
Please try to view and save the manual to this site..
http://www.vizio.com/documents/downloads/hdtv/E322VL/663E322VL%20User%20Manual.pdf
Thank you and please rate my answer...
Nov 25, 2011 | Vizio E322VL 32 in. LCD TV
I have a tv lcd vizio and no turn on just the vizio lights
Good day!!!!
Nov 16, 2011 | Vizio E322VL 32 in. LCD TV
Son was using x-box with a Vizio 32" tv (E322VL) and the picture froze up but the sound kept playing. He could use the TV controls at all. Is it the TV or the x-box. Thanks for your help!!
Sounds like the x-box. Try hooking up a DVD player to it and see if you can get a picture from it.
Restart the x-box, and maybe get a can of air to blow the dust out of it.
Feb 21, 2011 | Vizio E322VL 32 in. LCD TV
Frame periodically freezes on Vizio 37'' TV
HELLO to the guy saying hello ... I am on cable and have the same freezing problem ... so take the attitude and shove it!!!!!
Dec 17, 2008 | Vizio L37 Television
Vizio E322VL 32 in. LCD TV Logo
1,031 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
