Question about Sony Cyber-Shot DSC-F717 Digital Camera
No display on LCD
So it switches on, the menu appears on LCD screen but then its just a black screen - the lens cap is definately off! When trying to take a picture, it just appears black. Old photos display without any problems. Will be 3 years old in September. Have camera insurance but does not cover mechanical/electrical problems.
  • Ellil Satchi Aug 04, 2006
    Found solution - fault with CCD chip!
    Contact Sony call centre for free repair - 08705 143 480
    Have a look at:http://www.livingroom.org.au/photolog/ne...
Send it back to sony centre by getting an repair fill-out sheet of the sony website it is because the chip has malfunctioned lots of them are doing this
Posted on Apr 11, 2007
  • 89 Answers
May be the lens block or CCD can be defective. Call the nearest service center and we can only assist in spares and service manuals.
Posted on Feb 01, 2007
I have a canon t3i. The menu doesn't turn on when you turn on the camera.
The menu doesn't display when you switch on. You should get the settings screen appear. Once powered up just hit the MENU button
Mar 02, 2015 | Canon EOS Rebel T3i 600D SLR Digital...
Olympus e420 no live view black images
are the photos on the memory card? LCD could be shot or loose.
Mar 12, 2014 | Olympus Cameras
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
When the camera is switched on the lens goes in and out twice and then the message that appears on the screen is 'turn the power off and on again'
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
May 09, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
LCD/EVF screen come on but is "snowy"
The problem is the lens is not opening, If you look into the lens you can see it is closed. This will require a trip to the repair shop.
Aug 16, 2008 | Kodak EasyShare Z650 Digital Camera
Camera lens
Does the camera take pictures?
If you take the camera near a lamp, can you just about see menu items on the LCD?
If so, it's possible that the backlight ribbon cable slipped out of the socket. To check open up the back of the case and carefully lift it up a bit just to see the ribbon cables. The narrow one is used for backlight. Try to disconnect it (open the tiny black flap in the connector) and connect it again (close the black flap). Have a quick look at the connectors on the ribbon cable and make sure they are clean. If it still doesn't work I'm afraid most probably you have a faulty backlight and will need to replace either the whole LCD (easy) or just the backlight (fairly fiddly job). In any case, you'll probably need a donor camera (ebay ;) to scavenge for replacement LCD.
Good luck,
Raf
Jun 17, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
No view on viewfinder or screen
If the lcd screen is black even with the lens cap off,the ccd base assy. needs replacing.
May 28, 2008 | JVC GR-D20EK Camcorder
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
No image displayed through viewfinder or lcd screen
could be one from a batch with faulty CCDs - check out this fixya link (solution 2) - http://www.fixya.com/support/t115316-canon_mv30 - it's copied from a page at imaging-resource.com - my MV600i was out of warranty and I sent it back to Canon at the end of 2007 and they got it going again free of charge within the week - unfortunately within weeks a very similar fault appeared and now they're trying to charge me for the repair !!! even though they say repairs are under warranty for six months -
May 23, 2007 | Canon MV600i Mini DV Digital Camcorder
Sony Cyber-Shot DSC-F717 Digital Camera Logo
102 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
