I have a Samsung LCD LN52B750 TV that i am replacing the main board and by doing so will the life of the TV be extended
  • 43 Answers
No , the lcd panel only last 60,000 , about 5 yrs
Posted on Feb 08, 2012
circuitworld
  • 335 Answers
SOURCE: LCD tv main/digital board
Send it to us and we will refurbish the board.....
e-mail me....circuitworld@comcast.net
Posted on Feb 11, 2009
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
SOURCE: I have a Samsung LNT4665FX with screen problems. I
To solve this type of problem, you need a piece of white chalk. Draw a line around the area where the set is at. Call a priest - and lay the poor thing to rest!!!! This isn't the first time Samsung has "dropped" junk onto its' customers. Their dvd players also had problems with their DSP I.C.s that would over heat and cause the video playbacks to "break up". Don't waste any more time or money on the product!!!!!
Posted on May 18, 2010
Delete software upgrade
If you've a latest software than the TV has now installed, you can do it by an upgrade with that software. As the process goes on, the older version will be deleted. You cannot delete the software by any way. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. http://electronicshelponline.blogspot.com/
May 10, 2013 | Samsung LN52B750 52 in. LCD TV
Turn TV on and off itself
There are so many reasons for this fault. From main power supply regulator up to display panel should be checked. This is a very skilled work, that a user can't do it. Contact any experienced service technician.
Sep 27, 2012 | Samsung LN52B750 52 in. LCD TV
Broken screen ln52b750
It is a fatal case as the screen which is called a panel unit is more than the set cost new, sorry but it is the end for this set.
Mar 18, 2012 | Samsung LN52B750 52 in. LCD TV
Spilled juice on front of Samsung LN52B750. Juice ran down into on/off control area. Now when it's turned on, no picture and channel display runs through non-stop on the screen. Any replacement parts?
HI,
To solve this problem you have to open your tv and using a hair dryer het the are of the control panel this will evaporate the moisture at the touch panle switches . After that reassemble the same and check. The problem will be cured.
ok
Dec 15, 2011 | Samsung LN52B750 52 in. LCD TV
Have a samsung LN52B750 that was on during a lightning hit. It gets power but it will not turn on. You can hear it clicking and the red led power light blinks 8 times. Help
The problem is that there is a burnt or bad capacitor on the power supply board of the television, it is not longer responding, while it tries to respond is when you get the clicking sound, therefore it is not going to power on until the bad capacitor is replaced.
Run a check on the power supply board, you will definitely see the bad capacitor, have it replaced and the television will turn on after reassembling the television back together.
Thank you for using fixya
Caseytech
Jun 29, 2011 | Samsung LN52B750 52 in. LCD TV
I have a Samsung LN52B750 that has a few Black and White lines on the right side of the screen going to the middle of the TV. I have the latest firmware update and have reset the TV and neither helped. It...
This tv has not gotton hit by any object or someone.Than it not the LCD panel screen problems.This cause it the T-CON decoding board is dead,that sit wright in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Oct 17, 2010 | Samsung LN52B750 52 in. LCD TV
Samsung LN52B750 LCD TV image smear/trailing
It transfer the universal image signal of TTL and LVDS signal to specific TFT LCD.
No offense, but it is a very complex subject.
Unless you're an EE.
Apr 09, 2010 | Samsung LN52B750 52 in. LCD TV
Only HDMI3 port is working
your input switcher board is bad.get it replaced.
Apr 06, 2010 | Samsung LN52B750 52 in. LCD TV
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
