Question about Kenmore Elite 45986 Front Load Washer
F-20 fault Flashing F-20; machnes paused
    Genius:
  • 1,028 Answers
Be sure pump is cleaned out
Posted on Oct 23, 2008
I have to turn power switch off then back on on my minimax NT , then service light will flash once blower comes on for 20 sec. then shuts off i have nothing. What part should i throw at it first
Any fault codes?
what about the flashing Red light?
how many times is it flashing quickly? It will pause between message/code of quick blinks.
To assist, more info needed.
Jun 02, 2015 | Pentair Minimax NT Heater
Keeps pausing
Hello Friend, this is Z. Thank you for your post!
If you are receiving an error code PAUSE, it commonly indicates that the door of your washer is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If these basic troubleshooting tips prove ineffective, try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your washer. If the issue persists, then your washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 18, 2014 | Frigidaire Affinity ATF7000ES Front Load...
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
My Power Chair is flashin three code
hi, if it 's stays three pause three then the error "Left Motor wiring fault" , now I suggest you remove the lead from the controller and refit check the connections are clean and tight.
Regards
Feb 17, 2013 | Pride Mobility Pride Jazzy 614 HD
Kudx03ftss2 clean light flashing
you have a heater fault if the light is flashing 7 times and then pause. to clear the fault perform a key dance of HEATED DRY - NORMAL 2 times, or HIGH TEMP - AIR DRY 2 times. this will start a diagnostic cycle that will clear the fault. if the fault continues to return you may need to call for service.
Jan 23, 2012 | KitchenAid Dishwashers
Led with number 9 displayed is flashing
LED 9 flashing can mean many things. Here is the list of "flashing codes" for the vostro 1510.
Keep in mind a flashing led is going to blink 3 times. for example,
number one would look like this:
On (solid lit). Blink, blink,blink (paused off) blink, blink, blink... (paused off), (then repeat)
1. ON-FLASH-FLASH = No Ram or ram not seen
2. ON-FLASH-ON = Ram has a problem
3. FLASH-FLASH-FLASH = Motherboard failure (replace board)
4. FLASH-ON-ON = CPU Fault/failure
5. FLASH-ON-FLASH = LCD detect failure/fault
6. ON-ON-FLASH = MINI pci card (controller) failure/fault
7. FLASH-FLASH-OFF = Keyboard fault/failure
8. FLASH-OFF-FLASH = USB FAILURE
9. FLASH-FLASH-ON = Video BIOS or BIOS issue
10. ON-FLASH-FLASH = Modem issue
Depending on the blinking code, you might just need to re-seat or replace your RAM or your CPU. But then again, you could have a more severe motherboard issue.
Nov 01, 2009 | Dell Vostro 1510 Motherboard System Board...
Error Message
what is the error message ?
machne can lock on to mush soap
May 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
Power Light Flashing - Machine wont Start - Whirlpool ADP5966
this is a fault code. it will flash so many times and then pause.
let me no how many flashes before the pause and i will tell you what fault code it is
Feb 21, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Machne beeps and all indicator lamps on right hand column flash
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 06, 2008 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
