Question about HP Compaq ProLiant 800 Server
Fan failure detected
Our fan (the one on top - part # 4715KL-04W-B46) sounds like a jet engine. We tried to replace it with a generic and got the message "fan failure detected" and the computer shuts down. So, we tried to put the old fan back in are we are getting the same response. What's going on??
  • 29 Answers
REPLACED YOUR FAN YOUR ISSUE WILL RESOLVE
Posted on May 05, 2014
Cannon ir 3025 photocopier displays error code 805-000.
E805
There is a fan error.
0000
Failure in heat exhaust fan (front) (FM2)
When lock signal is detected for 5 sec while the fan is stopped.
- Replace the heat exhaust fan (front) - Replace DC controller PCB
0001
Failure in rotation of heat exhaust fan (front) (FM2)
When lock signal failed to be detected for 5 sec while the fan is driven.
0002
Failure in heat exhaust fan (rear) (FM1)
- Replace the heat exhaust fan (rear) - Replace DC controller PCB
0003
Failure in rotation of heat exhaust fan (rear) (FM1)
there are 2 fame in the right door if you just look on the right door you will see 2 square vents
get in there and remove the fans and clean them out with canned air and apply a small amount of oil in the center then flick the fan to make sure it spins softly
reinstall and try it should fix the problem but please go ahead and order a new fan the part number is on the fan itself in the sticker it will say FK2-????-????
Oct 30, 2013 | Office Equipment & Supplies
Fan is extremely loud and sounds like a jet engine
there are 3 speeds for that fan sounds like its at the highest speed might be a relay problem or a temp sensor problem. and that fan isn't 800.00 dollars someone is kidding you call a parts place yourself. although there should be no reason to replace it this time
Apr 15, 2013 | Chrysler 2003 PT Cruiser GT
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
Jul 20, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Own a mitsubishi WD-52525 52 in. Rear Projection HD TV. Already been through the "blinking light of death" problem about 2 yrs. ago. Now have a steady red lamp light. Purchased new lamp, installed, and...
You have to take the TV apart. Pull the electrical chassis out and look for bad electrolytic caps on the boards. sounds like caps on the power supply board are bad. You can tell if they are bad by the fact that their tops are puffed up and they may or may not be leaking brown fluid. Compare them against the other caps on the boards and you will see how they have flat tops.
BUT before you take the TV apart you can check the error codes by pushing "menu" and "Device" at the same time and holding for about 10 seconds. The status light will blink two numbers. ex. one flash pause two flashes is 12 Error Code Probable Cause
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
or use the table below -
You can buy replacement caps from Mouser electronics online
Sep 11, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Check engine light came on, generic code po495 is the problem, which is cooling fan speed high, What is that really telling me?
had this problem, d
ealer wanted $700-800, to replace the fan clutch, bought one from advance auto$199 with a $30 discoun onlinet. me and a buddy did the work, paid him $60 for helping, the engine no longer sounds like a jet and it has constant power. problem no longer exist
Sep 11, 2010 | Chevrolet TrailBlazer EXT Cars & Trucks
Matrix 3000 "bottom fan fail" need a replacement fan. APC said they don't have in stock and is discontinued.
The APC Matrix-UPS 3000 Isolation Unit IU bottom fan APC part number appears to be 490-0006-A. There are three OEM parts that APC appears to have used:
NMB Technologies 4715KL-05W-B30-P00
Japan Servo CNDC24B7-34
Sunon KDE2412PMB1-6A
But any fan that has the following specs should work:
119mm x 119mm x 38mm, plastic (black) 94V-0, ball bearing, 2-wire, 24 VDC (9.0V min, 10V to 27.6V), 2800 RPM, 80 CFM min, 41 dbA max
Nov 17, 2009 | APC - UPS - Matix/Symmetra Enterprise UPS...
Mitsubishi tv error code 21
The service manual does not list an error code for "21".
Here are the error codes:
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
Sep 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD62526 - Error/repair code
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
remove the back and lamp (make sure the lamp door is on) turn the tv on and look to see if the fan is running (keep you hand out of the tv when doing this - as the lamp connectors are empty) if the fan does not start - replace lamp - the connector is located under lamp housing connector JA - measure the red wire and ground (any metal part) for 12v at turn on - if 12v replace fan - if no 12v check the power pcb
Oct 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Fan Replacement
If the fan spins freely the problem is most likely not the fan but the 8 pin smd Mos-Fet fan speed control current amp has failed. Not difficult to replace and are a common problem with these projectors.
Jun 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
HP Compaq ProLiant 800 Server Logo
108 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
