Question about Dell Dimension 2400 PC Desktop
Sonic RecordNow when I bought my dell computer it came with sonic recordnow drive and software. By mistake it was removed and I would like you to help me recover them and put it back on my computer.
    Sergeant:
  • 264 Answers
You should have received a disk with the computer for "Utilities", you will have this software on that Disk.
If you don't have that disk you may call DELL, they will send the disk to you at no extra cost.
Kindly rate the solution.
Posted on Oct 22, 2008
I need driver/drivers for Sonic Record Now Deluxe 7 so it can run on my new compuer Sandy
Sonic RecordNow Deluxe 7.3 is an old burn software which do not need any drivers to run the program. If your New PC is running on OS Win 7, the software is not compatible with Win 7 & Vista. The version 10 is compatible.
Hope it helps.
Oct 09, 2010 | Sonic RecordNow! Deluxe 7.3
Record Now Used Up All Hard Drive Space I have no more space on my hard drive how can i get rid of these temp files I have try this C:\Documents and Settings\username\Application Data\Sonic\RecordNow! but...
Do you not know the admin password to your OS?  That's a problem when your apps leave 8GB staging files around in their application files.
What's the problem with deleting the larger files in the directory you mentioned?   They all should be project files (hopefully some committed to disc successfully?  And no longer of use?)
Temp files are a common issue.  You can go into the settings for that application (RecordNow! Dlx.) and tell it not to keep all those files!  You can run a temp file cleanup utility for WinXP or Vista or Win7 or whatever....
Mar 11, 2010 | Sonic RecordNow! Deluxe 7.3
Doesn`t work all the time and makes a whirring noise, do i need to buy a new cd/dvd drive?
Before you beginTo determine if the CD or DVD drive displays on the My Computer screen, follow the steps below.
  1. Turn on the computer and remove any discs from the CD/DVD drive.
  2. In Windows 98 and Me, double-click the My Computer icon on the desktop. In Windows XP, click Start and then My Computer .
  3. A CD/DVD drive icon displays on the My Computer screen when Windows recognizes the drive. If Windows recognizes the drive, find and use a section below that pertains to the CD-writing software with the issue.
  4. If the drive does not display on the My Computer screen, go to the Microsoft support website and search for documents on missing CD DVD drive .
RecordNow by Veritas/HP/Sonic does not recognize the CDRW or DVD+RW driveIf RecordNow does not recognize the CDRW or DVD+RW drive, follow the steps below.
NOTE: Install any updates for the RecordNow engine available on the Sonic support web site (in English). Step 1: Uninstalling RecordNowTo uninstall RecordNow to reset the software and cause it to look for the CDRW or DVD+RW drive again, follow the steps below.
NOTE: The steps below pertain to Windows XP.
  1. Click Start and then Control Panel .
  2. Double-click Add or Remove Programs .
  3. Select Record Now and then click Add/Remove .
  4. Follow the on-screen instructions until the uninstaller finishes.
  5. Select DirectCD and then click Add/Remove .
  6. Follow the on-screen instructions until the uninstaller finishes.
  7. Remove any discs from the drives and restart the computer.
Step 2: Installing RecordNow using Application RecoveryAfter Windows restarts, install the RecordNow software to begin creating CDs.To install the RecordNow software, follow the steps below.
  1. Click Start , All Programs , HP Tools or Compaq Tools , and then Application Recovery .
  2. Click Application Installation and then click Next .
  3. Select HP Record Now or Sonic RecordNow! and then click Install .
  4. The installation automatically installs all files. Follow the on-screen instructions.
  5. Restart the computer after the installation completes.
The HP Record Now or Sonic RecordNow! software should now recognize the CDRW drive. Back to topRoxio (Adaptec's) Easy CD Creator does not detect the CDRW driveEasy CD Creator produces an error message when it is unable to detect the drive, such as: There are currently no supported CD Recorders available...To prevent these errors from occurring, follow the steps below.
NOTE: Windows XP is not compatible with Easy CD Creator 4 and earlier. If the HP Pavilion computer was updated to Windows XP from Windows 98 or Me, use the native CD writing ability in Windows XP or purchase and install CD writing software that is compatible. Step 1: Installing updates for Roxio (Adaptec) Recording Software If the recording software is from Roxio (formerly Adaptec), go to the Roxio software updates page (in English) to obtain any software updates that are available for Easy CD Creator (with or without CD Copier or Direct CD). If Roxio still does not detect the CDRW drive after installing the updates, continue to the next step. Step 2: Changing the CD drive letter back, if it changedUpgrading to Windows 98 or Windows Me can change the drive letter to a different letter and make the drive undetectable to Easy CD Creator. To change the drive letter back to F or another previously designated letter, follow the steps below.
  1. Right-click the My Computer icon on the desktop.
  2. Click Properties . The System Properties window opens.
  3. Click the Device Manager tab.
  4. Click the plus sign next to CD-ROM .
  5. Double-click the CD-ROM name and then click the Settings tab.
  6. Under Reserved drive letters , select M (or the previously assigned letter) from the drop-down list. Be sure that both the Start drive letter and the End drive letter are the same.
  7. Click OK , Close , and then Yes .
  8. Restart the computer. If Easy CD Creator continues to fail to recognize the CDRW drive, continue to the next step.
Step 3: Uninstalling Easy CD CreatorIf the above steps fail to make Easy CD Creator recognize the CDRW, recover Easy CD Creator by uninstalling it. Recovering Easy CD Creator resets the software and causes it to look for the CDRW drive again. Be sure that you have the last recovery disc of your Pavilion recovery disc set before continuing.uninstall Easy CD Creator, Step 4: Installing Easy CD Creator using Application Recovery
Jan 17, 2010 | HP Pavilion dv6000z Notebook
My RecordNow program does not open. Can you fix?
Sonic Record now will not open. Anuy ideas how to fix this?
Dec 22, 2009 | Sonic RecordNow! Deluxe v7 for PC
MY SONIC RECORDNOW 7.3 KEEPS TELLING ME THAT I HAVE FIONGERPRINTS AND DUST AND IT CANNOT READ IT. I HAVE CLEANED AND CLEANED. THEN ANOTHER TIME IT TELLS ME THAT I NEED TO INSERT A BLANK DISC. DONE IT OVER...
Try a different brand of DVD Media.Also if you tried to record on the disc and had an error or failed message the disc is now not readable or recordable.Why some brand of Media gives issue I don't know.Try using air to blow out your drive.Good Luck.
Sep 05, 2009 | Sonic RecordNow! Deluxe 7.3
Sonic programe wont work ,cant copy disc
Nothing can be done. my advice is to format ur system and re-install xp or vista and download softwares for free from here
Mar 18, 2009 | Sonic RecordNow! Deluxe 7.3
I may need a phone number to hp for record now of sonic which comes with!
you need to reinstall every software that don't run now after the reinstallation.
Oct 20, 2008 | Sonic RecordNow! Deluxe 7.3
Sonic RecordNow 7.3 problem
not sure on this one , but go on to control panel and then to add/remove programs and remove the program. then check in your documents if the program left any database files and remove them , then add the program through control panel, same way you removed it only this time you add a program.C what happens and giv me feed back
Jan 17, 2008 | Sonic RecordNow! Deluxe 7.3
Dell Dimension 2400 PC Desktop Logo
65 people viewed this question
Alun Cox
