Question about Kenmore 24032\24036 Top Load Washer
How to change belt on kenmore stackable washer
  • 262 Answers
SOURCE: plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Posted on Jan 04, 2008
  • 188 Answers
SOURCE: kenmore HE2 plus 11047532601
If it's stackable, you'll want to start by removing the dryer.
Open the door and remove the outer bellow spring around the bellow to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Remove the kickplate for easier access and to visually check for leaks later.
At the top/right of the bellows (close to the tub) loosen the bellow to tub clamp and pull out the bellow.
Install the new bellow starting at the top by aligning the marks. Work your way around until bellows is properly seated snug against the tub.
Replace the tub to bellow clamp and tighten it (make sure the bellow stays snug against the tub while tightening the clamp). Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet with the outer bellow spring clamp.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leaks. If all is well, re-install the kickplate and wash some laundry.
Posted on Feb 22, 2009
  • 188 Answers
SOURCE: kenmore washer agitator
Remove the agitator cap and the bolt in the middle that holds the agitator. Reach underneath the sides of the agitator and pull up. Try gently rocking it around as you pull, I'm sure it's going to be stuck pretty tight.
Posted on Mar 12, 2009
praky16
  • 744 Answers
SOURCE: Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
Posted on May 25, 2009
  • 25 Answers
SOURCE: my kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
Posted on Jul 16, 2009
Hi is it pretty simple to replace parts like BELTS. or. AXELS pulleys on a Kenmore stacked washer/dryer? and are there any TUTORIALS TOU CPULD RECCOMEND FoR DIY need fix dryer belt axel possible
YOU CAN FIND EASY HELP ON GOOGLE OR YOUTUBE , JUST WRITE FIX CHANGE BELT ON STACKABLE DRYER ETC
USUALLY U HAVE TO REMOVE THE TOP PANEL THEN THE BACK PANEL
Jan 02, 2017 | Kenmore Washing Machines
Need to replace belt
Search Results
    How to repair a KENMORE double decker washer&dryer ...
    ? 4:59
    www.youtube.com/watch?v=Rc_ZGugYBTY
    May 31, 2014 - Uploaded by MrProductionist
    How to repair a broken dryer belt from a Double Decker Washer and Dryer. ... I have a Kenmore stackable Washer-Dryer, and the dryer belt is ...
Oct 21, 2015 | Frigidaire FFLE1011MW White Washer/Dryer...
My kenmore stackable model number has been
Jul 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
hi..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Loose Belt Drive
Remove the rear cover on the unit and see if the belt is loose. It should not stretch more than 3/4" when you pull on it. There may be an adjusting bolt on the motor to tighten the belt. Disconnect power before working on the unit!! You should have an owners manual for this unit. Check it for further information.
Ray
Dec 11, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
52 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
