Question about Ovens
Ignis Oven Manual AKL876/01 - Ovens
Hi I have an Ignis built in oven model number- AKL907/WH which is now displaying "- - - c" and t won't let me press any buttons to correct it, the oven itself does not turn on, any suggestions please? No...
Sounds like a bad electronic control board. Proper replacement might require a service tech. TRY resetting by unplugging it from the wall. Give it a few minutes, then re-plug. Also look for any sort of reset, switch, lever or button.
Dec 15, 2013 | Ovens
Instructions for a ignis electric oven as there is no temperature guide or modes on front of oven
I don't see what looks like your model anywhere, or a manual for any model, or a company website, so if no one can help you try this.
The left dial could be- bake, broil, fan, convection cook, now the bottom pan should come out so you can see the bake element.
Turn it one setting and see what happens, either broil (top),,, bake (bottom), convection fan (bottom), turn and wait to see what happens.
Right should be temp, not sure if the dial has a stop or you can spin, but it at 12:00, put at 6:00 I say this maybe 300deg F.
Get over temp gauge (cheap).
If you don't get any help, then you need to try and see what does what and mark it down.
If you can't see top burn, maybe top pan come out so you can see it.
They get red hot, so you can tell which one turn on.
Sorry, can't find any info.
Apr 01, 2013 | Ovens
I need a manual for ignis oven akl446ix
The manual (user guide) is available to download at the following link -
Just type your model into the 'commercial code box' and select the language.
Jan 14, 2011 | Ovens
I had an ignis build in, single, fan oven, model AKL907/IX installed in January, worked fine now, switches off when the oven is on, beeps and then can be restarted if pressing the ok button, however the...
Hi i have the same oven, Ignis AKL907/IX. Worked ok for 12 months but now cuts the power in the whole house out when the cooling fan is engaged. Just out of warranty and call out fee is
Aug 15, 2010 | Ovens
I am trying to get an instruction booklet/manual for my Ignis oven Model AKL901/IX with no success please help!!!!!!! Have searched many websites and now very frustrated
I AM ALSO LOOKING FOR A USER MANUAL FOR THIS OVEN, THE ONLY SITES I CAN FIND ARE FEE PAYING. HAVE YOU MANAGED TO FIND ONE YET ?
Aug 10, 2010 | Ovens
Oven not working, is it the thermostat or element
This will almost certainly be the element and is fairly simple to replace.
Nov 28, 2009 | Ovens
Fan works but oven doesnt get hot
One of the switches looks to be a 5 position switch. 0=off, 1=Light, 2=fan
Feb 24, 2009 | Ovens
Faulty electric oven (Ignis AKL828/AV)
I think you will find that it is the oven element that has shorted, causing the trip to go. The fan will still work, but with no heat.
Remove inner rear panel of oven, there you will see the element.
Remove and replace.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Ovens
Ovens Logo
369 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
