Question about Maytag Refrigerators
Water under crisper drawers
Water accuulates every few days below crisper drawers
  • Maytag Master
  • 4,654 Answers
I am pretty sure you are having a defrost drain blockage problem. Most refrigerators defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section (depending on the style refrigerator you have).Click Here=> Leaking Refrigerators Just What may Be Happening
Much more on this page=> Leaking Refrigerators!
I willbe here should you have questions, Thank You,
Sea Breeze
Posted on Feb 09, 2012
SOURCE: water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Posted on Jun 24, 2009
  • 112 Answers
SOURCE: ice acculation under crisper drawers
No. There is, however, a drain hole in the back center that tends to get plugged. Remove the lower two drawers and see if it is plugged. It drains to a pan under the unitand behind the kickpanel
Posted on Oct 18, 2008
  • 82 Answers
SOURCE: Refrigerator has water under the crisper drawers
There is most likely a plugged drain in the freezer section. The easist solution can be to empty the refrigerator and unplug it over night. If this is not possible then the back or bottom should be removed to allow access to the drain and a hair dryer can be used to make defrosting go faster. still takes a while, if there is access in the back of the unit that can be the cause of the plug.
Posted on Jun 19, 2009
  • 121 Answers
SOURCE: my no frost is leaking water from under the
You have a clogged drain tube in the freezer . here is how to repairit. take off the ice maker if it has one. then remove the 1/4 ince screws in the back. the whole back panel will come off.depending on the ice build up you might have to defrost the unit. if you would like to easily fix it just unplugg the unit and let it defrost. defrosting will unfreeze the line. this will sovle you problem for a while but it will happen again.
Posted on Oct 20, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Samsun RS265LA Water is under crisper drawer
Sounds like the typical defrost condensate line is stopped up and every time your refrigerator goes into defrost instead of water following the drain tube to the pan below your refrigerator where warm air blows over the water and returns it back into the air inside your home. This is a common problem that happens. Sometimes just the refrigerator leaning to left or right will begin the problem. Other times the tube gets backed up because of slime an crud and begins slowing the drain flow down to the point it backs up and spills over into freezer or fresh food compartment. Every refrigerator is a little different so click here=> REPAIR OF LEAKING REFRIGERATORS and scroll down to near bottom of page. Read and watch the You Tube movie clip and other material and if you have more questions ask. You may need to remove the rear panel in back of the freezer compartment or if your brand has dual evaporators you may need to go into the rear of the fresh food compartment. Not every Samsung has dual evaporators. here is your Service Manual=> RS265LA It does appear that you have two evaporators on your model. Look this may take a wet and dry vacuum and Clorox with warm water and once the drain is cleared you will not need to do this often. On page 17 is a view of the two evaporators. Watch the movie at the link above and it will be so much easier. Contact me if you run into problems. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Mar 14, 2010
Water in left bottom crisper drawer
You need to get a replacement gasket for the make and model of the refrigerator, http://www.fixya.com/support/12355008-water_in_bottom_left_crisper_drawer
Jun 11, 2017 | Whirlpool Refrigerators
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
Our Maytag MTB1976HRW leaks water under the crisper drawer. The drain has stopped up before but if this is the problem how do we solve this without having to call a repair person?
Open the freezer compartment...
Locate screws on the back wall (from inside freezer compartment)
unscrew and open the back panel.
You will see a hole at the bottom which is the drain hole.
if you feel ice there... then that's the reason... the clog wont let water drain out and it accumulates at the bottom after a few days it leaks out of the fridge.
I used a hair dryer to unclog that hole and within minutes I could see water on the drying pan located below the fridge (which previously was dry)
Hope this helpout......
Jul 28, 2010 | Maytag MTB1976HR Top Freezer Refrigerator
Water dripping from freezer area down in refrigerator water collecting under crisper drawer.
This is most likely due to the defrost drain being restricted, see the link below and let me know if it helps.
Defrost Drain
May 20, 2010 | Refrigerators
Frigidare 1812 frig-water under crisper drawers
clogged drain line somewhere in fridge plumbing
Feb 21, 2010 | Refrigerators
Water collects under the veg tray on bottom of fridge
Good day,
That's a classic example of the drain system either plugged up or iced up.
Remove the rear panel in the freezer, and inspect the drain hole where the condensed water drains out of the machine. Must be blown out or de-iced. Service techs use compressed air tank with hose to blow out the dirt. You'll need to improvise. However...
There are a few models that let the condensed water run down the back wall of the fridge, under the crisper drawers and then out a drain plug.
Check for this first.
Nov 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 28, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water standing under crisper drawers
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
167 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
