Question about Amana 24 in. ADB2200AWS Built-in Dishwasher
Spray bars not working
I have taken it apart down to the impeller. there didn't seem to be anything cloged all the way up to the upper spray bar. ran it while empty on rinse cycle, opened the door, water was dripping from the top, lots of water. the lower bar is spinning, the middle and upper bar are not. the path way from the impeller up to the upper bar is totally clear. there is lots of water in the bottom while this test is being done. can't figure it out. please help. thank you ivan
tricked out
  • 46 Answers
SOURCE: Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Posted on Jan 28, 2008
  • 177 Answers
SOURCE: water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
Posted on May 13, 2008
  • 525 Answers
SOURCE: Washer hums on rinse cycle
It sounds as if you are using WARM water for the wash cycle since your complaint begins with the rinse cycle. The rinse cycle generally uses COLD water, so I must deduce that your washer is not filling up for the rinse cycle. The humming sound is likely coming from the fill valve being starved for cold water.
Investigate your cold water supply to the washer and if you have good supply, you may want to replace the fill valve.
Let me know what you find...Thanks for contacting
Posted on May 27, 2008
  • 110 Answers
SOURCE: Amana Distinction leaks
this is a very common probelm with AM washer you have a bad upper sping bearing and at this point you need to cut your loses and send this one to the washer graveyard because this repair in labor intense
Posted on Jun 01, 2008
SOURCE: won't drain or spin
Sounds like the lid switch which is only about 30.00 to fix if you do it yourself. It's a little difficult but it's much better than replacing or having someone come in and do it
Posted on Mar 11, 2009
Why doesn't upper sray arm work?
  • Improper loading or over loading of dishes and glass ware that blocks the spray arm from rotating; check your user's guide for proper loading methods.
  • the holes in the spray arm can be plugged from food particles or other debris, like coffee grounds; remove the spray arm and clean out the holes; run water through the arm to verify there is no blockage.
  • check to see if the spray arm became disconnected from the feed tube or the feed tube from the water inlet feed hose.; reconnect hose or tighten down on hose clamps
  • check for any filter blockages; remove food particles and debris
  • the tub itself could be under filling, because of a restricted water inlet valve; pour 1 to 2 quarts of water into the tub of the dishwasher and run it; if the performance improves, replace the water inlet valve with a new one; DO NOT try to repair the old valve- it will fail once it's taken apart and put back together.
  • the circulating motor drives a water pump that rotates an impeller, which creates water pressure to go through the washer arms and out the holes. The jetting action of the water pressure exiting the spray arm holes propels the arm to spin...if the water pump impeller is worn, damaged, or impeded by food debris, the cleaning action will be greatly diminished; inspect and clean or replace the impeller if necessary.
  • If the aforementioned trouble shoot and repair methods do not correct the problem, then a more in depth diagnostic check will have to be done by a qualified repair technician to check switches that controls the water/drain pump, (if it is a dual action model for example); to verify if the switch or the pump itself has failed.
Mar 24, 2015 | Dishwashers
Upper spray arm
Hello Alan - Will the spray arm rotate freely or is it damaged? If so, you might have to remove and replace the spray arm assemblies. The top spray arm typically starts to function when the unit is in rinse or wash cycle. If for some reason the top rack is not getting clean, there is a possibility that it is not working properly. The top spray arm is either blocked by pots/pans or not enough water pressure is being pump meaning that the flow of water is not making it to the upper spray arm. If you tap the delivery tube that feeds this nozzle and the water pressure jumps immediately, then the problem may lie with a faulty pump or impeller. Should all basic troubleshooting measures fail contact a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
Jun 24, 2013 | Frigidaire 24 in. FDB126RB Built-in...
Sim card slot stuck
1) taken apart and rebuilt cellphones and 2) dealt with hundreds of malfunctioning phones that didn't read SIM's, I'll give you some ACTUAL help.
1) remove the SIM and check for any missing pins in the slot. You can only see the first row of pins on the N1, but that's all you can see without taking the thing apart again. You should see 4 pins, but the one closest to the notched corner of the SIM doesn't really do anything.
2) If everything looks okay, reinsert the SIM, along with a couple pieces of paper. The idea is to press the SIM into the contacts in case the fit isn't as tight as before.
If you either see damaged pins in step 1 or step 2 didn't work, take it back to the repair guy. He broke it, he's obligated to fix it.
Auto Accessories
May 24, 2012 | HTC TyTN II Smartphone
I inherited a braun 4169 immersion blender and it seems that the previous owner did not realize it could be taken apart for cleaning! it is totally stuck together- how can i take it apart properly? I've...
see my solution, posted today, 3rd Sept 2010. if you are not pretty handy at fixing things then don't bother is my advice because even if you manage to get it working ok it still my be unusable.
Sep 01, 2010 | Robot Coupe MP450 Handheld Blender
M084600 Dynamite Bagless Upright Vacuum: loss of suction...
A few weeks ago I ran into the same problem, virtually no suction. First I replaced the bad belt (make sure you fit it right or it'll destroy the belt, luckily I bought 2!) and while the vacuum sounded more "alive" it didn't seem to pick up anything any better. The final solution was taking apart the entire intake port section down to the motor and getting the collection tube. It was filled with junk all the way up. I spent over an hour clearing out gunk and animal fur throughout the tubing. Putting it back together was a cinche because the entire vacuum uses one screw type universally. The whole process was pretty intuitive and its clear it's meant to be taken apart for just this purpose.
May 18, 2010 | Dirt Devil M084600 Dynamite Bagless...
Remove the Impeller on the motor of dishwasher
you can acess the impeller, by removing the lower spray arm, ther are 5 torx scrws holding the motor cover down, then from ther ther are 2 additional torx 15 screws covering the pump outlet and impeller housing, the impeller is spring loaded in place.
May 15, 2010 | Dishwashers
Upper spray arm failure
Easy to solve!
(1) Remove the drawers to give yourself room to work
(a) bottom drawer just comes right out -- but you knew that
(b) Carefully unclip small plastic retainer caps at the ends of the metal "glides" for the top drawer. Then slide the caps out of the glides. Then remove the top drawer.
(2) Unscrew the "gear-like" plastic fitting into whose hole you were sticking your finger when you felt that small cylindrical ring.
(3) Now that you've got access to the ring, the solution is obvious -- use it to snap the upper arm back into the gear-like fitting. When you're done, the arm will rotate freely in the fitting.
(4) Put everything back together and enjoy the fact that you didn't have to pay some yobbo $75 to come to your hous and do this for you!
(HINT: When screwing the gear-like fitting back into place, use the old machinist's trick of pressing gently and screwing backwards until you feel a click. The threads will now be aligned for you to screw things together the right way. If you do not do this, you might experience frustration reattaching fitting -- since the piece it screws onto is spring loaded.)
Dec 06, 2009 | Frigidaire PLD4555RFC Dishwasher
Upper Spray arms not spraying
Took apart again and found the stepping motor which diverts the water from lower to upper spray arms to be burnt out. I was able to manually set the diverter to the correct position so the dishwasher works but I am waiting for new parts to properly repair the problem.
Oct 09, 2009 | LG LDF6810ST Stainless Steel Built-in...
Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Apr 01, 2009 | Dishwashers
Upper dishwasher arm not spraying water
Have you looked at the spray arm fixing nut at the back top arm as this has just gone on my machine
Sep 27, 2008 | Dishwashers
Amana 24 in. ADB2200AWS Built-in Dishwasher Logo
42 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
