Ricoh Afico MPC 2500 SC220 - Office Equipment & Supplies
newport74
  • 58 Answers
SOURCE: sc491 error on ricoh MPC 3500
Sc 491 straight from manual
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
 High voltage leak
 Broken harness
 Defective drum unit or development unit
 Defective high voltage supply unit
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
Posted on Feb 26, 2010
  • 903 Answers
SOURCE: Ricoh afico 811 error sc689 and sc547
sc547 is a power supply error that can mean you have a faulty power supply. The service manual does not list an sc689, and it's not in the help desk support database either... are you sure that's the code that comes on the screen?
Posted on Oct 10, 2010
  • 86 Answers
SOURCE: Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
Posted on Jan 13, 2009
SOURCE: Ricoh afico 401
It is a cooling fan that has died.....I copied the following directly from the service manual. It's been a while since I've seen one of these machines, but the fan is either inside the rear panel, or accessible through either side (wherever there are vents in the panels basically). If you're at all technically inclined you can usually tell which fan it is by simply spinning it, and if it's not free, it is trouble...fairly standard fans, as long as you get the proper direction of airflow, and similar amps.
SC490: Ozone fan motor lock/Exhaust fan motor lock
-Definition- [B]
A fan motor lock signal is detected for more than 0.5 second from
either fan.
- Possible causes -
· Ozone fan motor defective
· Exaust fan motor defective
· Poor connection of the fan motor connector
· Something is stuck in the fan motor
Posted on Feb 12, 2009
goodgold
  • 389 Answers
SOURCE: Where do I get a manual for a Ricoh Afico 401
dalz_tech@yahoo.com <dalz_tech@yahoo.com> Aleksander Kondourov
http://startcopy.ru/shop/r_af470.htm
Posted on Mar 22, 2009
I need to setup scanner on my ricoh mpc 2500 to folder wont ping when i check connection so please help me
Of course you can use scan-to-folder on operating systems above win7!!! You just need a firmware update (NIB)
Sep 29, 2016 | Ricoh Office Equipment & Supplies
What will I do to Ricoh Aficio MP 3350B with an error code of SC220?
Ricoh Copier Error Code SC 220 is Laser Sync Detect problem. Check your manual and there is a fix for this in the menu.
Sep 30, 2014 | Ricoh Aficio MP3350
How to Fix led touch screen Ricoh aficio mc2500 with heat flame?
If you mean the Ricoh MPC 2500 there was a factory bulletin issued about the touch screen. Contact your nearest Ricoh dealer and provide the machine serial number to determine if it is one of the affected units.
Aug 13, 2014 | Office Equipment & Supplies
What is error code SC220
http://terraofficesolutions.com/forum/index.php?topic=50.0
Aug 03, 2014 | Ricoh Aficio 3352 Copiers
Ricoh aficio MPC 2500 sc202.
Very common problem. It's a short in the BICU that takes out the Polygon motor. Replace BICU, and most likely the polygon motor (again)
Nov 15, 2013 | Ricoh Office Equipment & Supplies
My Ricoh aficio 3800c keeps stalling with error code sc220-4. How do I fix it?
Hi. The SC220 issue is a known one on the 3800c. It's a firmware related problem, and the code, which points to the synchronizing detector boards, is erroneous. You can read more about it, and possible ways to avoid it here.
Updating the firmware to get rid of this problem is not an easy job.
Nov 07, 2011 | Ricoh Aficio AP3800C Laser Printer
Error code SC220 for ricoh spc811dn what do I do?
sc220 is a laser sync error. You'll probably need to either replace the laser sync board or the laser diode itself, so you may want to contact a local service technician, as both of these components are internal and can be slightly tricky to get to.
May 13, 2011 | Ricoh Aficio SP C811DN Laser Printer
Jan 13, 2009 | Ricoh Aficio 180 Laser Printer
150 people viewed this question
jasbo
jasbo
