Question about Mitsubishi WD-60737 TV
Bulb keeps blowing hours after I replace it - Mitsubishi WD-60737 TV
  • 77 Answers
Could be the main board power capacitors. You can pull the back of the TV off and look, you should be able to see them with the rear panel removed. If the back\top of them looks popped out then they're bad and need replaced.
If they're leaking liquid they need replaced. Also make sure to use gloves when replacing the bulbs, oils from your skin can cause hot spots and make the bulbs burn out quicker.
Posted on Feb 08, 2012
The lamp to my WD73C8 keeps burning out, what causes it to do that?
if your fingers touch the bulb glass when fitting
it can blow the bulb easy
use a tissue or paper towel
find out how many hours the bulb life is
Oct 22, 2016 | Televison & Video
My Panasonic PT-60LCX64 television keeps having a problem with temperature. Every few hours, the TV will turn off and the temp light will blink 4 times. It will turn back on if we give it a rest of 10
Sounds like a fan issue which is possiblt slowing down as it gets warm. I would try removing the rear cover and set a fan behind it blowing on the chassis and see if the set keeps running if so the fans would be suspect.
Oct 14, 2012 | Panasonic PT-60LCX64 Television
1998 Ford explorer keeps blowing the fuse for the right turn signal. Have replaced 3 times now but it only lasts about an hour before it blows again. Please help. Thanks. Dawn
check for a ground short, also check the bulb sockets that flash on that side of the
vehicle, one of the sockets could be bad
Nov 15, 2011 | 1998 Ford Explorer
2004 jeep grand cherokee laredo keeps blowing the fuse for the parking lights and taillights
If it "keeps" lowing the fuse, there can be only one reason for it...you "keep" replacing the fuse without diagnosing the circuits to find out WHY the fuse is blowing in the first place.
When a fuse blows, there is a reason for it. If you do not find the reason and correct it, the fuse will continue to blow.
Please also review this article: Where's The Fuse?
With all of that said, the first thing I would check is all of the light bulbs. Sometimes the bulbs get really hot and melt inside and it causes the metal contacts in the bulbs to touch each other and short the circuit out. This is especially true if you can replace the fuse and everything seems to work ok for a while. They will all work until the offending bulb gets hot and "POOF" there goes the fuse again.
This condition can be hard to diagnose since the short circuit usually goes away as soon as the bulb cools off for a few seconds. In cases like this, what I usually recommend to save time and money is to replace all of the bulbs.
If it is fuse #6 (15 Amp) in the Central Junction Block that keeps blowing, it only powers the tail lamps, licence plate lamps, front park lamps and the front side marker lamps. The cost of replacing all of these bulbs is a LOT cheaper than an hour of diagnostic time at most shops. If this does not fix the problem, then you will have to trace all of the wires going to all of these bulbs to find out which one is shorting and where it is shorting. This could turn out to be very time-consuming and expensive, but at least, you will have eliminated the likelyhood that it is caused by a bulb.
Oct 10, 2011 | 2004 Jeep Grand Cherokee
What causes headlights to keep blowing bulbs?I just replaced them and got about one hour of run time out of them.
When replacing a modern headlamp be sure not to touch the glass part of the bulb with your bare hands. The oil from your hands will ruin the bulb for some reason. Check to see if your lens assembly is letting water in this will blow the bulb instantly also.
Dec 02, 2010 | 2002 Kia Sedona
2002 montana headlight trouble
Make sure the headlamp assembly does not have water in it.This will cause them to blow.If there is water in it you should replace it.Good luck.
Dec 06, 2009 | 2002 Pontiac Montana
Installed driver side headlight worked, an hour later both main headlights went out, when I went to check lights noticed that there was another headlight behind a little chrome cover that was out, could...
reasons bulbs keep blowning.your head light bulbs is halogen bulbs.dont touch with bare hands.the oils on your hands will make them over heat and blow.so use clean gloves on your hands when replacing the head light bulbs.if all is good.check alternator out put.it could be overcharging causing too much current flow through electrical circuit blowing out bulbs.use a digital volt meter hook it battery with car running battery voltage should be 13.5 to 14.5 volts. if it is 15 to 16 volts too many volts.alternator is faulty.due to lock out features turn off radio before disconnecting battery cables so you wont lose radio playing code.
Nov 24, 2009 | 2004 Honda Accord
Why does my fuse keep blowing for my tail lights in my 96 plymouth breeze ?Every time I put fuse in it cut the lights on the fuse blows?
The fuse keeps blowing out because there is a short circuit. Check the tailight sockets for corosion. Is there a tow package wiring installed?
Jul 26, 2009 | 1996 Plymouth Breeze
Mitsubishi WD-60737 TV Logo
146 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
