Question about Harman Kardon Audio Players & Recorders
Sound won't come on with the tuner
I have a nuvo concerto and the sound quit working on the tuner but works throughout the home on CD. What could have happened?
    Top Expert:
  • Harman Kardon Master
  • 75,311 Answers
Hello
There ar two possibilites for thif fault, and both are related with its tuner circuit board. Either the tuner section do not get proper voltage to function, no tuning will be done or if the varactor diode that helps electronic tuning has got damaged. In both cases, no tunig will be done.
Posted on Feb 09, 2012
Nuvo Essentia won't power up
First, try unplugging all of the sound system and plugging the amplifier into an outlet on a circuit that was not changed by the electrical work. Also, plug an outlet tester into the outlet you were using for the amplifier to make sure it is correctly wired. If one outlet in a system has hot and neutral reversed and others don't, this could cause problems with some designs.
If you are lucky, dirty power from sparking inside the circuit breaker crashed the control circuitry in the amp, and it just needs a hard reset (power disconnect/reconnect) to be made functional again. In the worst case, something got fried and you'll have to use instruments to track it down.
Apr 23, 2014 | Nuvo Essentia Amplifier
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Nov 06, 2012 | Bose Lifestyle Model 5 Music Center
Blue screen. Won't get any channels, or picture. Tried programing. Didn't work
It sounds that the tuner is faulty. Befror confirm it, a through checkup is necessary. Seek tech support.
May 24, 2012 | Prima C2012 TV
I have a Nuvo Grand Concerto System (NV-18GM) that I am setting up. I initially plugged it in to 240V mains power before realising I had to reconfigure a couple of internal wires (switching from the...
If the main amp section does not have it's own fuses, then the fuse might have blown, because the amp has gone. However I think it is highly likely that you have taken out the main amp, especially if it is a single IC that does all the work. You should try and determine if the amp section is getting power before replacing it.
Mar 19, 2017 | Audio Players & Recorders
My Philips DCM230 home stereo system wont produce any sound. The CD is playing, the voulme is on, and the mute is off. What could be the problem?
Your output I.C. might be faulty. Output I.C. is the one converting the audio from cd's,tuner,auxiliary to sound which passes to your speakers.
Since your Output I.C. is defective then the unit will not generate any sound even your inputs(cd,tuner,auxiliary) is working.
It is quite technical so I've advice you to look for a qualified technician to isolate the problem and do resoldering also for some dry joints on the main board.Dry joints also will might caused for damaged a parts.
Thanks for using fixya.
Jan 05, 2011 | Philips DCM230/37 iPod Docking Executive...
The sound stopped working on my koss KS2503. Yesterday everything worked perfectly fine. Today there is no sound. Everything else seems to work. I checked all the connections and have had no success. Is...
unplugg your tuner from the AC wall outlet then check the setting on the tuner do not try to watch and listen to the tv only try to listen to the radio or a CD and select the right option on the tuner to do so. If you have sound on any of the functions....radio or CD/MP3 then the problem lies on the setting not correct for the TV/VCR/DVD mode.
Sep 12, 2009 | Koss KS2503 System
Serial codes for nuvo simplese
I asked Nuvo about this and they said that the RS232 port was never setup for control, it is only to be used for programming when they are initially setup by Nuvo.
I have codes for the Essentia and Grand Concerto that I have written but non for the simplease as Nuvo said it cannot be controlled.
Cheers,
Nov 01, 2008 | Nuvo Simplese D 4-Source 4-Zone Audio...
Nuvo NV-4A Keypad Flashing/Won't Work
I have the same problem. All keypads blinking in All Off. I changed the fuses on the Nuvo. No luck. Does anyone have a solution to this?
Jul 12, 2008 | Nuvo Simplese D 4-Source 4-Zone Audio...
114 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
