Question about Compaq Computers & Internet
Cd/dvd tray will not open on compaq desktop - Compaq Computers & Internet
  • 1,179 Answers
Hello there, I am the computer technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Paul Stanford.
Here is what needs to be done if the DVD drive is a normal 5.25" (inch) desktop drive.
On the front of the drive, below the tray front cover is a little hole.
This hole is the key to opening your DVD drive.
Bend a paper clip, so that you get a long length, about 2" (inches) long. Now push the paper clip into the hole and your DVD drive tray will open.
Caution: Do this when your computer is off and be sure NOT to use the LED hole!
Take care!
Posted on Feb 09, 2012
4 Suggested Answers
djicenova
  • 319 Answers
SOURCE: The cd tray on my compaq presario desktop wont close
The drive should be replaced. they are fairly cheap (like under 50 bucks) and simple to install. sorry about your untimely issue
please rate
Posted on Mar 03, 2009
benwabnick
  • 2404 Answers
SOURCE: HP DVD 635 - auto tray open
no ghosts, you either have something jammed up inside of the drive which is keeping the door from closing properly all the way or the door itself is defective.
Either way you would be better off replacing the drive with a new dvd-rw cause the drive would be up to date and the problem with the opening door would go away.
Posted on Jun 21, 2009
wiqi546
  • 1511 Answers
SOURCE: NEED DRIVERS FOR MY COMPAQ 5000 CD BURNER AND DVD,
you can download all the drivers and software for you pc from this link
Thnx you and i hope this helps
Please rate this solution
Posted on Jul 16, 2009
How to open the disk drive
Open the Computer folder in Start Menu, select the DVD Rom Icon, right click, select Eject. If a DVD or CD has exploded inside remove DVD Rom and open the DVD case. Sometimes if you open the front case door cover and access the DVD/CD drive door you will see a tiny hole to insert a open paper clip that will open the tray.
Mar 19, 2013 | HP Black Compaq Elite 8300 All-in-One...
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Dvd won't eject. It lights up flashing like wants to open. I tried to eject dvd every way possible ie., computer link, etc
All CD / DVD drives have a Eject Pin Hole. The only thing we need is a paper clip to use it
All we have to do is bend it at the first curve 180 degrees (straitening it out). Then take the second curve and bend it 90 degrees. Now we need to locate the Eject Pin Hole.
Laptop - Notebook CD / DVD drives:
The trays on laptops/notebooks are spring loaded, so all that is needed is to release the locking mechanism. You do not have to insert the paper clip as far as with a desktop CD / DVD drive, as you are not connecting to the gearing under the tray. Gently insert the paper clip into the Eject Pin Hole. Once you feel it make contact, gently push in and the tray will eject immediately. Once done, gently push the tray back inward until it locks back into place.
Desktop CD / DVD drives:
Gently insert the modified paper clip into the Eject Pin Hole until you feel it make contact with the gear underneath the tray. Firmly pressing inward, you will notice the tray to start to move out. Press inward until you have enough room to get your finger under the tray and then pull it out the rest of the way. If you can only get a small portion of the tray out, you can use the other end of the paper clip to gently pry open the tray enough to get your finger under it. Once done, gently push back the tray to the closed position. It will close firmly when the system is powered up.
Mar 14, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
CD/DVD burner in Compaq Presario 5010NX w/ VistaBasic Reads and any DVD but has problems with CD's. If I load a music CD, sometimes it will open right up and I can play the music. Most times it just...
Microsoft updates may not have the driver you are looking when it is searching for drivers. When you are in the device manager make a quick note to the name of the device and go to http://www.compaq.com/country/cpq_support.html
and see if you can match the device to the driver for your pc. If you are able to find the correct driver and install it and still receive the same results then the drive itself may have a problem.
Mar 14, 2011 | Compaq (CDD480172) CD-RW Burner
My dvd-writer/cd-writer combo will not open?
look a tiny hole in the front of the CD/DVD drive use a paper clip to pull out the tray, when you have the tray out use the EJECT bottom in the drive to close and wait 3 seconds and press again to open, do this at least 3 times.
Fosg2000
Feb 24, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Cd/dvd not responding to any type of cd
if dvd r/w drive is old then get a newer one from store and get fixed
if u get the problem in new one then if it is under warranty thea call the services center
if u get this problem otherwise do following:
open the dvd drive from your computer:
open the shutter of drive, shut down the computer while the cd/dvd tray is out
unscrew the drive and open it
1. seethe cd/dvd rotor "called chulk"
2. have the cello tape on chulk and remove the dust from it
re close all
start the computer
enjoy else change the drive
don't forget to give me all thumbs
thanks have a nice day
Jan 25, 2010 | Compaq Presario S6300NX PC Desktop
NEED DRIVERS FOR MY COMPAQ 5000 CD BURNER AND DVD, TRAY WILL NOT OPEN. WHERE DO I GO TO DOWN LOAD WHAT I NEED
Jul 16, 2009 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
53 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
