Question about Lasko Heating & Cooling
Problem with feature comforts HV-0513F ? - Lasko Heating & Cooling
I hv lg 700s studioworks crt monitor... i hv set a resolution of 1280*1024, but now m not able to control some of its functions like its width size...width has gone out of the monitor, it isnt getting
Hello
Select reset option by monitor menu, set it to default first. Then try to adjust the width and height of the screen. If this does not help you, try other resolutions set by the system.
Nov 26, 2011 | LG Studioworks 700S 17" CRT Monitor
Feature comforts tower fan need owners manual- cant access the blades to clean
I have a Feature Comforts Tower Fan that doesnt work? It has never worked
Jul 22, 2011 | Dryers
Trying to connect antenna. Tv will not program for digital channels. Only goes through analog and comes up with 0.
Sounds as if you have a bad tuner. Can be tricky to replace if it is on a 2 sided board. If you are not comfortable with a soldering iron or electronics, I would have a certified servicer look at it.
Apr 08, 2011 | Proview HV-207 20 in. HD-Ready LCD...
About audio device
No it wont support with your board...because it's the driver of some other board but not *********** board....try to download in the internet
Jul 05, 2009 | Audio Players & Recorders
Comfort features Problem
* An adjustable or rotating blade or handle allows a more natural grip at various angles * A well-balanced design enhances control and tends to make the saw feel lighter * A cushioned grip improves comfort and control, even through long, sweaty jobs * Antivibration features deliver smoother action to reduce fatigue and enhance accuracy
Aug 27, 2008 | Dewalt 9.5 amp reciprocating saw kit
Auto convergence feature gone
Its the HV transformer, But if your symptom is auto convergence feature gone from the menu. Its not your flyback. Please respond to this same post with your model number and let me know if the auto convergence feature is missing, and I will assist you with the problem.
Jul 22, 2008 | Televison & Video
Tooooooooo Bright
I would start by making some voltage measurements on the signal processor IC to see if the black level pin voltage can be varied. if not that might be the issue, but I have a feeling that it will vary so lets look at what else could be wrong. I know I harp on this circuit so much, but I have seen its failure so many times that I suspect it when ever HV issues occur. Inside of your TV there is a circuit that is supposed to shut the TV down whenever there is excessive HV pulses coming from the HV output of the IHVT (flyback transformer) if this circuit fails there will be an excessive amount of HV delivered to the anode of the picture tube, and this would cause the picture to become too bright. In addition this could be caused by a failure in the HV/Horizontal section of the TV in question. I would begin checking waveforms and voltage levels in that section if the brightness control on the signal processor IC is indeed working but not controlling the black level of the picture. I can not tell you what components are bad, just that you should concentrate on the HV/Horizontal section and the shutdown circuit for measurements. Get a schematic. If you dod not feel comfortable doing this take the set to a qualified TV technician.
May 13, 2007 | Durabrand DWT1905 TV
Heating & Cooling Logo
88 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Mack Baxter
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
