Question about HP Laserjet M2727nf Multifunction Printer
HP Laserjet M2727nf 's scanner
My scanner jams everytime I feed more then 1 page through the tray. How can I fix this?
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 102 Answers
If the problem is ALWAYS, can be caused by an error in the configuration of the white paper size. That is, the printer has a conflict of comparing the original document size and the size of the white paper.
If the paper has left marks from objects obstructing the paper path. This alone can resolve the paper feeding disarm until you check that the sensors are free of obstructions.
You can also clean and well make sure they are free of any problems and ensure that the paper path goes smoothly.
Try also check the good condition of the rubber paper feed, paper separation and drag.
Posted on Feb 28, 2012
SOURCE: HP Laserjet 3050 paper jam
software cd
Posted on Feb 18, 2008
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
DosHog
  • 168 Answers
SOURCE: 13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Posted on Jul 23, 2009
  • 39 Answers
SOURCE: HP color laserjet 4600 dn printer How do I set
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Posted on Feb 19, 2010
  • 121 Answers
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Posted on Feb 23, 2010
Hp Color Laserjet 1600 says Jam in tray 2 bt there is not paper jams
Open the paper feed area and the printer, examine the paper feed path and make sure there isn't a page or piece of paper jammed in the path somewhere.
Aug 21, 2014 | HP Color LaserJet 1600
ERROR MESSAGE 5.
This is a common problem with this machine and more than likely the scanner will need to be replaced. You should try calling HP and see if they will cover it since it is a common problem... but before that try hard reset on ur printer
good luck....
Jun 05, 2009 | Office Equipment & Supplies
My HP M2727nf scanner pulls more than one page through at a time causing paper jams and interrupting the scan function. How do I diagnose the cause?
Hi this is a typical symptom of the firmware being out of date. Go to the hp website and download the latest firmware upgrade utility. If the firmware is updated and the problem continues it could be a problem with either the dc controller of the formatter board.
Al
May 07, 2010 | HP M2727NF Laserjet Printer
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Jam in print paper path HP 2840 printer
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
May 20, 2009 | HP LaserJet 2840 All-In-One Printer
Printing problems - i can only print manual feed...
the manual tray is the is the one above the tray,
1-either your tray is set incorrectly must be set to Letter/Plain
priority is tray 2 not tray 1
tray one is the by-pass / manual
since this printer does not have a screen on it everything is setup through the PC.
print a configuration page and you will see all the settings
Aug 05, 2008 | HP LaserJet 1022 Printer
LJ3700 page tops half- way through fuser. Bob
13.01.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. 13.02.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. these are areas that you mentioned and fixes to them http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478#A3 this is the link to all error codes for your printer you might want to print these out and keep safe
May 07, 2008 | HP Color LaserJet 3500 Printer
HP Laserjet M2727nf Multifunction Printer Logo
91 people viewed this question
Seeker5211
Seeker5211
