Question about Dell V305w All-In-One R840635AU InkJet Printer
How do I open the dell v305 printer to attach encoded strip?
The encoded strip came off. It is ok it still has a hole on either end. But I can not see enough where to put it without taking the lid off. I removed the screws but it still won't open.
  • Donna Nelli-Brozak Feb 09, 2012
    Does anyone know how to take the lid off the printer? I can't see inside well enough to attach the encoder strip. Another person said they were able to take it off, but I have been trying & the manual does not tell you how.
5 Suggested Answers
damanpreet_c
  • 69 Answers
SOURCE: encoder strip
It is not possible for you to hook the encoder strip back to print, its kind of a Hooks on both ends which is holding it, even if you are able to put it back, it will not work,
I would refer you to a local computer tech, however I'll suggest you to get a new printer, coz tech might charge lot more than what the price of new printer
Posted on Nov 07, 2008
  • 38 Answers
SOURCE: my encoder strip on my v305 printer is not
If it is not installed anymore then it probably broke on one of the ends. Check to see if you have a little square hole on each end. If you do then you will have to remove the cover to reattach. There is a hook on each end of the printer that the square hole attaches to. There is also a slot on the back of the carriage assembly (where the ink cartridges go into) and the encoder goes thru that slot and then attaches to the ends.
Posted on Nov 07, 2009
Testimonial: "i do still have both holes attached on each side. this is good news that i am able to repair it! thanks so much! "
pineworks
  • 4041 Answers
SOURCE: dell 922 all in one printer. Encoder strip has
Hi
Error code: 1200
This error code is commonly associated with the Dell 922 printer. Usually you might see the cartridge moving front and back and slamming itself against the printer. You need to tighten the strings located on the back of the printer and then it should work fine
Clean the carriage rail. This is the round chrome piece that the carriage assy that holds the cartridges rides on. Use a paper towel that is slightly moist.
Be sure to not force anything. Unplug the printer after you get the carts in the middle. Move them to one side and clean and then move them to the other and repeat.
Lift up the scanner to reveal the cartridge compartment; under the chrome rod on which the cartridges run there are two small gaps about 8cm apart. In the right one should sit the paper sensor which is a small black rod that hooks downwards; the problem I had was my sensor had bent up and out of the gap so all I had to do was bend it gently back into position using a small screwdriver.
Hope you get it to go.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Error message clear carrier jam, when I opened the top of the Dell Photo 926 a long clear strip fell out, What do I do to fix this.
The long clear strip is the encoder strip that the cartridge carriage reads to know where it is in the printer. It should not have just fallen out. There should be a small hole at each end of the strip to attach it to points in the printer. If one of those holes is broken you might as well get a new printer. Paying someone to buy a new encoder strip and install it will most likely cost more than the machine itself.
Sep 28, 2010 | Dell 926 All-In-One InkJet Printer
My Lexmark 4 in 1 X5630 printer is saying carrier jam. How do I go about sorting this out?
I got an amazing solution to this problem that worked for me.......my printer is working now :)
just sharing with you............
"Someone tried for hours to reattach my encoder strip, and finally figured out the way to do it after reading many web postings, and my own trial and error. The key is to use a "dental mirror" that you can pick up at a pharmacy or hardware store for about $5. (Perhaps a small compact mirror may also work.) And you need to focus light back there. (I used a head lamp.) The problem is you just can not see the small slot through which the encoder strip must be threaded from the front of the printer. It sits in back of the ink cartridges. This thin slot "tunnel" goes though a rectangular piece of plastic. You can feel the rectangular piece of plastic in back of the ink cartridges, and looking with the dental mirror you can see how small the slots are on the right and left side, through which the encoder strip must be threaded. After "seeing" these small slots using the dental mirror, you then can feel them with the tip of a fingernail, and know exactly what you are aiming for as you then feed the encoder strip through. (It doesn't make any difference of you feed the strip from the left or the right, but the down arrow end of the encoder stip must end up on the right when you later attach it to the wire tab.) I fed the strip "blind" after I had formed a strong mental image of exacly what I was trying to do, and now being able to feel the small slot I was aiming for with the tip of a fingernail. (It is tough working in the small space in back of the ink cartridges, and if you have really big hands and fingers it may be impossible. I did not want to use forceps or tweezers because of a fear of damaging the encoder strip.) The encoder strip then must be attached with the down arrow end on the right attaching to a flimsy looking wire on the right side of the printer. The left end of the encoder strip must be attached to a metal tab on the left side of the printer. You will need to hold tension on the encoder strip, and manually push the sliding ink cartridge back and forth out of the way as you attatch both ends. (It's probably a good idea to gently clean the encoder stip of all your fingerprints and any smudged ink with a tissue after you get it back in place. Also be sure to clean the metal bar the ink cartridges slide back and forth on, so you don't get error message 0502.) Be prepared for this to be a very frustating experience! You will be maddened by how many times it will take to thread the encoder strip though the slot, how difficult it will be to catch the end of the encoder strip on the wire and metal tabs, and how you will have to figure out how to hold tension on the encoder strip so one end won't fall off as you attach the other end. But once you use the dental mirror to see where you have to thread the encoder strip, and once you see the wire and metal tabs to which the ends of the encoder strip must be attached, then YOU CAN DO IT! It just takes persistance."
Jul 09, 2010 | Lexmark X5470 All-In-One InkJet Printer
I have a dell V305 Printer and there is a plastic strip that has fallen off from somewhere inside. Can you advise as to what this strip is for and if it can be reinstered?
If it's a clear plastic with black lines on it, it's the encoder strip. If the holes on the end are not torn out, it installs inside from the right side to the left side, one side has a spring to connect to and the other side has a solid hook on the frame. It has to thread thru a sensor slot at the rear of the carriage assembly in order to work.
Jan 15, 2010 | Lexmark X1270 All-In-One InkJet Printer
My encoder strip on my v305 printer is not attached, i dont know where or how to reattach, anyone have a clue?? thanks
Nov 06, 2009 | Dell V305w All-In-One R840635AU InkJet...
Dell 924 printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Nov 05, 2008 | Dell 924 All-in-One InkJet Printer
Encoder strip have hole. How can i take it out?
Why would you want to remove the encoder strip? The strip can be carefully cleaned in place by following the instructions here.
If you really want to remove the strip (not recommended) open the lid (with the power on). Wait for the printer noises to stop, then carefully move the carriage (with the print cartridges in it) to the left. Unplug the printer power.
The encoder is held on a metal tang at the right side and a spring on the left side. Carefully grasp the encoder near the right side and pull it to the right so it can be dislodged from the tang on the right. You will need to bend the encoder slightly to unhook the end. Once it has been loosened form the right you can then release the left tang and carefully remove the encoder.
When reinstalling the encoder reverse these steps. First thread it properly through the sensor on the back of the carriage, then connect the left end to the spring, then connect the right side.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jun 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Encoder strip
I tried for hours to reattach my encoder strip, and finally figured out the way to do it after reading many web postings, and my own trial and error.
May 28, 2008 | Dell A940 All-In-One InkJet Printer
Encoder Strip
Jan 09, 2008 | Dell A940 All-In-One InkJet Printer
Encoder strip
Nov 05, 2007 | Dell A940 All-In-One InkJet Printer
Dell V305w All-In-One R840635AU InkJet Printer Logo
526 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
