I need to take apart a paper shredder MX120D
Made by AXEUS
4 Suggested Answers
SOURCE: the shredder will not cut the paper. the motor
I just had this problem. I took the screws out from the bottom of the shredder and opened it up, take a look and see if there are any cracks around the frame that surrounds and holds the shredder in place, if so you have to glue the crack so the frame is stable again.(the crack/break in the frame prevents the paper from cutting because the teeth on the shredder are not fitted properly). hope this helps.
Posted on Aug 30, 2009
venexcsd
  • 1185 Answers
SOURCE: I have a large amount of paper jamed in the
You would be better to use a can of WD40 to soak the paper to soften it then try a reverse drive
Stripping down the machine is an option however you are still faced with getting the paper residue out of the cutters
WD40 or any of the oil based sprays will give you a better chance of clearing the jam
Posted on Jan 24, 2010
walesarumi
  • 6993 Answers
SOURCE: I have an Axeus model
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage. Make sure the paper is engaging sensor located in the center of the shredder opening
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three times.
Good luck.
Posted on Mar 23, 2011
How do I remove paper stuck in my shredder????I have a Royal 10X Cut Paper Shredder. On label it has PCUA:29054E 10x 00324040. How do I take it apart to remove the wedged paper???
You may have to turn it upside down and go to work with tweezers and a utility knife to remove every bit of paper from the mechanism. I have found that 10X rating to be overly optimistic; the equivalent Royal shredder I am using currently groans and complains if more than a few sheets are fed in at a time.
Feb 22, 2015 | Royal Office Equipment & Supplies
I need a new drive gear
Owner:AXEUS, INC.Owner Address:P. O. Box 130026
Carlsbad CA 92013Owner Web Sitewww.axeus.comOwner Phone760-496-1300Owner Toll Free
Donna:
This is the latest information that I have on Embassy. Good luck.
Sep 12, 2012 | Office Equipment & Supplies
I have an Ativa 1850. When putting papers in to shred the papers move to the right side and bunches up the paper. The shredder now doesn't want to work properly. No papers will go through to be...
You probably need to get some shredder oil and lubricate the cutter heads. see: http://www.walmart.com/ip/Fellowes-Powershred-Shredder-Lubricant-Oil/8207323
Apr 19, 2011 | Office Depot Ativa 1850 (MicroCut)...
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here: http://hubpages.com/hub/Paper-Shredder-Oil
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
I have royal shredder and suddenly stopped. reverse side is working. There is no paper stuck in it. please help. Thanks
There are LED photo sensors in the feed path that detect paper. They can get a build up of paper lint or oil on them. The shredder needs to be taken apart and these need to be cleaned.
Oct 13, 2009 | Office Equipment & Supplies
The shredder will not cut the paper. the motor
Aug 28, 2009 | Aurora Electronics AURORA - Aurora paper...
Infoguard SX100M unit will not shred. Green light comes on.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
Anyways, I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Jan 10, 2009 | Cross Infoguard Shredder SX102M
Huge paper jam ( piece of a checkbook)
Throw it out and buy a new one! staples won't replace this unit and your gonna have to take it apart and clean the gears.
Also tell your employees to stop reversing the drive gears with paper inside the bucket it only reverses the flow and jams the unit.
I would buy a cross cut shredder next time.
Hope that helps.
Jan 19, 2008 | Techko SH1524CP Shredder
Shredding paper partially
Your cutters have spread apart this could be caused by overloading machine to many times or something may have cracked internally that held them in place.
Jan 02, 2008 | Shredder Secure Shred Shredder
Sx-102M
I have the Infoguard SX-100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, the gears and fuse was ok, I think something on the circuit board was fried.
Dec 21, 2007 | Cross Infoguard Shredder SX102M
101 people viewed this question
jasbo
jasbo
