Question about LG WM Washing Machines
IU code on LG front loading washer - WM LG Washing Machines
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
  • 53 Answers
SOURCE: OE ERROR CODE APPEARS ON DISPLAY
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages
Posted on Oct 14, 2009
  • 94 Answers
SOURCE: LG front load washer coded UE. what does that
UE means unbalanced error. when you see this, it means the clothes are unevenly distributed in washer, it's basically unbalanced.
Posted on Dec 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: LG washer Model # WM1814CW problem code UE
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
Posted on May 20, 2010
LG ERROR CODE ID56 AND IU 10
to better help you with these error codes from your LG washer what model is this washer?
Aug 22, 2016 | LG Washing Machines
LG front load washer is leaking underneath the front left corner, the display code is FE.
Why don't you simply find out what the FE code is alluding to? Go to web site or do a google search and then you can check for the issue further.
Sep 17, 2017 | LG WM2487H Front Load Washer
Error code te for lg tromm front load washer wm2496hsm
The TE error code is a Thermistor error. Replace the thermistor and you should be good to go.
Feb 29, 2012 | LG WM-2032H Front Load Washer
LG WM2277HW washer not filling with water
I own the same washer. First see if you are getting the "IU" or any other error code. I would do the following
1) Check to make sure the water supply valve, where the hoses connect (just bear with me!) is on. hoses should be "stiff" with water pressure.
2) Check for a link in the hoses which may be blocking water flow
3) Unplug the machine
4) Remove the water supply hoses at the machine end.
5) Remove the plastic orange and blue "screens" and check for blockage
6) Clean and reinstall screens and hoses, make certain all connections are tight
7) Turn on water supply.
8) put load in washer and turn on the run normal cycle
9) Listen for the water valves to open. If you down hear valve opening, it could be a bad valve
10 Check washer to see if water is entering
11) If none of these solves the issue..call for service.
Good Luck!
Apr 14, 2011 | LG WM-2277HW Front Load Washer
We have an LG front loading washer. We first
This could be a bad hall sensor or even a bad motor. The motor is warrantied for 7 years but, you need to call an LG authorized service center and provide proof of purchase.
Jan 24, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE code appeares on my LG front load washer
A majority of the time when the LE code appears.. the Hall sensor in the motor is bad. Replacing it. Part # 6501KW2002A from MCM electronics... can help. Good luck.
Nov 17, 2009 | LG Washing Machines
"UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Aug 07, 2009 | LG WM1814CW Front Load Washer
LG WM2277HW - ERROR CODE "LE"
Hello remrama,
Please use this link to access the service manual on your display code message ( page 18 ) elaborates on the cause of that message. You should be able to determine which of the few causes may be the culpret,... http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Hope this helps you..
Regards,
Rick
Feb 22, 2009 | LG WM-2277HW Front Load Washer
LG Front load washer LE error code
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
You can order parts by your location by CLICKING HERE
Nov 21, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
213 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
