I have a blank GREEN screen on all of my sky hd channels
  • william bird Feb 08, 2012
    have a green freeze screen in vertical thirds but can hear the sound
    Genius:
  • 1,212 Answers
If you are able to bring up the menus on screen for the Television, the problem is with the skybox converter box. Make sure the subscriber card is loaded. You may need to remove it and clean the contacts with a pencil eraser. Gently of course.
Posted on Feb 08, 2012
  • John McPherson Feb 11, 2012
    Assuming set is okay, the dish or it's LNB may be loose. The LNB is the piece the dish actually reflects to. If the dish is loose, it may need to be re-aimed.
    A frozen screen in green can be the result of a multi-path signal such as one with tree branches between a satellite or distant digital signal source and the dish/antenna itself, Check the terminal connections for loose condition and for corrosion. from the LNB or digital antenna down to the box itself.
5 Suggested Answers
SOURCE: Green screen on HD channels
VIDEO CARD IN LCD IS BAD MOST CAUSE OF THIS PROBLEM
Posted on Sep 23, 2007
lukster
  • 217 Answers
SOURCE: HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Posted on Jul 20, 2008
  • 109 Answers
SOURCE: distortion on people faces
What does a dvd look like played on it? If it's the same then there is something wrong with the TV. If a dvd looks good - no color problem - then it's the sat box that needs replaced.
Posted on Mar 25, 2009
as400jockey
  • 3 Answers
SOURCE: White/Grey screen with non-HD channels
I removed the HDMI cable and connected with component video and rca audio. No more white screen.
Picture quality looks good. I don't know if it's as good as HDMI, but then I don't need to reboot the TV three times to get to teh on-demand menu... Grrrrr....
I am trying to contact Toshiba on this as well. I have seen several reports of this problem on the web.
Posted on Feb 06, 2010
Colour is not normal, sometimes the picture is too dark, football pitches bright green, peoples faces very orange.
that would be a failing tcon board on the back of the screen.you would need to replace this part but they are available on ebay the part number is on the tcon board. match the numbers a version number to get the matching board for the screen. tcon board is the board were the main wire cluster goes to the screen board this is the tcon board.
Jul 03, 2017 | Samsung LE37R72B 37 in. HD-Ready LCD...
HD not working.
Have you connected it Via HDMI? if the screen is still connected via Scart then that is the problem.
May 03, 2010 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung tv 32:inch no LE32R74BDZ WILL NOT WORK WHEN CONECTED WITH HMDI CABLE ,SCREEN GOES GREEN. SO I USE COMPOSITE CABLES .I HAVE A FOXSAT HD SKY BOX. BUT I WANT HD PICTCURES. AS I HAVE AN HD BOX . IS IT...
We need to narrow things down . If you have a dvd player that has an HDMI output plug that into the HDMI input of the tv with a diffent cable than the one for the sky box. If color is still green then the main board on the tv is bad. If the picture is good then Either the cable used for the sky box is bad or the sky box is bad.
Mar 25, 2010 | Televison & Video
LG HD 37 INCH TV GREEN LINE APPEARING ALONG THE BOTTOM
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
Feb 19, 2010 | LG 32LG30 32 in. LCD HDTV
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
HDMI conneection wont override tv picture
I am a sky engineer (not a subby)
the reason this does not come on straight away is because a Scart lead send power upto your telly when it is turned on. Telling the telly that this is what you want.
Unfortunately HDMI does not send power upto the telly. There are ways around this. ON Samsung, Panasonic and Lg tellys you can go into a secret menu and apply something called HOTEL MODE this allows you to change the av input so it would automatically come on your hdmi 1,2,3, etc
In your case follow my instructions below
go to the hdmi you are using for your Hd
on the sky remote
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice. what this mean is when you press your Sky button, tv guide, services or interactive button to turn the sky on this will automatically change your av/source on your telly to the sky HD for you
You owe me a pint
Have a good one
Little Dish Fitter
Jul 19, 2009 | Microsoft Xbox 360 Console
Bravia & Sky+HD, aspect problem
There is nothing wrong with you Sony Bravia TV and it suppport all HD and SD formats.
Are you viewing the HD version of the channel when it is showing a standard defination show. e.g SKY1 HD instead of SKY1.
This means that regular standard defination shows are in a 4:3 ratio and does not fill the whole screen. In order to view these type of shows you will need to tune to regular channel instead of the HD version.
You can check if a show is brocast in HD by going into the tv guide and checking for the HD symbol in the programme symposis.
Example
Apr 13, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Probem getting sky to work with a new TV
An HD TV connects in the same way as a standard TV.
Connect a scart lead from the TV scart of the Sky box to the TV.
When you switch on the Sky box it should automatically switch the TV to the correct external input.
May 19, 2008 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
