Indesit W 123 Front Load Washer
Problem for Indesit W 123 Front Load Washer
Washing machine fills continuously
By sph1 on Aug 03, 2006
when turning on the washing machine it started to fill with water but then kept on doing so. after turning the machine off it would not empty the water either
Same Problem
Aug 03, 2008
-   At start of cycle water fill but never fills up the basket as it fills it also is draining out never goes to the next cycle to wash
Yvonne-   Guest
Aug 03, 2008
-   washing machine continue to fill with water but does not clicl over to wash cycle-   Guest
Mar 23, 2008
-   I have a GE top load washer that will continue to fill past the water level and overflow. Then even though I set the wash cycle by hand it continues to fill with water, however when I set to the spin cycle it spins and empties the water, no other cycle will work. flooding the laundry room, any suggestions-   allwet2
Feb 16, 2008
-   i have a ge top load washer that will continue to fill because the water level continues to drop any suggestions?
-   Guest
Dec 14, 2007
-   I have a Constructa CR 60850 that does not stop filling water causing the water to overflow from the bottom of the machine. How do I solve the problem. Where is the water valve?-   sarahle
Best Solution
posted on Sep 11, 2006
Very Helpful)
MikeC
Rank: Apprentice
Rating: 100%, 3 votes
you may have solved the problem by now....but it is probably a blockage in the level pressure chamber which is eaither a part of the drain pump manifold or a seperate chamber attached to the bottom of the tub. Its easy to find just follow the small pressure hose from the top of the machine. If its part of the drain manifold its not so easy to clear unless you have a large surringe to pump hot water down the hose to clear it.**** REMEMBER TO UNPLUG THE APPLIANCE FROM THE POWER SUPPLY ******
Was this helpful?
Yes
No
Solution #2
posted on Oct 09, 2007
Helpful)
Guest
Rank: Apprentice  Washers & Dryers  Expert
Rating: 0%, 0 votes
I had the same problem as above. I cleaned the chamber attached to the bottom part of the bucket and used a syringe to push hot water down the this plastic hose that runs to that unit. I also made sure that the clip holding the plastic hose at both ends are fited properly. (similar to what mike has in solution 4). All sorted.
Solution #3
posted on Aug 03, 2006
Helpful)
take
Rank: Master
Rating: 79%, 495 votes
It sound to be the water level switch but somes times the thin hose conected to the water level switch is broken... if you know how to dissambling and check visualy if you got a broken hose or a bad switch if the hose is ok try snaping the switch with an screew driver..any way is better to replace it with a new one....
Was this helpful?
Yes
No
Solution #4
posted on Jan 08, 2007
Helpful)
Guest
Rating: 0%, 0 votes
If you know how to use a mains volt meter you can check if the solenoid that controls the water inlet is energised to start and the de-energised to stop the flow of water. If this operates as suggested the water level switch is probably ok as is the controller. That then leaves the valve itself - if brave - disconnect water and power, remove valve and disassemble. There is a tiny hole in rubber membrane inside valve. If this gets blocked it can open but cannot close. Usually it is a tiny piece of dirt that causes the problem.
Mat
Solution #5
posted on Jan 17, 2007
Not Rated)
Guest
Rating: 0%, 0 votes
MAKE SURE YOU CHECK THE WATER LEVEL SWITCH, THE WATER VALVE (SELENOID) IF THIS TWO PARTS TEST OUT OK, REPLACE THE TIMER AND THE MAIN WIRE HARNESS..
Popular Solutions for Indesit W 123 Front Load
Questions and Unsolved Problems for Indesit W 123 Front Load
Do you recommend Indesit W 123 Front Load Washer?
Answer
Answer
Indesit w1232. when I select a programme the dial just keeps turning continuously. keeps clicking... (More)
Answer
I am trying to change the door handle on my indesit w123 and finding it difficult
Answer
riped metal inner drum how do i replace it the seam on the inner drum has come apart and has now has... (More)
Answer
I must have wrongly reconnected the program knob because it does turn any more. Any wiring diagrams... (More)
Answer
have a Indesit WDN 2296 XWU for 13 years and first time got a problem with cycling/rotating cd yu... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Newbury, OH
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
