Question about Lexmark T630 Laser Printer
Lexmark t630 prints ink on right side of paper
  • 65 Answers
There are typically a few causes of this.
1 - low toner
2 - charge and transfer rollers need to be replaced
3 - high voltage power supply is failing
the first 2 can be checked and fixed very easily
take the toner out and give the toner a shake and replace into the printer.
remove the toner, drop the front door down a couple inches and you will see the charge roller attached to the 2 arms drop down from the top of the printer in the toner bay. if the roller is yellow or orangish it needs to be replaced because the roller should be gray in color. hope this helps!
Posted on Feb 27, 2012
SOURCE: Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Posted on Apr 13, 2007
amfigue
SOURCE: Alignment error after replacing black ink. Lexmark X5495
I found a pencil inside my printer and took it out. It was not easy but now it does not jams the paper. Disconnect the power cord and softly shake the printer from side to side making sure you are holding on to the top scanner door so it won't flip open and listen for anything rolling or loose inside. It just might be your problem.
Posted on Mar 24, 2009
webmaster21
  • 803 Answers
SOURCE: how do I print config pages for Lexmark T630,
1 Make sure the printer is on.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Print Menus, and then press Select to
print the page. The message Printing Menus appears on the
display.
4 Verify that the options you installed are correctly listed under
“Installed Features.”
If an option you installed is not listed, turn the printer off, unplug
the power cord, and reinstall the option. See Step 3: “Install
memory and option cards” on page 30 for more information.
5 Verify the amount of memory installed is correctly listed under
“Printer Information.”
6 Verify that the trays are configured for the sizes and types of
print media you loaded.
or
3 Press Menu until you see Print Net Setup, and then press
Select to print the page.
4 Check the first section on the network setup page and confirm
that Status is “Connected.”
If Status is “Not Connected,” your LAN drop may not be active
or your network cable may be malfunctioning. Consult your
network administrator for a solution. Afterward, print another
network setup page to verify connection to your network.
or
1 Launch the CD.
2 Click Quick Reference.
3 Print the documents.
The same Quick Reference pages are stored in the printer. To print
them:
2 Press Menu until you see Help Menu, and then press Select.
3 When you see Quick Reference, press Select.
Posted on Sep 25, 2009
thunderbo611
  • 66 Answers
SOURCE: Lexmark T630 paper jam 238 it says check duplex.
in the back
Posted on Jan 26, 2010
rcw1962
  • 2571 Answers
SOURCE: 202 Paper Jam, but there
Thank you very much! ????
I am not sure where you think you are posting, but to leave a comment like that is unlikely to get a favorable response.
This is an independant help site, this site has nothing to do with Lexmark, and so the thank you very much comment is unneeded, and unwelcome.
You may have paper stuck inside the machine, where you cant see it, If you had a jam, and pulled the parer out, some may have stuck inside, or you may have damaged something pulling it out.
You may have to take the printer apart to check
Posted on Sep 16, 2010
I HAVE LEXMARK T630, IT PRINTS THE REGULAR PAPERS PRETTY GOOD EXCEPT A CERTAIN VERTICAL SPOT, HELP NEEDED PLEASE!
You have to check if you do not have a fuser problem.
In that case you have to chage the fuser
Sep 21, 2011 | Lexmark T630 Laser Printer
Lexmark t630 error says remove paper standard bin. Never knew anything about standard bin -- can't get it to print, and yes, there is a connection to the computer
The Remove Paper Standard Bin error can be possibly caused by the exit flag that is out of position, stuck or broken. Follow troubleshooting steps found at http://bit.ly/dhOTEo. If any part of the flag or holder appears to be broken, contact Lexmark technical support or a local authorized service provider.
Sep 20, 2010 | Lexmark T630 Laser Printer
Hello i have a lexmark t630 and when it prints out of tray 2 it says change tray two and beeps. It will work normal if you hit the select button. What could it be?
the printer is telling you that the tray is reporting the wrong size paper. print the network menu from tray 2 if it prints out smaller than the page it will be reporting smaller than letter. if the bottom line of the outline is missing its reporting legal size paper. if you are running lettersize paper in the tray check on the left side of the tray half way down the drawer you will see a plastic snap in plate with 3 fingers the bottom 2 should be sticking out for letter size paper. you only have to be one of the small adjust teeth off to make the third finger stick out and report the wrong size paper this is a very common issue. look at the metal fingers that stick out of the frame of the options tray to make sure they are uniform and straight. if the fingers are set right and not damaged then the logic board in the tray assembly will have to be replaced
May 14, 2010 | Lexmark T630 Laser Printer
THERE IS PAPER JAMMED IN THE LEXMARK T630 AND WE CAN'T GET IT OUT
first you take out toner cartridge and see if paper is jam in fussing unit otherwise open the back side door and take out fussing unit and clean the paper jam
Feb 05, 2010 | Lexmark T630 Laser Printer
I have an lexmark 630 and keep getting the error "load MP feeder plain paper" thanks for the help chip loye chapelthrill@gmail.com charlesloye@gmail.com
Please follow my tips ,When you print your computer before you go to print properties.Setting paper layout choice paper source and enable MP tray then print ok.
keep your mind before print you must be insert paper in MP tray.
Sep 28, 2009 | Lexmark T630 Laser Printer
Lexmark T630 error message: Change MP Feeder
use the right arrow go to paper menu scroll to the right to paper source select if it is set to mp tray reset it to tray one. if its set to tray 1. check the side of the paper drawer to make sure the paper size snap in plate is in place. if these things are good replace the paper size selection pcb located in behind the logic pack
Sep 15, 2009 | Lexmark T630 Laser Printer
Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Dec 31, 2008 | Lexmark T630 Laser Printer
Lexmark T630
I would suggest pulling the toner out and paper tray and using compressed air to blow out all ereas of the printer. If that does not work then you will have to remove the 2 screws at the back of the printer and with the two tabs at the top remove the backa nd look for paper jammed inside.
Feb 27, 2008 | Lexmark T630 Laser Printer
Lexmark T630 Laser Printer Logo
169 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
