I have a whirlpool washer model wtw4930xw0 and its not coming on
My electricty went off and when it came back on the washer is not coming on
2 Suggested Answers
SOURCE: Electricty went out and the refridgerator did not come back on
my refrigerator lites are out but the refrigerator is still running good i replaced the lite bulb and still no lites
Posted on Jun 09, 2009
MODEL 110-24722300 KENMORE WASHER. LID SWITCH DOES NOT WORK AND HAS COME LOOSE. HOW DO I PUT IT BACK TOGETHER?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024722300/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet. See the Sears diagrams on the control panel and cabinet to see where / how the switch connects.
Nov 24, 2010 | Kenmore 22422 Top Load Washer
Model 110246 32 300 washer filled and then went completely dead=Help top loader
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Aug 21, 2010 | Kenmore Washing Machines
Dryer won't come on
Was it the dryer door he slammed shut or the house door? If it was the dryer door, then TheMobilian's answer is on the nose. If it was the house door that was slammed and it tripped the circuit breaker to your house, then you have something else entirely going on. Does your dryer have an electronic control panel (totally smooth surface), or does it have the knobs and buttons? What model number do you have?
Jul 08, 2009 | Whirlpool LER4634J Electric Dryer
alot of times you will have a seperate breaker in your fusebox check to see if 1 of those is triped
Jun 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Clock went out and now have a loud clicking sound even with electricty turn off.
Checked the fuse box and found no issue, but switched it on and off. Then replugged in the oven but still got the clicking sounds. However after again repushing the clock reset buttons the clock came back on and clicking stopped.
Jun 01, 2009 | Bosch Kitchen Ranges
No cam in my washer?
hat is the dogs, four little progections should have ridges on the outside of them, and they "interlock;" with the grooves cut into the inside of the agitator
Feb 13, 2009 | Whirlpool Washing Machines
Squeeking noise on whirlpool washer duet ghw9100lw2
replace your belt in back easy.every year if still has smell buy warranty your rear bearing is going bad."less soap plz"
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Akai tv wont come back on
Nothing......bad capacitors in power supply need replacing.....T.
Jul 16, 2008 | Akai LCT2716 27 in. LCD Television
Whirlpool Top loader
Open the lid and the model and serial tag is on the washer itself in the middle under lid in back. Open lid and look at area where lid and washer top come together between hinges.
Nov 05, 2007 | Whirlpool LSB6200KQ Top Load Washer
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Sep 12, 2007 | Washing Machines
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
