Question about Garden
How do you adjust chain tension on the weslo aerobike 1250
4 Suggested Answers
SOURCE: chain tension
Hi Sally, I guess you don't have the owners manual. It tells you how to adjust chain tension. If you look around near the motor side of the bar, you should see two nuts that hold a bracket tight against the bar and an adjustment screw or bolt or something to loosen or tighten the chain by moving the bar or making it longer or shorter. Adjust that so that the bar is as short as possible and put the chain back in place. Then tighten that feature till the chain is snug again and tighten the two nuts to hold the bar firmly.
Posted on Sep 11, 2008
  • 708 Answers
SOURCE: the chain adjuster screw is broken
If the housing itself is broken you will probably be better off buying a new or used say. As that part would be very expensive and you will still have a used saw.
Posted on Apr 07, 2009
huffman49
  • 235 Answers
SOURCE: JUST BOUGHT A 20'' POULAN PRO TENSION A CHAIN
the adjustment screw near the end of the bar( next to the engine) needs to be turned in to tighten the chain just don't tighten it to much
Posted on Apr 04, 2010
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Tip
StarTrac NXT Chain Tensioning & Alignment Video
About This Video
Adjusting Chain Tension and Alignment on a StarTrac NXT
  • In this video, we show how to tension and align the chain and flywheel on a StarTrac NXT bike
  • First you see an example of a chain that is way too loose
  • To correct this loosen the flywheel bolt on both sides of the flywheel
  • Loosen the tension nut on the sprocket side of the bike and tighten the tension bolt until you get the proper deflection on the chain
    • A properly tensioned chain will have roughly 3/16" of deflection
  • Tighten the tension nut and the flywheel nut on both sides as shown in the video
Check the Alignment of the Chain and Sprockets after Making a Chain Tension Adjustment
  • Misaligned chains will look like they are walking from side to side where they enter and leave the sprockets
    • This can cause noise, premature wear, as well as making the chain look to be jumping from side to side during use
  • To correct this, loosen the flywheel nut on both sides of the flywheel, then loosen the tension nut and adjust the tension bolt to move the flywheel in the proper direction needed to align the chain with the flywheel sprocket, as seen in the video
    • Note: If you have already achieved proper tension of the chain, adjusting the tension nut on the opposite side from the sprocket will help to keep the same tension on the chain
  • Don't forget to check the chain tension after making an alignment adjustment
Chain Tensioning Alignment Video for StarTrac NXT Bike
on Feb 11, 2015 | Startrac Fitness Products Star Trac 4410HR...
How to adjust timing chain 2003 honda accord
the timing chain is adjusted by an oil pump chain tensioner and is to be renewed at each chain replacement. from this it is hydraulic adjustment and is automatic and does not require manual tensioning
Jan 06, 2015 | 2003 Honda Accord
How to tighten chain on 4620avx poulan pro
First, RTFM- read the manual. Lost it? No problem, download it from Poulan PRO website page for PP4620avx. Pick a version you like, save and read it. Google is your friend.
Chain Adjustment Part cut and pasted as follows:
Adjusting the tension:
Chain tension is very important. Chain stretches during use. This is especially true during the first few times you use your saw. Always check chain tension each time you use and refuel your saw.
1. Lift lever on bar knob and turn counter-clockwise 1.5-2 turns to loosen clutch cover.
2. Turn adjusting wheel (downward direction) to tension chain until chain solidly contacts bottom of guide bar rail. Lift tip of guide bar while adjusting tension. Tighten chain Adjusting Wheel
3. Use a screwdriver to move chain around guide bar to ensure all links are in bar groove.
4. While lifting tip of guide bar, tighten bar knob securely (clockwise).
Hand tighten only.
Be careful not to destroy the adjustment mechanism. When it breaks, go for a clutch cover with the simple adjuster that needs a "scrench". Longer term, learn how to search this info. Saves time. Now you can work on sharpening chains- very important.
Manual page:
http://www.poulanpro.com/ddoc/PPOO/PPOO2006_USen/PPOO2006_USen_PP4620AVX_952802146.pdf
Jul 21, 2014 | Poulan Pro Chain Saw 46cc 20"
Chain keeps poppin off
These are the instructions for adjusting the chain. They are taken directly from the manual available at http://ep.yimg.com/ty/cdn/razorama/e100e200e300manual.pdf
To adjust the chain:
1. Loosen the axle
2. Loosen the brake anchor (this is attached with the small bolt in the long slot on the left side of the rear fork)
3. Tighten the tension adjusters on the axle 1/8 to 1/4 turn to tension the chain. Tighten both adjusters the exact same amount to maintain the wheel alignment.
Note: this system of adjusters is common to motorcycles and BMX
bicycles so I your are not familiar with it, if you know anyone who is,
they would not have a problem adjusting it for you.
Chain tension: The chain should be "just not-quite snug" in other
words, not taut or sloppy loose. BE CAREFUL NOT TO ADJUST TOO TIGHT. The tensioning system can easily impart too much tension and snap the chain or bend the motor output shaft. Turn the adjusters 1/8 to 1/4 turn at a time and recheck the tension each time.
4. Once the tension is good, tighten the axle and brake anchor bolt. Test run the scooter. Readjust as needed.
Jan 02, 2014 | Razor E100 Electric Scooter
My weslo momentum 7.0 ex elliptical machine stopped giving resistance. I have turned the knob as far as it can go, and it is still easy! What can I do to repair this?
If you don't have the owners manual I suggest going to iconservice.com click on manual input this info Weslo THEN M# WLEL2904 then pages 11 and 12 will the steps to inspect and adjust tension for resesistance.
Jun 08, 2010 | Exercise & Fitness
How to adjust resistance on a manual Weslo cardio/walk treadmill
I found the solution on the Internet. Allen head bolts on each end of the frame can be turned to loosen or tighten the belt.
Jan 05, 2010 | Exercise & Fitness
How do you adjust chain tension? I have the 16" Remington electric chain saw, and the chain will not stay tight; it slips off the rear sprocket as soon as I try to use it. I don't feel everything is...
Here is a link to instructions for EL-8 series saws ... http://www.desatech.com/pdf/115499-01_EL8_Series_Chain_Saw_Tension_Adjustment.pdf. For series LNT-2, LNT-3,EL-1, and EL-7 according to the manufacturer... "WARNING: The cutting edges on the chain are sharp. Protective gloves should be used when touching the chain. Unplug the chain saw from the power supply. Allow chain to cool. Loosen the guide bar nuts until they are finger tight. Ensure the adjusting block is in the adjustment hole in the guide bar. Turn the chain tensioning screw clockwise to increase tension. Turn the chain tensioning screw counterclockwise to decrease tension. Check for proper chain adjustment by pulling down on the chain at the bottom center of the guide bar. You should see no more than a ⅛ inch gap between the chain cutting links and the guide bar. The guide (or drive) links should not come out of the guide bar grooves. The chain should rotate freely around the guide bar. If it does not, chain tension should be decreased. When the chain is properly adjusted, tighten the guide bar nuts securely." On the M series if your chain keeps slipping off your sprocket... The Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. I hope this helps you!
Jul 01, 2009 | Remington 16" Electric Chain Saw
Timming chain adjustment
Most likely you have anautomatic cam chain tensioner, which cannot be tensioned, and the only remedy is to replace the cam chain (if it's stretched). If, however, you have a manualy adjusted cam chain tensioner (highly unlikely), you have to look up the tensioning value in your workshop manual.
Jun 13, 2009 | 1986 Yamaha FZ 600
How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
