Question about Refrigerators
Light and temperture control indicators don't work
There was no indication of a problem until the next morning when I found the light and the indicators out, but the freezer light does work
The refrigerator was moved to a new location.  The temperature setting was on 41 degrees.  After the move the temperature indicator does not indicate any temp.  How do I reset the temp.  and turn on the indicator?
Posted on Oct 23, 2008
UR 2 Universal controller - don't work!
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 22, 2012 | Televison & Video
I have a universal remote systemlink 3 RCA. I need the code to program it. I have Goldstar TV. Thanks.
1.Use one of the following three digit codes for your TV set:
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, or 1722. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV. set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
8. If none of the codes work, you will want to use the following to go through the codes manually (this will take some time):
Code Search for the right TV code on a Universal Remote (systemlink 3 RCA)
1. Turn on the TV.
2. Press and hold the CODE SEARCH button until the indicator light lights. Then release the CODE SEARCH button.
3. Press and release TV button. The indicator light will blink once.
4. Repeatdly press and release the OFF/ON button until the TV turns off. It may be necessary to press the OFF/ON button up to 200 times before the TV turns off.
5. When the TV turns off, press the ENTER button. Now the Device is programmed for the TV set.
Aug 05, 2011 | RCA 3-dev Universal Remote Remote Control
2004 Audi A6 2.7T S-Type I have a battery and/or altinator issue. Last nite the battery indicator came on in the dash (not in the center display). The volt meter keept going lower until the radio quit...
doug hard688, It sounds like you have an alternator issue here. The volt meter monitors the output of the alternator. The battery indicator will come on when you have a bad or weak alternator. When this happens you are running on the power of the battery alone and this does not last long. As you state here the radio quit working and your lights probably got dimmer with time. As far as the other lights coming on, when some systems don't have enough power to run them the lights will come on indicating a problem. I wouldn't worry about them until you have your charging system checked. You can do this yourself if you have a volt meter. Start the vehicle and put the meter's red lead on the positive terminal of the battery and the black lead on the negative side. A properly charging alternator will be putting out 13.6 to 14.6 volts. A few tenths of a volt either way out of these specs is nothing to worry about. However, a variation really far from these specs indicates an alternator problem. Good luck with this.
Jun 04, 2011 | Audi A6 Cars & Trucks
I need a code for RCA remote RCR311STR for a Durabrand television model BH2004D.
In order for the 4 component universal remote to control your TV, you must program it with the TV code that matches your TV. These instructions explain the preferred method of programming the remote-the Direct Entry method.
  1. Manually turn on the TV.
  2. Locate the enclosed TV Code List. Find your brand of TV.
  3. Press and hold the CODE SEARCH key until the indicator light illuminates. Then release the CODE SEARCH key.
  4. Press and release the TV key. The indicator light blinks and then remains lit.
  5. Use the number keys to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3.
  6. Aim the remote at your TV and press the ON•OFF key. If your TV turns off, you have found the correct code.
  7. Write the code down for future reference.
  8. If your TV doesn't turn off, repeat steps 3-6 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote.
Program for VCR: In order for the 4 component universal remote to control your VCR, you must program it with the code that matches your VCR. These instructions explain the preferred method of programming the remote-the Direct Entry method.
  1. Manually turn on the VCR.
  2. Locate the enclosed VCR Code List. Find your brand in the VCR Codes.
  4. Press and release the VCR key. The indicator light blinks and then remains lit.
  5. Use the number keys on the remote to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3.
  6. Aim the remote at your VCR. Press the ON•OFF key. If your VCR turns off, you have found the correct code.
  8. If your VCR does not turn off, repeat steps 3-6 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote.
May 11, 2011 | RCA RCR311B Remote Control
Control lock light is on - The washer won't work. I unplugged overnight, and the light is still on when I plugged it in this morning. When I press Control On, HOld start, and Pause at the same time, the...
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off to unlock the control. You have to check the control for any stuck button and unstuck it if the control still cannot be unlocked with the End of Cycle button. The control needs replacing if no stuck button is found and unlocking it is not possible. Please let us know if that is the case and if you need further help. Just indicate the exact model number of the machine.
Jul 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is the code to use for universal remotes
i found that your brand is not RCA universal remote code list..
if your are using RCA controller follow the steps below
1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE
SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV,VCR or
DBS•CABLE). The INDICATOR LIGHT will blink once then remain lit.
Note: For AUX, press DVD•AUX
then the device button for the
code you are retrieving.
3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off.
4. Starting with 0 on the keypad, press the number buttons in order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code.
6. Repeat step 4 until you have retrieved all three numbers in code
if you are not having RCA controller or the method above is not works then buy new GE universal remote
solution using GE controller
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
i hope this will work
regards,
cseian
May 01, 2010 | Vivitek V37655 56" DLP TV
Lost remote control. have universal RCA and
i found that your brand is not listed RCA code list,
your G&E remote is good one and easy to detect code for your tv.
solution
using your GE remote :
1. Turn on the device(TV) you wish to program.
3. Press and release the device(TV) button for the device you are programming . The INDICATOR LIGHT will
using your RCA controller:
SEARCH.
i hope this will solve your problem
regards,
cseian
Apr 22, 2010 | Durabrand DWT2704 TV
2001 F-150 cruise control stopped working. Already checked the fuse and it's good. What's next
really tough to do on the net but first we need to know about any codes...
Hold speed control OFF button, and turn ignition switch to RUN position. CRUISE indicator should flash once to indicate successful entry into self-diagnostic mode. If CRUISE indicator does not flash, start procedure over. If CRUISE indicator still does not flash, repair system by symptom there might be some switch concern
If CRUISE CONTROL indicator flashes once followed by 5 additional flashes, replace speed control servo/actuator.
Release speed control OFF button. Within 5 seconds in entering self-diagnostics, press speed control ON button. Press remaining speed control buttons in the following sequence; ON, RES, COAST and SET/ACCEL.
As each button is pressed, CRUISE indicator will flash.
Wait until indicator light goes out, then press next button. After sequence has been completed, indicator light will flash to indicate test passed or failed. With the codes we can then better diagnose your concern
Immediately after static test has passed, actuator performs a dynamic test by automatically operating throttle .04-.40" (1-10 mm). Observe throttle movement to witness any sticking in cable or linkage. Ensure throttle returns properly. Turn ignition switch to LOCK position. If self-diagnostics do not pinpoint fault there is more we can do but tough over the net
Mar 26, 2010 | 2001 Ford F150 Styleside SuperCrew
Need codes for rcr 460 remote
1. Manually turn on the component
you want the remote to control
(TV, VCR, DVD, satellite receiver
or cable box).
Note: If you press an invalid key
during the Manual Code Search,
the remote does not respond and
the LED indicator light does not
blink. If you do not press a valid
Manual Code Search key (TV,
VCR, DVD, SAT·CBL, ON·OFF,
GO BACK), the search times out
after two minutes. When the
search times out, the LED
indicator light blinks four times
and turns off. The last
programmed code under that
component key is retained.
2. Press and hold the component key
(TV, VCR, DVD, SAT·CBL) you
wish to program. The LED indicator
light turns on and remains on.
3. While holding the component
key down, press and hold the
ON·OFF key. The LED indicator
light turns off.
4. After holding down both keys
for three seconds, the LED
indicator light turns back on.
5. Release both keys. The LED
indicator light remains on.
Throughout the
programming of each key, be sure
to keep the remote pointed at the
IR sensor of the component you
are currently programming the
remote to control.
6. Press and release the ON·OFF key
repeatedly until your component
turns off. Each time you press the
ON·OFF key, the LED indicator
light blinks, and the next code in
the list is sent. This process
continues until all of the codes in
the Code Lists have been searched.
If your component turns off, you
have found the correct code. (If it
cycles through and the LED
and turns off, all codes have been
searched. The Manual Code Search
method is exited.)
Press Stop when TV turns off.
Mar 06, 2010 | RCA Universal Remote Control
I'm missing the instruction manual for my RCA RCR460 remote control. I need the manual set-up instructions, and a list of all the potential codes to sync up to a Toshiba or Mitsubishi DVD player. Any help...
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box). Note: If you press an invalid key during the Manual Code Search, the remote does not respond and the LED indicator light does not blink. If you do not press a valid Manual Code Search key (TV, VCR, DVD, SAT·CBL, ON·OFF, GO BACK), the search times out after two minutes. When the search times out, the LED indicator light blinks four times and turns off. The last programmed code under that component key is retained. 2. Press and hold the component key (TV, VCR, DVD, SAT·CBL) you wish to program. The LED indicator light turns on and remains on. 3. While holding the component key down, press and hold the ON·OFF key. The LED indicator light turns off. 4. After holding down both keys for three seconds, the LED indicator light turns back on. 5. Release both keys. The LED indicator light remains on. Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control. 6. Press and release the ON·OFF key repeatedly until your component turns off. Each time you press the ON·OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the LED indicator light blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.) Press Stop when TV turns off.
Jul 06, 2008 | RCA RCR460 Remote Control
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
