Question about Yamaha HTR-5730 Receiver
Will not stay on
Can someone help me out my receiver will not stay on, it comes on and shuts off after 3-5 seconds
  • derek6622 Nov 01, 2008
    I have the same problem, It turned off all of a sudden when I pulled a wire out from under one of the footings and it seemed to take some kind of jolt when it fell, The fall was no more than the thickness of the power cord, and shut off immediately. Ever since, it turns on and then in a about a 3-5 seconds it turns off. No sound is ever heard at any time.
  • willwalk31 Dec 07, 2008
    i have a hrt-5730 av receiver and is the service manual the same as the owners manual if so i wasnt able to find diagnostic mode in the manual
  • 3 Answers
Your receiver is going into protection mode.
Need to know what type of reciever. In the self diagnostic mode there are code that will tell you why it is cutting off. If it is as you say you, as for the fall, you may just be able to reset it in diagnostic mode and everything will be fine. You can search for the service manual online. It will explain the diagnostics and the protection mode in detail.
Posted on Dec 05, 2008
Protect appears when the receiver is cut on. what does that mean?
I just wrote the reply below for someone who is having the same problem with their receiver than you are. So here it is. Enjoy. I hope it is a help to you.
Here is some theory as to why this is happening to your receiver. The "protect" mode is designed to respond to several related conditions:
The first reason is a wiring fault between the receiver and the speakers such as a strand of speaker wiring touching the opposite conductor so that there is a short circuit. If this happens the receiver will overheat and then shut down to protect itself. This is a good thing. otherwise you simply have a very expensive repair on your hands.
The second reason happens when the receiver is inside a closed cabinet and overheats because not enough air is going through it to keep it cool. So it shuts down in this circumstance.
The third reason happens when the receiver is playing loudly beyond the limit of it's design. In this case, it will overheat and thus shut down to protect itself.
Here is a diagnostic procedure for the first reason above:
What we are doing, in this case is looking for a shorted out speaker system, or wiring to speakers, or cables or components that are connected to the receiver that have a short circuit. This is what I would do if I were called to your house to debug your sound system.
1 Disconnect one set of speakers at the back of the receiver and turn the power button on again. See if it stays on.
2 If not, remove the next speaker and keep repeating the test.
3 If it still stays off, disconnect all of the equipment connected to the unit, one piece at at time.
Somewhere along the line, the receiver may not shut down. If that is the case
identify the the offending cable(or component)and replace or service it.
To correct the second reason simply leave the cabinet door open while the system is playing. The only problem with this solution is that if you don't have cabinet, it makes no sense.
To correct the third reason. Watch the volume level while using the system.
I hope this helps you.
If you have any questions at all, please contract me through this website.
Best Regards,
Mark
Jan 23, 2011 | Audio Players & Recorders
I have a Maytag Neptune gas dryer that is approx 8 yrs old and has worked great as far as drying time. The gas will now light and stay on for 15 seconds and then shut off, in 2 or 3 minutes it will light...
to me it sounds like your venting going out side,if it doesn;t get a clear flow it will come on and off the thermastate inside sencing to much heat.try unpluging the vent then try it if it stays on then you know your answer
Sep 12, 2010 | Maytag Neptune MDG5500AW Gas Dryer
RCA RT2400R Receiver shuts off 3 seconds
Try running the remote wire right to the power if it doent stay on,it may have a blown amp
Oct 27, 2009 | RCA RT2400R Receiver
Lightning Last Night Nocked The Receiver Out.
leave unpluged overnight. usually capacitors hold charge and will release slowly. try that if doesnt work powersupply is bad.
Jun 03, 2009 | Yamaha RX-V861 Receiver
AV-S17 - Clock Display won't stay on?
Check the internal memory battery if there is one, then reset the sleep setting? Check the manual regarding memory back up.
Sonic Doctor
Mar 27, 2009 | Aiwa AV-S17 Receiver
My Denon AVR5800 Receiver Shut itself off after I turned it on?
This amp is going into protect mode as it is sensing an internal overload,needs to be repaired...
Jan 08, 2009 | Denon AVR-5800 Receiver
Green lite comes on for about 2 to 3 seconds then shuts down red lite pulses
If the back was off the board on the left is your Ysus board. It will have a cable plugged into the right side of the board from the signal board. Unplug the the Ysus board. If it stays on without a picture change both Y and Z sustain boards. If this helps let me know.
Oct 15, 2008 | Philips 42FD9932 42 in. Plasma Television
When i power on the device, it comes on but goes off about 5 seconds later.
Hi...
1st thing to check is for GOOD speaker connections at both ends
and not mixing A and B speaker wiring.
A Denon is usually a good brand. Might be worth servicing if need be.
Sep 20, 2008 | Denon AVR-1905 Receiver
Onkyo SR502 Shuts off by itself
It is not a blown fuse. Your baby is in its ***** throes! It is fubar. You have either a damaged power supply or blown output stages (since sounds horrible it is probably this).
Sep 17, 2017 | Onkyo TX-SR502 Receiver
Yamaha HTR-5730 Receiver Logo
348 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
