Question about Crime Stopper Vehicle Parts & Accessories
I need to reset my RS795Vat remote starter
Replaced battery, light flashes on remote but truck doesn't start
ABKS
  • 39 Answers
SOURCE: Truck won't start, new battery, lights keep flashing
Sometimes the new battery is not 100% charged. Put it on a charger or jump start the car, the alternator should then charge up the battery.
Posted on Oct 09, 2008
johnjohn2
  • 5763 Answers
SOURCE: how do you reset the security system on this van
this is a aftermarket system, remove the fuse, look under the dash for a control box, follow the wires until you see a fused wire remove fuse, or if the bypass button is installed, this is a small push button under dash turn key on and push button 4 times,this sounds like someone already bypassed the starter disable, i would remove the rest of the alarm or just remove fuse.
Posted on Jun 15, 2010
  • 411 Answers
SOURCE: I changed the battery in
1. Locate the valet switch for your system. It's a small black push button, connected to a pair of wires that are gray and black. There's no telling where the installer placed it, or if he even left it connected. But if it's there and you find it:
2. Put your key in the ignition and turn it to the "on" or "run" position (not to "start").
3. While the key is on, press the valet switch once and release it, then press it again and hold it.
4. Press the "lock" button on the key fob.
5. Release the valet switch and turn the key off.
6. Test the key fob to see if it worked.
Posted on Jul 07, 2011
  • 9 Answers
SOURCE: the 'theft system' light does not turn off with the key in the run position on my 1999 chevy cavalier. car won't start, it won't even crank over. the battery and the starter are brand
try locking your car with the key and unlocking it with the key, leave it for 30 second or so between the locking and unlocking , the car thinks some one has tampered with it
Posted on Mar 18, 2012
tayjoejoe
  • 2217 Answers
SOURCE: 1999 2dr chevy tahoe security light flashes truck won't start
The security light is a visual indication that something in the car's antitheft system is failing. In most GM cars and trucks there is a hidden system that most people are unaware even exists. From the moment you put your key in the ignition, there begins a constant line of communication between your key's security chip or transponder, to the ignition's lock cylinder, and then to the car's TDM. (Theft Deterrent Module) The TDM is what tells your computer that the correct key is being used and that it is "OK" to allow the vehicle to start and run. These 3 parts must be in CONSTANT communication. If the key is in the ignition, then these parts are sending important signals to each other. The security light illuminates when that signal gets broken, even just for a second. When the signal breaks, (normally due to a failing/broken part) the car goes into antitheft mode. The car misinterperates this and thinks its being stolen or hotwired because it is NOT getting that signal from YOUR specific key. There is where the security light turns on and shuts down your vehicle. So basically, if that light is on, your system has some sort of failing part. This can start as an intermittent "no start", to your vehicle not running for days at a time, to the vehicle NEVER starting again. The problem is electrical and computer based, so don't count on an easy reset button, or the problem fixing itself. The hard part is isolating which part is the problem. You can spend a thousand dollars through a mechanic very easily. I have had great luck with bypassing the entire system. This way the problem will never return. It actually CAN'T ever return because it is eliminated. This can also be done yourself at a much cheaper cost. Read through this link very carefully. You'll find alot of information and pictures, along with ways to help you fix this.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Posted on Jun 26, 2012
Remote starter doesn't work when pressed
I think that you answered it yourself. Give you 1 point. The continual is the processor searching but not finding its mate. Replace the battery and repair them.
May 11, 2017 | 5101 LE 1 Way Car Remote Starter System
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
I changed the battery in my remote now my car will not respond
Reprogram the remote: press and hold the f button for approximately 8 seconds. the remote will flash three times. press the remote start button on the remote. the remote is now ready to pair. enter vehicle, turn ignition on, press and release button and antenna, immediately press and hold same button, the vehicle should respond with a horn honk and/ or light flash on antenna. While holding button on antenna, pres lock button on remote...vehicle should respond with a confirmation horn honk and/or light flash. Release button on antenna, turn vehicle off. Test system.
Jul 12, 2012 | 5101 LE 1 Way Car Remote Starter System
My 2000 ford focus will not start. It does not make any noise but the lights go on. It doesn't even turn over. My mechanic disconnected the remote car starter and that seemed to help but now I'm...
If it's not a dead battery, it could have bad connections. Check battery connections for tightness
Check the battery cable connection on the start solenoid, usually very near the battery. Check all wires on the sloenoid.
Check solenoid cable to starter for tightness at both ends.
If starter & battere are good it has to be one of above'
Good Luck
Jun 30, 2011 | 2004 Ford Focus
Wont start with remote.light blink one than two
disconnect battery to reset remote starter
May 12, 2009 | 2001 GMC Sierra 1500HD
Remote starter
I had the same issue with my remote start on another vehicle, the part that bypasses the code on the key had to be reset. The way we figured it out was everything was normal except the vehicle did not start & the security light flashed rapidly.
Nov 20, 2008 | 2003 Ford Expedition
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Frank Mangiapane
Level 1 Expert
Steve
Steve
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
