Question about Cadence Exercise & Fitness
Can I get a manual for my treadmill?
I can not find my manual and I need to know how to maintain it in good running condition.
Find the brand, model, identification, and serial number for ur equipment and use your preferred search engine on the internet. type in all that info and add owners manual at the end
Posted on Feb 08, 2012
Tip
Advantages and disadvantages of treadmills
1. Treadmills offer important health benefits for trainers. They help us stay in shape, burn calories, maintain low body fat, burn fat, and improve our speed. Let's take a look at some of the treadmills main advantages and disadvantages. First, during unpleasant weather conditions (rain, snow, etc.), most people cannot go out for a run. But if you have a treadmill at your home, you can run regardless of the weather outside. Second, the treadmill offers a variety of trainings likeintervals/speed training and hill training. Third, running on the treadmill isbetter for your knees and joints that running outside on concrete or asphalt.Now let's move on to disadvantages. Treadmills are very expensive, so if you're looking to buy one for your home, make a wise decision and buy a high quality one that will last you a long time. Another disadvantage is that it gets really boring! Many people who use the treadmill complain that regardless of their treadmill program, they are quite bored. Also, even though it is safer than running on hard materials from outside the gym, treadmills still puts pressure on your knees and joints, so people with knees and joint problems will probably benefit more from other equipment like elliptical machine. Last, compared to running outside, you don't work out ashard on the treadmill because of lack of wind speed.
on Aug 01, 2012 | Exercise & Fitness
Machine makes a LOUD clack clack clack while running. Seems to be coming from rear belt roller area...
It is probably the join on the belt itself as it passes the over the roller. It could be a sign that the belt is breaking.
Feb 24, 2015 | Bowflex TreadClimber TC5000
Error 27
Precor Error 27, Too Much Drive Motor Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 27
Feb 18, 2014 | Precor 933 Premium Series Treadmill
Adjust voltage on motor control board
Dear Sir:
You can adjut the voltage motor in m.m.board.
The only way is 1) Put some regulator voltage in the line for to maintain the voltage in the line Good 2)Try to get some circuit special for your treadmill without interference 3) You can add the voltage from the transformer inside from your machine.
However You can RUN the software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
May 07, 2012 | Reebok treadmill i-run s
Where can i get a weslo cadence m6 treadmill manual?????
www. weslo.com or www. fitness.manualsonline.com or www.iconservice.com
download for free.
Apr 21, 2012 | Exercise & Fitness
Dear doctor , Really i need to know if the ProForm 525E motor is DC or AC , can i run it on a gym ??
yes you can run in your gym, any machine is global attached by ISO 9000 + etc , and there are conditions for tipical voltage in many continents like North America, latin america, etc.
In short you can connect your tredmill in 120VAC(alternating current) or AC only you must provide a good circuit for protection with the require dimension wires + ampacity of breaker.
sincerely.
ERNESTO CUADRA
MANAGUA,NICARAGUA
Dec 08, 2011 | Treadmill Doctor Proform 525E Treadmill...
DOES THE UNDERNEATH SURFACE OF THE TREADMILL RUNNING BELT NEED TO BE TREATED WITH ANYTHING BECAUSE IT SEEMS TO BE STICKING
Yes! these units need to be maintained depending on usage. for example: 2 people using a treadmill 3 times weekly for a period of 30 min @ a pace of 3 mph would need to apply lubricant on deck every 3 months. Any exercise specialty store or sporting goods that are selling treadmills should have these lubricant kits with instruction on how to apply it.
Now their is a chance that your treadmill may either need the running belt or drive belt (under motor shroud) to have the tension adjusted.
Mar 11, 2010 | Proform 730 Folding Treadmill Model...
How do I best maintain the belt on a Proform 525?
read your manual- there is a small section that states NOT to use silicone/wd-40 on your item. You can use only the lube the manufacture(ICON) reccommends. Sears Parts store or parts on Phone 1-800- FON PARTS your part # is 06-831-135855 it is called walking belt lube The retail store does NOT sell this lube, they do sell the silicone spray-but its for the OLDER treadmills I know this I work on treadmills for the company!!!! with a little work, bypass the retailer, go to the source- they charge less...
Jan 07, 2010 | Proform 525C Treadmill Walking Belt
Please help..Need manual for 1993 Roadmaster treadmill.
Check Workout warehouse. Should be able to search them online.
Jun 03, 2009 | Proform 560hr Treadmill Walking Belt
Exercise & Fitness Logo
85 people viewed this question
Top Cadence Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Sportsmith LLC
Sportsmith LLC
Are you a Cadence Exercise and Fitnes Expert? Answer questions, earn points and help others
