Question about Maytag Refrigerators
I need the reset code for my Maytag Refrigerator MFF2557KES
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Maytag Model MFF2557KES EVERYTHING FREEZES
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Sep 17, 2011
Fridge not cooling
might need freon or the compressor going out cheaper to get a new or used one
Apr 22, 2012 | Maytag MFF2557KES 25 cu. ft. French Door...
Maytag Model MFF2557KES EVERYTHING FREEZES TOP AND BOTTOM COMPARTMENT
heatman101
Sep 17, 2011 | Maytag MFF2557HES Stainless Steel French...
Model msd2651kes Water supply very slow. I can't find any kinks in the lines. Detached hose from back of frig and water just dribbles out. Maybe I hooked up water supply incorrectly when I first...
If when first hooked up the water line if you used a peircing type valve that clamps onto the cold water pipe it clamps on,tighten the screws equally on both sides till its tight around the pipe.Turn that handle in to peirce the pipe in a clockwise motion till it stops,it will peirce the pipe but be in the closed position, so open it in counterclockwise direction till it stops
Gene
Aug 05, 2011 | Maytag MFF2557KES 25 cu. ft. French Door...
My Maytag MF12568AES Refrigerator is not cooling. May be I need to reset the computer.
This happens to my Maytag like clockwork every summer. The freezer works fine but the refrigerator stops cooling. The first time this happened, it was the fault of the small plastic DC fan that sends cooling from the freezer compartment to the refrigerator section. A technician replaced the DC plastic with an AC metal fan he guaranteed would last the life of the refrigerator. He blamed govt energy standards as the reason Maytag uses the cheap DC plastic fan in the first place. Problem solved. One year later, same issue with no cooling in the refrigerator, freezer fine. Again today, nearly one year to the day! SOLUTION? Trip the circuit breaker or unplug the refrigerator for a minimum of 5 minutes. A reboot now fixes the problem every time. Who would have thought you'd ever have to REBOOT your refrigerator?
Jun 15, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
My model MFF2557KES refrigerator not getting cold and freezer operating fine.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 07, 2009 | Maytag MFF2557KES 25 cu. ft. French Door...
Our maytag refrigerator has an automatic shutoff on the water dispenser if it runs continous for too long. It has to be reprogrammed and I can't find the code anywhere. Please help!!!
where do you reprogram it? I have the same problem the code is supposed to be on the serial number plate. I read you are supposed to change it to all zeros, then the code on the plate but I don't know how to reset it.
Aug 20, 2009 | Maytag MFI2266AE Side by Side Bottom...
Frdge not getting cold
Since your unit will have only one compressor, the cooled air must be circulated via a fan that distributes the air between the two compartments and this has probably died. This allows the cooled air to simply fall downward. When you can hear the compressor running, hold your fingers in front of the vents in the refrigerator compartment to see if you can feel any air stream.
Jun 07, 2009 | Maytag MFF2557KES 25 cu. ft. French Door...
Programming hv board
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Jan 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
