Question about Maytag MFF2557KES 25 cu. ft. French Door Bottom Freezer Refrigerator w/ Electronic Dual Cool Syste...
Need reset or defrost code for Maytag MFF2557KES Refrigerator
4 Suggested Answers
SOURCE: MZD2766GES Maytag defrost problem
in fresh food part on top right, remove the housing assy.
Posted on Aug 07, 2008
Sea Breeze
  • 4654 Answers
SOURCE: my maytag wide by side having cooling problems.
Here is the service manual for your model=> MSD2652KE Go ahead and unplug defrost manually and if you like I will be your Technician. Thanks, Sea Breeze
Appliance 911 Repair Forum
Sea Breeze Appliance Parts
Posted on Jan 02, 2010
heatman101
  • 43501 Answers
SOURCE: Maytag Model MFF2557KES EVERYTHING FREEZES
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Sep 17, 2011
Where is defrost timer reset switch on a Maytag mfd2561heb
This model Maytag has a defrost control board and not a defrost timer. Your control board is located at the top of your refrigerator behind the display.
Jul 28, 2016 | Maytag Refrigerators
Maytag refrigerator
I think the fan is not working ( inside the refrigerator, not at the back)
Mar 10, 2013 | Refrigerators
Fridge not cooling
might need freon or the compressor going out cheaper to get a new or used one
Apr 22, 2012 | Maytag MFF2557KES 25 cu. ft. French Door...
Maytag Model MFF2557KES EVERYTHING FREEZES TOP AND BOTTOM COMPARTMENT
heatman101
Sep 17, 2011 | Maytag MFF2557HES Stainless Steel French...
I have a Maytag French door bottom freezer Refrigerator. The freezer is working fine but the frigerator stopped cooling entirely. Is there anything that I can do to fix it. A technician will charge $75...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Aug 01, 2011 | Maytag Refrigerators
Ice maker stopped working
Take off the back panel in the freezer. 1/4" screws. Use a nut driver or ratchet and socket with an extension.
2. Behind the frost is the evaporator and the defrost heaters. One heater in the middle and one at the bottom. They are glass tubes. If you can see the bottom heater that is great. If not use a hair dryer and defrost only the very bottom to expose the lower heater only.
3. Now in the refrigerator section at the top where the controls are, take off the long plastic piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and the refrigerator turns off. This will put it into defrost.
4. Now look at that heater that you exposed and see if it glows and gets hot. If it does, then the timer is bad.
5. If the heater doesn't come on then go ahead and defrost the rest of the evaporator with the hair dryer. This will take a little while. Don't poke at the evaporator!!!
6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running thru them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator.
7. If the heaters look ok the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem. However the best thing to do is replace the heaters and defrost thermostat . It is easy to install.
Follow these steps and this will solve your problem.
Good luck
Aug 14, 2010 | Maytag MFF2557KES 25 cu. ft. French Door...
My model MFF2557KES refrigerator not getting cold and freezer operating fine.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 07, 2009 | Maytag MFF2557KES 25 cu. ft. French Door...
Frdge not getting cold
Since your unit will have only one compressor, the cooled air must be circulated via a fan that distributes the air between the two compartments and this has probably died. This allows the cooled air to simply fall downward. When you can hear the compressor running, hold your fingers in front of the vents in the refrigerator compartment to see if you can feel any air stream.
Jun 07, 2009 | Maytag MFF2557KES 25 cu. ft. French Door...
Maytag MFF2557KES 25 cu. ft. French Door Bottom Freezer Refrigerator w/ Electronic Dual Cool Syste... Logo
107 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
