Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson stylus sx415 paper jam - Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Dipu007
  • 2110 Answers
SOURCE: Epson Stylus D88 Plus paper jam
1. Unplug the power and USB cables from the printer. I pried open my C42UX printer, careful not to break anything. I use a flat blade screwdriver to pry it apart; there are two-three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
2. Next I removed the two (2) waste ink pads. They are located at the back on the left hand side. I used the flat blade screwdriver to lift up the ink pads (they were soaked). Please use rubber gloves as it gets very messy.
3. Next I took the pads to the kitchen skin and washed them with just plain hot water until they were white again. I just let the hot water run on them (the pads are about three inches long).
4. Once washed I dried them using a hair drier. (you could place it the sun for a few hours or on top of your heater or maybe in a heated oven; (make sure you do not set it on fire with too much heat).
5. Once dried I placed the pads back in the ink waste bin at the back of the printer.
6. I closed the printer cover and put back all the pieces and plugged in the USB & power cable and turned it on. (Yes the lights are still flashing).
7. Go to this link and download this software: http://inkjetprinterhelp.us/epsonSSC.html
8. Install the software and run it.
9. Select your printer and model number ( It only says C42 there is no UX, choose it anyway).It will ask if you replaced with new pads; say “YES”. Then close the window.
10. Now right click on the SSC service utility, it looks like a printer icon near your clock in the task bar.
11. Then click on reset counters. You can do all other stuff with this utility too.
12. Turn off the printer power and then turn it on again. If necessary un-plug the power cord from the back of the printer, wait 20 seconds. Plug it back in.
13. THERE YOU GO! IT WORKS AGAIN.
14. By the way I use generic ink and I fill my own cartridges. I use ink from www.atlanticinkjet.com. Great stuff.
try this and let me know it worked or not ...
Posted on Dec 12, 2008
yooperbud
  • 8637 Answers
SOURCE: paper jam error
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 23, 2009
  • 415 Answers
SOURCE: does n e one know if the Epson Stylus SX415
Yes it is. I checked the Epson website and it has drivers for Windows 7 so it is compatible.
You can download drivers here:
Epson Drivers
Posted on Jan 31, 2010
Testimonial: "cheers, ill give it a go!"
pineworks
  • 4041 Answers
SOURCE: Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 28, 2010
pandeyram1
  • 192 Answers
SOURCE: About paper jam for epson stylus photo r230.
check for any little peace of paper into your printer. may be any sensor are open.
Posted on Mar 31, 2010
SX415 Error message A printer error has occurred - switching off and on again results in the same message.
Diagnosing the Problem - Epson
https://files.support.epson.com/htmldocs/rx620_/.../trble_1.htm
EpsonAn error has occurred in the printer parts. Turn this product off, and then back on. If theerror message still appears, contact your dealer. Scanner error occurred.
Epson printer sx415 printing problems/paper jam - Forum Thread ...
www.pcadvisor.co.uk > Forums > Tech Helproom
Jun 30, 2010 - Epson printer sx415 printing problems/paper jam ... before it will work correctly again otherwise you will continue to get the error message.
Oct 08, 2015 | Epson Stylus Office Equipment & Supplies
I have lost the disk to install my epson stylus sx415 printer to my laptop
l.- Go to : epson.com "
2.- click on " download driver "
3,- Select the one you need for your epson printer
4.- Download to your computer under " documents " .
5.- Click on " run "
good luck
wilsoncopier
Feb 16, 2011 | Epson Stylus Photo R1800 InkJet Printer
How do you use the epson stylus sx415 to scan documents
when i go to my desktop it says epson scan and click on there and it does the rest hope this helps
Aug 24, 2010 | Epson Stylus C86 InkJet Printer
Epson Printer NX400 series problem
Found this on the web. You can download the
manual, reference guide, troubleshooting guide and more. Hope this helps. If you find this helpful, pls rate. me.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=106004&infoType=Overview
According to the error codes :
Make sure there's no jammed paper or other obstruction inside your Epson Stylus.
The print head may not be able to move because of some obstruction. Follow these steps to remove jammed paper or other obstructions from the Epson Stylus:
Turn off the Epson Stylus.
Open the scanner.
Remove any jammed paper or other obstructions from the paper path.
Carefully lower the scanner.
Turn the Epson Stylus back on.
Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Epson Stylus.
Good Luck............
Jan 22, 2010 | Epson Stylus NX400 InkJet Printer
I've just installed my new Epson SX415. Please
hello just bought a new epson sx415 i cant find in the operation guide how to scan to pc or no symbol on the printer. can you help thanks
Nov 18, 2009 | Epson Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
312 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
