Question about Sony FWD40LX2F 32 in LCD TV
Factory menu fwd40lx2f
Please can you give me a back end menu so i can change the preset volume!
How do I restore factory presets to me Samsung Galaxy 6?
You need to do a factory recovery. Follow the link and read the information there n doing a reset. Two Ways to Factory Reset Galaxy S6 and Galaxy S6 Edge
Dec 30, 2016 | Samsung Cell Phones
My Yamaha HTR 6130 surround sound amp just froze up on me and won't turn off or on or control the volume ect. I'ts on but will not do anything, I can't control from remote or the unit itself at all.
HI
i think the unit needs to be set back to factory defaults
procedure is
Initializing the HTR 6130
1. Connect the power cable of this unit to the AC outlet.
2. Press the "STANDBY/ON" key while simultaneously pressing the "STRAIGHT" and "AUDIO SELECT" keys.
The self-diagnostic function is activated.
3. Select the main menu "13. FACTORY PRESET".
4. Select the "PRESET RSRV".
Hope this helps
Kind regards.
M.Mathis
Apr 14, 2016 | Yamaha Htr-6130bl 500 Watt 5.1-channel...
KD-R805 does not store clock settings
first of all you must be able to check out a few things like do you know how to set your clock for the kd-r805. if you can check to see if you set your clock and set your presets for radio station to be saved. set your clock and set all your station presets once done. Once you have done that turn off the car wait about 60 seconds then turn your car back on to power up the radio and see what happens to your clock and presets . if your clock and presets are not still saved this means that who ever did the radio install has the yellow memory wire connected to switch ignition and not constant battery wire from the factory harness. have someone fix it. If the clock and station presets are still save then it was that you don't know how to program the clock.. how to program your model radios clock .......
STEP 1 : TURN ON POWER TO RADIO
STEP 2 : PRESS AND HOLD MENU UNTIL THE MAIN MENU IS SHOW ON RADIO SCREEN PRESS AND TURN THE VOLUME KNOB TO MOVE THROUGH THE MENU ( YOU MUST CANCEL THE DEMO FIRST TO BE ABLE TO PROGRAM THE CLOCK).
STEP 3: TO SET THE CLOCK SELECT THE CLOCK IN THE MAIN MENU SETTING ROTATE THE VOLUME KNOB AND PRESS IT ONCE TO SELECT THE CLOCK SETTING.
STEP 4: ADJUST THE HOURS AND THEN PRESS THE VOLUME KNOB TO MOVE ON TO THE SECONDS .
STEP 5 : THEN SELECT 12HR OR 24HR TO BE DISPLAYED
STEP 6 : RETURN TO THE PREVIOUS MENU BY HITTING (BACK BUTTON)
STEP :7 TO EXIT SETUP OR MENU HIT THE (MENU BUTTON)
radiorepair@www.windowtintingin239.com
Oct 26, 2013 | Car Audio & Video
I have a L46FHD37 lcd tv how can i reset it
The Sound menu lets you adjust audio output. To access the Sound menu, press MENU on the remote, and then select Sound from the Main Menu. The following audio items can be adjusted:
Equalizer The five-band graphic equalizer lets you adjust the audio frequency settings. You can select one of the five-band Equalizer Presets or create your own personal preset.
Sound Preset Allows you to choose a specific Sound Preset. Press the right arrow to cycle through the options: Standard, Movie, Voice, Music and Personal.
Frequency Range Displays the different graphic equalizer bands set for each Sound Preset option. Choose a band and make adjustments. When you make adjustments, the Sound Preset option automatically changes to Personal. Press the left or right arrow button to select the frequency (100Hz, 300Hz, 1KHz, 3KHz, 10KHz) you want to adjust. Then use the up or down arrow button to adjust the level. When you're done adjusting the levels, press the MENU button to exit.
To view the frequency range of another Sound Preset option, press the right or left arrow until no band is selected and Frequency Range is highlighted. Then press the up arrow to highlight Sound Preset.
Sound Type Controls the way the sound comes through your speakers. The options available vary according to the input selected.
Mono (available for regular TV viewing only) Plays the sound in mono only. Use this setting when receiving broadcasts with weak stereo signals.
Stereo Splits the incoming stereo audio signal into left and right channels. Most TV programs and recorded materials have stereo audio. The word Stereo appears in the channel banner when you tune to a program that is broadcast in stereo.
Sound Mode Provides special processing through your speakers (depending on the setting you chose as your Sound Type). The available sound modes are:
Off Does not give any special sound processing.
SRS WOW Gives a surround effect with more bass. (available for models L42FHD37, L46FHD37, and L46FHD35) SRS TurSurround XT (available for models L42FHD38, L46FHD38, L52FHD38, and
L40FHD380) Dynamic Bass Improves bass output. Displays a choice list of available settings you can adjust: Off and On.
Balance Press the right or left arrow buttons to adjust how much audio is sent to the left and right speakers.
Auto Volume Level Reduces the annoying blasts in volume during commercial breaks, and also amplifies softer sounds in program material. Eliminates the need to constantly adjust the volume.
Internal Speakers Turn on or off the internal speakers. If you have a device connected to the AUDIO OUTPUT jacks on the back of the TV and you want to control the sound by the device instead, uncheck the box.
If you would like for me to send you the user manual, please send me an email to LBrown18062@hotmail.com. Put "RCA L46" as the subject and I will send it to you.
Mar 30, 2012 | RCA L46FHD2X48 46 in HDTV TV
The television turns its volume down to zero and won't turn off or change.
You must preset the volume value in the MENU option, go Menu and search the VOLUME option and set to a good level for you
Fosg2000 Please Rate Me !
Mar 20, 2010 | Samsung HL-T5676S Television
I cannot make any changes to my Zone 2 -- cannot change the volume or change the setting from what Zone 1 is on. A blinking symbol that looks like a mushroom appears when you are trying to switch between...
Hi.
Looks like the the unit is locked to region 1.
The Yamaha receiver you listed is region free, therefore I assume you are talking about a different unit, in that case give model please.
If you have the problem with a Yamaha RX-V661, then simply disconnect power cord for ten minutes. And disconnect from power all devices connected to the receiver.
This should reset the system.
Let me know in case it does not work.
Regards.
Nov 17, 2009 | Yamaha RX-V661 Receiver
ACER Aspire 3610 Wireless and Blootooth Switches
if you have a system restore disk, restore the settings back to the factory presets. XP System restore could help you, but the restore disk is usually the end result
Sep 05, 2009 | Acer Aspire 3610 Notebook
When I Turn My Car On The Volume Is Always Preset
There is a way to set the power on volume. most of the time you would turn the volume to the level you want it at when you start the car and then while it still says volume on the display you hit another button to lock it in. You may have to check the manual to find out which button to hit or just keep trying buttons till you find the right one. When you do the display will change from volume to something like "powr v" set.
Jul 10, 2009 | Phase Linear UDV9010 Car DVD Player
Change illumination colour Alpine CDA 9853
1. Go to menu
2. Using touchbar go to 2nd function
3. Using touchbar choose a preset colour or tap P1 at the end on the touchbar and use the volume round thingy to choose your own colour by turning the volume knob.
Jul 10, 2009 | Alpine CDA-9855 CD Player
Sony FWD40LX2F 32 in LCD TV Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
