Question about Toshiba Satellite L355-S7915 Notebook
Double click on mouse not workin - Toshiba Satellite L355-S7915 Notebook
    Problem Solver:
  • 16 Answers
Does single click work? if so, the problem is the amount of time between the first click and second click, if the delay is too long, the computer will only register it as 2 single clicks.
Double click settings are change in control panel > mouse
Posted on Feb 08, 2012
The left mouse button doesnt work every 4th press...
I believe the switch inside the left mouse button has worn out or broken that made you think after pressing 4 times you were able to trigger the switch and make the mouse to work. You may open your mouse carefully to see if this is the case. If not please follow the below steps as you might need to configure the mouse double click speed.
Open control panel>Double click on the mouse icon>Button Tab>Double Click section>Adjust your double click speed.
Jul 19, 2011 | Computers & Internet
My toshiba touchpad is not working
1. Go to the "Control Panel" and double click on the "Mouse" item.
2. Go through the tabs in the "Mouse Properties" window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
3. On that tab, check & make sure that your touchpad is enabled. If it is not, then change the setting to enabled.
4. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
If you cannot find a tab to set up your touchpad, then your touchpad drivers might not be installed. In this case, you will need to install them first.
Nov 02, 2009 | HP Pavilion dv4000 Notebook
Double click on single clicking the left mouse
Try changing the "Double-Click speed.
2. Check for the Folder option.
Good Luck!!!!!!!!!!!!
Oct 20, 2009 | Computers & Internet
Mouse sometimes double clicks so that it opens 2 things at a time, what is causing that. It also seems to be sticking I have to press it a couple of times to get it to click
You need to go into the control panel and choose the mouse icon.
From there you can set the double-click speed. They give you a little box to click to calibrate the click speed.
Aug 03, 2009 | Logitech Cordless Mouse
Double clicking
Access CONTROL PANEL.
Access MOUSE.
Set the "double-click" speed to your personal taste,
to avoid "accidental" double-clicking.
Jul 17, 2009 | Logitech MX1000 Laser Cordless...
The wireless mouse Double clicks on its own
go into the control panel under mouse and make sure your settings are set to single click insted of double click.
Nov 28, 2008 | Logitech Cordless Mouse
Dell Latiture D600 Touchpad not working!
Have you downloaded and installed the latest glide pad drivers from Dell?
Upon starting your laptop I would enter the bios setup screens and navigate the startup screens using Alt+P to find the pointer settings and set your or check that yours is using Glide Pad only, If you so choose to use an external USB travel mouse, this setting must be changed to Serial only.
Once, you download and install the latest drivers for the Glide Pad, and by the way, the Glide Pad on the D600 series is its only weak link in an otherwise best in class laptop.
To access the sensitivity settings for your Glide Pad after installing the new driver or in your case this may be reinstalling (I have to do this way to often) open Mouse within Control Panel and the last Tab is your Glide Pad. Here you can change a lot of the property values for things like sensitivity and double tap scrolling etc. Your mention of the mouse traveling up and to the right in most case is normal for this laptop.
Here is the link for the Glide Pad driver update. If this link has expired, here is the permanent location. Just click on the download button on this page. Download and move to a unique folder as the file name won't be of help. Move to something like c:\software\Dell\Glide Pad\
Regards,
Worldvet
Jul 24, 2008 | Dell Latitude D600 Notebook
Logitech Cordless Mouse clicks too fast!
Try going into control panel, mouse, and set a longer delay for the double click.
Thanks and please take a moment to rate as FixYa. Thank you.
Jul 23, 2008 | Logitech Cordless Mouse
Faulty mouse
You need to check your settings by going to Start-----Control Panel------Mouse. Make sure everything is normal. If its all good from there, try a different mouse. The software installation should have nothing to do with your mouse function.
Oct 29, 2007 | Compaq Armada M300 Notebook
MSI mouse thats included in MSI S420
you need to check the mouse settings, go to Start>control panel>printers and other hardware>mouse and check that it isn't set to one click as being a double click, check all other settings also especially the click speed may be set too fast and is encouraging a double click.
Jun 24, 2007 | MSI (MUKUA) Mouse
Toshiba Satellite L355-S7915 Notebook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
