Photofix SP5 Digital Image Copier user Manual
3 Suggested Answers
  • 6 Answers
SOURCE: User Manual for a Copier
try canon USA .com
Posted on Jun 24, 2008
SOURCE: Canon image runner 400s copier
error E014
Posted on Apr 06, 2011
Drivers for windows7
I would check the website of Summit Photofix Copier for the correct drivers for your device and your OS.
Feb 29, 2016 | Summit Photofix Copier Sp2
Error sc 870
One possibility:
Address book data stored on the hard
disk was detected as abnormal when it
was accessed from either the
operation panel or the network.
?? Initialize the address book
data (SP5-846-050).
?? Initialize the user information
(SP5-832-006).
?? Replace the HDD.HDD defective
Secondly:
When the machine reaches the Ready condition after boot-up, the operator turns OFF the Main Power
Switch without first pressing the Operation Switch. As a result, the flash memory on the controller board is
damaged, triggering the SC.
SOLUTION:
1. Please be aware of the following:
Before turning off the machine's main power, always make sure that the Operation Switch LED is not
lit or blinking. By turning the Main Power OFF while the LED is still lit or blinking, may cause damage to
the machine's hard disk or memory.
Feb 22, 2013 | Ricoh Aficio Mp3350b Digital Copier...
We have a toshiba e studio 181 copier, it have an error messsage sp5. what will we do?
is that really e-181 and sp5?maybe that error is C55 which is adf i/f error.communication error between the adf and scanner
Mar 19, 2012 | Toshiba Office Equipment & Supplies
How to access sp5 on 2228c when changing developer unit
the only way I can help you is to give you a service manual.
The service manual is for 3800C but it`s the same machine.
You can download the manual by clicking HERE.
Jun 06, 2011 | Ricoh Aficio 2228C Copier
Error code 350 error code 990 error code 540
Error code 990 indicates software problems yuo can check in SP7-403 for information.
Error code 540 will proberly indicate some heating trouble in the fix, you have to reset the machine with service code SP5-810.
Code 350 will disappear if you restart the copier.
Oct 09, 2009 | Ricoh Aficio 1035 Copier
Have error code sc457 on copier, have received detailed instructions on how to fix it, but I need to know how to open it?
SC457 Position error for the image transfer belt’s cleaning unit
- Timing & Condition
• When the belt cleaning section touches the image transfer belt, but the belt cleaning sensor signal remains LOW.
• When the belt cleaning section releases from the image transfer belt, but the belt cleaning sensor remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning shift clutch
• Defective drum peripheral component motor
• Defective I/O control board
• Defective main control board
1. Pull out and re-insert the image transfer belt unit.
2. Clean the image transfer belt cleaning H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-012)
4. Replace the belt cleaning shift clutch.(Output Check: SP5-804-036)
5. Replace the drum peripheral component motor.
6. Replace the I/O control board.
7. Replace the main control board. [Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O control board
The above information are taken from the service manual.
Good Luck!!!!!!!!!!!!!
Sep 20, 2009 | Office Equipment & Supplies
How do I get a driver for Summit Photofix Copier?
I have a 2 year old Summuit photofix and have recently got a new computer with Widows 7. The Summit won't work.
Any ideas.
iAN
May 03, 2009 | Office Equipment & Supplies
Ricoh 1232c reset SP5-810-1
press the yellow button on the copier. Then press the 107 keys. Press and hold the clear button. Then the service code screen will appear.
Goto sp5 first then choose the 810 button from the screen. You will probably have to page down to find the 810 key.
Nov 05, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
