Question about Garden
What type of hyd. fluid for mf175? - Garden
  • Garden Master
  • 2,478 Answers
It calls for massey perm-tran-III. They claim 134 oil at WALMART is the same.
Posted on Feb 08, 2012
WHAT TYPE FLUID IN HYD SYSTEM
If your hydraulics and trans are one using the same oil then use ATF oil, if your hydraulics is a separate tank then you can use a hydraulic oil, ATF, or a light weight oil
Jan 12, 2016 | Garden
1952 Fordson major diesel hyd fluid gets into front tranny
Sounds as if the input shaft seal for the hydraulic pump that is driven off the transmission is bad and allowing the fluid to enter the transmission housing. When the fluid gets too full it aerates and causes the "root beer float" fluid.
Mar 05, 2015 | Cars & Trucks
What is destroying front hyd. seals?
Mechanic is not doing the job correctly and should be doing subsequent repairs free or paying for someone else to do it right.
Dec 09, 2014 | Cars & Trucks
What type lubricant is used in jcb js200l escavator.
where in motor ?hyd fluid? grease in bucket and boom arms?
Sep 27, 2014 | Cars & Trucks
No fluid from rear pump 410 john deere backhoe
1st ck hyd tank for fluid level and fluid quality 2nd remove and ck hyd filter for blockage (note some hyd filters have a water sensing block valve inside) 3 rd verify that fluid is reaching pump , pumps will make horrible noises with no fluid in them , if all are well replace pump , and ck that bypass valve is not stuck open and is set correctly (some are internal to pump )
a method i've been sucessful with is to temp power hyd system with remote from another working tractor/bobcat , this sometimes unsticks bypass valves , but unless your familiar with what fittings do what and such I don't recomend this action for novices
Mar 19, 2014 | John Deere Garden
Hyd problem with JD tractor
Crack your hoses on cylinders to get air out of them.
Feb 06, 2014 | Garden
Where do you put hydrallic oil in a mtd white lawn tractor ,
First thing hyd. oil should not and can't come out the oil filter. May a hyd. filter. I'll try to find something. Most tranmission are sealed.
May 06, 2012 | Garden
1994 chevy 3500 1 ton dump hyd problem when I activate the hyd unit, I can hear the pump running, and it seems to develope a load on the motor, but the cylinder does not lift. I had the dump body...
There should be a bleeder valve on the cylinder itself somewhere. Otherwise with air in the system, Im surprised no hyd fluid came out the top of the cylinder!
Feb 05, 2010 | 1994 Chevrolet C/K 3500
My 345 john deere hyd pump is whining
What does your fluid look like is it milky?also you can be getting air in the system,And the most important the hyd filter change,and your pump just might be getting tired
Sep 14, 2009 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
