Question about Whirlpool Kitchen Appliances - Others
I have a Whirlpool WRF40IX refrigerator. I believe the control pcb is faulty. The frige only work on the med setting. How do I replace it?
You need to remove the front cover that houses the pcb. If you open the main fridge door and look (from the bottom) up on either of the edges of the control unit cover, you will see clips that can be released by inserting a flat blade screwdriver and applying a small amount of pressure to the clip while pulling the cover away from the case. This will release the cover.
Posted on Jan 29, 2015
I have a Whirlpool Refridgerator model WBM39MS. It stopped cooling and I had it repaired. The Repairman replaced the electronic control box. Repairer claims that the compressor is working. It now seems...
Hi Lollipop, partially working fridge? A fridge either works or not, cold air is made in freezer then distributed to fridge via a vent. In your case WBM Series fridge, top mount freezer blows air down a vent (back centre of chiller compartment). A common fault with the WBM Series is both the PCB and Interface Panel (PCB beside compressor back of fridge, Interface is display panel front of fridge).
So if freezer is cold and fridge not, try a fan motor. If compressor doesn't work either comp is faulty or PCB has blown(has a burning smell).. Hope this helps you and maybe many other ppl.
Jan 21, 2010 | Refrigerators
Whirlpool Refrigerator not working -------------------------------------------------------------------------------- Hi all, I have a Whirlpool ED22PC SxS fridge which has stopped cooling on both the...
Hi. Due to the fact that the fans are not operational, this will confirm that the Main PCB has failed. This is the main power control board. It must be replaced, asap. The general location of this affected board will be just behind an access panel, near the compressor unit, or on the backside, mounted in the middle section of the unit.
Once the Main PCB board is replaced, the unit will return to its normal operating status.
Dec 21, 2009 | Whirlpool Refrigerators
Whirpool gold Frige no light or temp display working
I am having the same problem does anyone have a solution?
Dec 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Doors need levelled - motor runs very loudly but is silent when fridge door is opend - Can you send instructions as to how to level the doors?
the door leveling is controlled by the front legs on the bottom of the frige. make sure the frige is level first.
Oct 29, 2009 | Whirlpool GS5SHAXN Side by Side...
My whirlpool gold frige ices up and doesnt keep refrigerator side cold
The most likely problem is mthe part number W10135899 defrost control board. Next likely is the defrost heater and the defrost thermostat. Thanks, Sea Breeze
Oct 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge is not cooling on my Maytag MSD2756GES
Check thermostat and fan switch. If not same thing need changeagain
Sep 04, 2017 | Master Bilt Indoor Step In Cooler 70""W x...
Refrigerator side not working
The freezer is workig fine but refrigerator side is not cooling.
Jun 10, 2008 | Whirlpool GS6NBEXR Side by Side...
ICEMAKER DOES'NT WORK.
hi there sounds like your control pcb is at fault
Dec 13, 2007 | Whirlpool (ET8FTEXSQ) Top Freezer...
Kitchen Appliances - Others Logo
248 people viewed this question
Top Whirlpool Kitchen Appliances - Others Experts
richie46
John Tripp
John Tripp
Are you a Whirlpool Kitchen Appliances - Other Expert? Answer questions, earn points and help others
