Question about HEWLETT-PACKARD Hewlett Packard HP ProBook 4530s 156 Notebook PC (XU073UTABA
Hp probook 4530 ac connected indicator flashing. will not power up
Hello thanks for any help.. got an hp probook 4530 here that when you plug in the ac adapter the indicator light above power jack flashes constantly.. and the laptop will not power up.. tried running of a different and know good battery.. no change.. pulled the memory and hard drive no change..helpppp thanks
    Problem Solver:
  • 11 Answers
Remove the battery, Plug in the AC charger. Push and hold the Power on button for 45secs. If this doens't reset. The fault is most likely the System/Motherboard. If the unit is under warranty, contact HP and arrange a repair.
Posted on Sep 01, 2012
  • 355 Answers
Either your charger is not providing the perfect voltage or there is a short circuit in your motherboard. Try replacing the charger first. If still the problem persists then you should check the connector. try resoldering it cause loose connection in it also sometimes causes this problem.or you need to change the motherboard finally.
Posted on Feb 08, 2012
Why wont my hp 4530s boot?
This indicates one of the following:
1. Dead Battery
2. Incompatible Charger
3. Incompatible battery
4. Static Charge Overload - Take out battery, unplug charger, hold power button for 30 seconds, put battery back in, plug in charger and press power.
LB
Jul 13, 2014 | HEWLETT-PACKARD Probook 4530S 156 I52410M
The power button don't turn on the laptop
The RAM is not connected properly or it may have become damaged
you know it is useless to power up a battery powered computer without RAM so it blinks twice to tell you the situation then stays off.
try replacing the RAM with a new one
Nov 26, 2013 | HEWLETT-PACKARD Probook 4530S
How do restore my hp probook 4530 to original factory settings
Try downloading or purchase a Restore CD for your model HP Probook from the HP WEB site. Boot up with this Restore CD and follow the instructions.
http://welcome.hp.com/country/au/en/cs/support.html
Apr 16, 2013 | HEWLETT-PACKARD Probook 4530S 156 I52410M
My notebook does not want to switch on. The charging light flashes blue ones and that is it. The battery is not faulty and the ac adaptor was replaced. If anyone could help me.
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just your hp probook 4730s adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Jan 04, 2013 | HP ProBook 4730s Notebook
Set dead
Did you plug your AC adapter in and then try to turn it on? It may be that your battery ran out of power. Try to plug your AC adapter into your laptop, wait about 2 minutes for the battery to charge, then turn on your laptop. If that doesn't work, you may need to replace your battery. The battery on that laptop is fairly cheap, ranging in price from $10 used to $60 new. If that doesn't work, your power button may need to be fixed. You then need to have it fixed by a reputable computer repair store.
Hope that helps. Good luck!
Jun 27, 2012 | HP Computers & Internet
Blinking white amber light above power cord
The power supply is the issue, or the DC jack in the laptop has developed bad connections, or ram issue. Remove 1 stick of ram and power on, if no! remove second one, and replace the first, power up, if no! test the power supply for proper voltage, if okay! it is a DC jack or motherboard problem.
Mar 09, 2012 | HEWLETT-PACKARD Probook 4530S
HP DV2036ea i have a blank screen on the computer
Hello there
Description.
When pressing the notebook power button nothing is displayed on the screen or display. The cause of this problem may be a failed AC adapter, the memory modules (RAM) need to be reseated or a failed notebook system board component which will require an HP certified repair.
Below steps will assist in identifying the cause of the problem and suggest the best solution. Test the AC adapter Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board.
  1. Remove the battery and disconnect all external devices from the computer.
  2. Hold the Power button for several seconds, with all power sources removed. This drains residual power from the system, and may correct many problems.
  3. Connect the AC adapter to a wall outlet and plug the other end into the computer.
  4. Press the Power button to start the notebook PC.
If the notebook does not start or the display is blank then check the power indicator light or power socket LED. Check the power indicator light or power socket LED On newer models of notebook PCs, there is an LED or indicator light around the power socket on the notebook. Check to see if this light is on or off, when the notebook is plugged into AC power.The power indicator light or power socket light should turn on when the AC adapter is connected.
  • If the light does not turn on then the problem is most likely related to the AC adapter or the electrical source in your home or office. Go to the Light does not turn on section on this page.
  • If the light does turn on but the notebook does not start or the there is a blank screen then continue to the Light does turn on but the notebook does not start section on this page
The light does not turn on when the AC adapter is connected If the power indicator LED is off, the AC power adapter may need to be replaced. To determine if the AC power adapter needs to be replaced follow the steps below:
  1. Ensure that the AC adapter is plugged directly into a known working wall outlet.
    NOTE: To check the wall outlet, plug in a different known working device like a light, radio etc.
  2. Check all of the following connections:
    • The connection from the power cord to the wall outlet.
    • The connection into the power adapter from the power cord.
    • The connection from the AC adapter to the notebook power socket.
  3. Press the power button again to test the notebook PC.
If the power indicator light still does not turn on, then the AC Adapter needs to be replaced. Contact HP Service and Support for further assistance. Power socket LED or power indicator light is on but the notebook does not start If notebook power indicator light (LED) is on, the AC adapter is working correctly. The problem is a result of a hardware failure in the notebook itself. In some cases, reseating the memory module (RAM) may solve the problem.
Feb 02, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HEWLETT-PACKARD Hewlett Packard HP ProBook 4530s 156 Notebook PC (XU073UTABA Logo
1,387 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
